RTEMS 6.1
Flexio_i2s
struct  _flexio_i2s_type
 Define FlexIO I2S access structure typedef. More...
struct  _flexio_i2s_config
 FlexIO I2S configure structure. More...
struct  _flexio_i2s_format
 FlexIO I2S audio format, FlexIO I2S only support the same format in Tx and Rx. More...
struct  _flexio_i2s_transfer
 Define FlexIO I2S transfer structure. More...
struct  _flexio_i2s_handle
 Define FlexIO I2S handle structure. More...
Driver version
enum  {
  kStatus_FLEXIO_I2S_Idle = MAKE_STATUS(kStatusGroup_FLEXIO_I2S, 0) , kStatus_FLEXIO_I2S_TxBusy = MAKE_STATUS(kStatusGroup_FLEXIO_I2S, 1) , kStatus_FLEXIO_I2S_RxBusy = MAKE_STATUS(kStatusGroup_FLEXIO_I2S, 2) , kStatus_FLEXIO_I2S_Error = MAKE_STATUS(kStatusGroup_FLEXIO_I2S, 3) ,
  kStatus_FLEXIO_I2S_QueueFull = MAKE_STATUS(kStatusGroup_FLEXIO_I2S, 4) , kStatus_FLEXIO_I2S_Timeout
 FlexIO I2S transfer status. More...
enum  _flexio_i2s_master_slave { kFLEXIO_I2S_Master = 0x0U , kFLEXIO_I2S_Slave = 0x1U }
 Master or slave mode. More...
enum  { kFLEXIO_I2S_TxDataRegEmptyInterruptEnable = 0x1U , kFLEXIO_I2S_RxDataRegFullInterruptEnable = 0x2U }
 _flexio_i2s_interrupt_enable Define FlexIO FlexIO I2S interrupt mask. More...
enum  { kFLEXIO_I2S_TxDataRegEmptyFlag = 0x1U , kFLEXIO_I2S_RxDataRegFullFlag = 0x2U }
 _flexio_i2s_status_flags Define FlexIO FlexIO I2S status mask. More...
enum  _flexio_i2s_sample_rate {
  kFLEXIO_I2S_SampleRate8KHz = 8000U , kFLEXIO_I2S_SampleRate11025Hz = 11025U , kFLEXIO_I2S_SampleRate12KHz = 12000U , kFLEXIO_I2S_SampleRate16KHz = 16000U ,
  kFLEXIO_I2S_SampleRate22050Hz = 22050U , kFLEXIO_I2S_SampleRate24KHz = 24000U , kFLEXIO_I2S_SampleRate32KHz = 32000U , kFLEXIO_I2S_SampleRate44100Hz = 44100U ,
  kFLEXIO_I2S_SampleRate48KHz = 48000U , kFLEXIO_I2S_SampleRate96KHz = 96000U
 Audio sample rate. More...
enum  _flexio_i2s_word_width { kFLEXIO_I2S_WordWidth8bits = 8U , kFLEXIO_I2S_WordWidth16bits = 16U , kFLEXIO_I2S_WordWidth24bits = 24U , kFLEXIO_I2S_WordWidth32bits = 32U }
 Audio word width. More...
typedef struct _flexio_i2s_type FLEXIO_I2S_Type
typedef enum _flexio_i2s_master_slave flexio_i2s_master_slave_t
typedef struct _flexio_i2s_config flexio_i2s_config_t
typedef struct _flexio_i2s_format flexio_i2s_format_t
typedef enum _flexio_i2s_sample_rate flexio_i2s_sample_rate_t
 Audio sample rate.
typedef enum _flexio_i2s_word_width flexio_i2s_word_width_t
 Audio word width.
typedef struct _flexio_i2s_transfer flexio_i2s_transfer_t
typedef struct _flexio_i2s_handle flexio_i2s_handle_t
typedef void(* flexio_i2s_callback_t) (FLEXIO_I2S_Type *base, flexio_i2s_handle_t *handle, status_t status, void *userData)
 FlexIO I2S xfer callback prototype.
