RTEMS 6.1
_flexio_i2s_type Struct Reference
Define FlexIO I2S access structure typedef. More...
#include <fsl_flexio_i2s.h>
FLEXIO_TypeflexioBase
uint8_t txPinIndex
uint8_t rxPinIndex
uint8_t bclkPinIndex
uint8_t fsPinIndex
uint8_t txShifterIndex
uint8_t rxShifterIndex
uint8_t bclkTimerIndex
uint8_t fsTimerIndex
Field Documentation
◆ bclkPinIndex
uint8_t _flexio_i2s_type::bclkPinIndex
Bit clock pin index
◆ bclkTimerIndex
uint8_t _flexio_i2s_type::bclkTimerIndex
Bit clock timer index
◆ flexioBase
FLEXIO_Type* _flexio_i2s_type::flexioBase
FlexIO base pointer
◆ fsPinIndex
uint8_t _flexio_i2s_type::fsPinIndex
Frame sync pin index
◆ fsTimerIndex
uint8_t _flexio_i2s_type::fsTimerIndex
Frame sync timer index
◆ rxPinIndex
uint8_t _flexio_i2s_type::rxPinIndex
Rx data pin index
◆ rxShifterIndex
uint8_t _flexio_i2s_type::rxShifterIndex
Rx data shifter index
◆ txPinIndex
uint8_t _flexio_i2s_type::txPinIndex
Tx data pin index in FlexIO pins
◆ txShifterIndex
uint8_t _flexio_i2s_type::txShifterIndex
Tx data shifter index