#define FSL_FLEXIO_I2S_DRIVER_VERSION   (MAKE_VERSION(2, 2, 0))
 FlexIO I2S driver version 2.2.0.
#define I2S_RETRY_TIMES   0U /* Define to zero means keep waiting until the flag is assert/deassert. */
 Retry times for waiting flag.
#define FLEXIO_I2S_XFER_QUEUE_SIZE   (4U)
 FlexIO I2S transfer queue size, user can refine it according to use case.
Initialization and deinitialization
void FLEXIO_I2S_Init (FLEXIO_I2S_Type *base, const flexio_i2s_config_t *config)
 Initializes the FlexIO I2S.
void FLEXIO_I2S_GetDefaultConfig (flexio_i2s_config_t *config)
 Sets the FlexIO I2S configuration structure to default values.
void FLEXIO_I2S_Deinit (FLEXIO_I2S_Type *base)
 De-initializes the FlexIO I2S.
Status
uint32_t FLEXIO_I2S_GetStatusFlags (FLEXIO_I2S_Type *base)
 Gets the FlexIO I2S status flags.
Interrupts
void FLEXIO_I2S_EnableInterrupts (FLEXIO_I2S_Type *base, uint32_t mask)
 Enables the FlexIO I2S interrupt.
void FLEXIO_I2S_DisableInterrupts (FLEXIO_I2S_Type *base, uint32_t mask)
 Disables the FlexIO I2S interrupt.
Bus Operations
void FLEXIO_I2S_MasterSetFormat (FLEXIO_I2S_Type *base, flexio_i2s_format_t *format, uint32_t srcClock_Hz)
 Configures the FlexIO I2S audio format in master mode.
void FLEXIO_I2S_SlaveSetFormat (FLEXIO_I2S_Type *base, flexio_i2s_format_t *format)
 Configures the FlexIO I2S audio format in slave mode.
status_t FLEXIO_I2S_WriteBlocking (FLEXIO_I2S_Type *base, uint8_t bitWidth, uint8_t *txData, size_t size)
 Sends data using a blocking method.
status_t FLEXIO_I2S_ReadBlocking (FLEXIO_I2S_Type *base, uint8_t bitWidth, uint8_t *rxData, size_t size)
 Receives a piece of data using a blocking method.
Transactional
void FLEXIO_I2S_TransferTxCreateHandle (FLEXIO_I2S_Type *base, flexio_i2s_handle_t *handle, flexio_i2s_callback_t callback, void *userData)
 Initializes the FlexIO I2S handle.
void FLEXIO_I2S_TransferSetFormat (FLEXIO_I2S_Type *base, flexio_i2s_handle_t *handle, flexio_i2s_format_t *format, uint32_t srcClock_Hz)
 Configures the FlexIO I2S audio format.
void FLEXIO_I2S_TransferRxCreateHandle (FLEXIO_I2S_Type *base, flexio_i2s_handle_t *handle, flexio_i2s_callback_t callback, void *userData)
 Initializes the FlexIO I2S receive handle.
status_t FLEXIO_I2S_TransferSendNonBlocking (FLEXIO_I2S_Type *base, flexio_i2s_handle_t *handle, flexio_i2s_transfer_t *xfer)
 Performs an interrupt non-blocking send transfer on FlexIO I2S.
status_t FLEXIO_I2S_TransferReceiveNonBlocking (FLEXIO_I2S_Type *base, flexio_i2s_handle_t *handle, flexio_i2s_transfer_t *xfer)
 Performs an interrupt non-blocking receive transfer on FlexIO I2S.
void FLEXIO_I2S_TransferAbortSend (FLEXIO_I2S_Type *base, flexio_i2s_handle_t *handle)
 Aborts the current send.
void FLEXIO_I2S_TransferAbortReceive (FLEXIO_I2S_Type *base, flexio_i2s_handle_t *handle)
 Aborts the current receive.
status_t FLEXIO_I2S_TransferGetSendCount (FLEXIO_I2S_Type *base, flexio_i2s_handle_t *handle, size_t *count)
 Gets the remaining bytes to be sent.
status_t FLEXIO_I2S_TransferGetReceiveCount (FLEXIO_I2S_Type *base, flexio_i2s_handle_t *handle, size_t *count)
 Gets the remaining bytes to be received.
void FLEXIO_I2S_TransferTxHandleIRQ (void *i2sBase, void *i2sHandle)
 Tx interrupt handler.
void FLEXIO_I2S_TransferRxHandleIRQ (void *i2sBase, void *i2sHandle)
 Rx interrupt handler.
◆ anonymous enum
anonymous enum
FlexIO I2S is in idle state
FlexIO I2S Tx is busy
FlexIO I2S error occurred
FlexIO I2S transfer queue is full.
FlexIO I2S timeout polling status flags.
◆ anonymous enum
anonymous enum
Transmit buffer empty interrupt enable.
Receive buffer full interrupt enable.
◆ anonymous enum
anonymous enum
Transmit buffer empty flag.
Receive buffer full flag.
◆ _flexio_i2s_master_slave
kFLEXIO_I2S_Master
Master mode
kFLEXIO_I2S_Slave
Slave mode
◆ _flexio_i2s_sample_rate
Audio sample rate.
Sample rate 8000Hz
Sample rate 11025Hz
Sample rate 12000Hz
Sample rate 16000Hz
Sample rate 22050Hz
Sample rate 24000Hz
Sample rate 32000Hz
Sample rate 44100Hz
Sample rate 48000Hz
Sample rate 96000Hz
◆ _flexio_i2s_word_width
Audio word width.
Audio data width 8 bits
Audio data width 16 bits
Audio data width 24 bits
Audio data width 32 bits
◆ FLEXIO_I2S_Deinit()
void FLEXIO_I2S_Deinit ( FLEXIO_I2S_Type base)
Calling this API resets the FlexIO I2S shifter and timer config. After calling this API, call the FLEXO_I2S_Init to use the FlexIO I2S module.
Parameters
baseFlexIO I2S base pointer
brief De-initializes the FlexIO I2S.
param base FlexIO I2S base pointer
◆ FLEXIO_I2S_DisableInterrupts()
void FLEXIO_I2S_DisableInterrupts ( FLEXIO_I2S_Type base,
uint32_t  mask
This function enables the FlexIO UART interrupt.
Parameters
basepointer to FLEXIO_I2S_Type structure
maskinterrupt source
brief Disables the FlexIO I2S interrupt.
param base pointer to FLEXIO_I2S_Type structure param mask interrupt source
◆ FLEXIO_I2S_EnableInterrupts()
void FLEXIO_I2S_EnableInterrupts ( FLEXIO_I2S_Type base,
uint32_t  mask
Parameters
basePointer to FLEXIO_I2S_Type structure
brief Enables the FlexIO I2S interrupt.
param base Pointer to FLEXIO_I2S_Type structure param mask interrupt source
◆ FLEXIO_I2S_GetDefaultConfig()
void FLEXIO_I2S_GetDefaultConfig ( flexio_i2s_config_t config)
The purpose of this API is to get the configuration structure initialized for use in FLEXIO_I2S_Init(). Users may use the initialized structure unchanged in FLEXIO_I2S_Init() or modify some fields of the structure before calling FLEXIO_I2S_Init().
Parameters
configpointer to master configuration structure
brief Sets the FlexIO I2S configuration structure to default values.
param config pointer to master configuration structure
◆ FLEXIO_I2S_GetStatusFlags()
uint32_t FLEXIO_I2S_GetStatusFlags ( FLEXIO_I2S_Type base)
Parameters
Returns
Status flag, which are ORed by the enumerators in the _flexio_i2s_status_flags.
brief Gets the FlexIO I2S status flags.
param base Pointer to FLEXIO_I2S_Type structure return Status flag, which are ORed by the enumerators in the _flexio_i2s_status_flags.
◆ FLEXIO_I2S_Init()
void FLEXIO_I2S_Init ( FLEXIO_I2S_Type base,
const flexio_i2s_config_t config
This API configures FlexIO pins and shifter to I2S and configures the FlexIO I2S with a configuration structure. The configuration structure can be filled by the user, or be set with default values by FLEXIO_I2S_GetDefaultConfig().
Note
This API should be called at the beginning of the application to use the FlexIO I2S driver. Otherwise, any access to the FlexIO I2S module can cause hard fault because the clock is not enabled.
Parameters
configFlexIO I2S configure structure.
brief Initializes the FlexIO I2S.
note This API should be called at the beginning of the application to use the FlexIO I2S driver. Otherwise, any access to the FlexIO I2S module can cause hard fault because the clock is not enabled.
param base FlexIO I2S base pointer param config FlexIO I2S configure structure.
◆ FLEXIO_I2S_MasterSetFormat()
void FLEXIO_I2S_MasterSetFormat ( FLEXIO_I2S_Type base,
flexio_i2s_format_t format,
Audio format can be changed in run-time of FlexIO I2S. This function configures the sample rate and audio data format to be transferred.
Parameters
formatPointer to FlexIO I2S audio data format structure.
srcClock_HzI2S master clock source frequency in Hz.
brief Configures the FlexIO I2S audio format in master mode.
param base Pointer to FLEXIO_I2S_Type structure param format Pointer to FlexIO I2S audio data format structure. param srcClock_Hz I2S master clock source frequency in Hz.
◆ FLEXIO_I2S_ReadBlocking()
status_t FLEXIO_I2S_ReadBlocking ( FLEXIO_I2S_Type base,
uint8_t  bitWidth,
uint8_t *  rxData,
size_t  size
Note
This function blocks via polling until data is ready to be sent.
Parameters
bitWidthHow many bits in a audio word, usually 8/16/24/32 bits.
rxDataPointer to the data to be read.
sizeBytes to be read.
Return values
kStatus_SuccessSuccessfully read data.
kStatus_FLEXIO_I2C_TimeoutTimeout polling status flags.
brief Receives a piece of data using a blocking method.
note This function blocks via polling until data is ready to be sent.
param base FlexIO I2S base pointer param bitWidth How many bits in a audio word, usually 8/16/24/32 bits. param rxData Pointer to the data to be read. param size Bytes to be read. retval kStatus_Success Successfully read data. retval kStatus_FLEXIO_I2C_Timeout Timeout polling status flags.
◆ FLEXIO_I2S_SlaveSetFormat()
void FLEXIO_I2S_SlaveSetFormat ( FLEXIO_I2S_Type base,
Parameters
brief Configures the FlexIO I2S audio format in slave mode.
◆ FLEXIO_I2S_TransferAbortReceive()
void FLEXIO_I2S_TransferAbortReceive ( FLEXIO_I2S_Type base,
flexio_i2s_handle_t handle
Note
This API can be called at any time when interrupt non-blocking transfer initiates to abort the transfer in a early time.
Parameters
basePointer to FLEXIO_I2S_Type structure.
handlePointer to flexio_i2s_handle_t structure which stores the transfer state
brief Aborts the current receive.
note This API can be called at any time when interrupt non-blocking transfer initiates to abort the transfer in a early time.
param base Pointer to FLEXIO_I2S_Type structure. param handle Pointer to flexio_i2s_handle_t structure which stores the transfer state
◆ FLEXIO_I2S_TransferAbortSend()
void FLEXIO_I2S_TransferAbortSend ( FLEXIO_I2S_Type base,
Note
Parameters
brief Aborts the current send.
◆ FLEXIO_I2S_TransferGetReceiveCount()
status_t FLEXIO_I2S_TransferGetReceiveCount ( FLEXIO_I2S_Type base,
flexio_i2s_handle_t handle,
size_t *  count
Parameters
countBytes recieved.
Returns
count Bytes received.
Return values
kStatus_SuccessSucceed get the transfer count.
kStatus_NoTransferInProgressThere is not a non-blocking transaction currently in progress.
brief Gets the remaining bytes to be received.
param base Pointer to FLEXIO_I2S_Type structure. param handle Pointer to flexio_i2s_handle_t structure which stores the transfer state return count Bytes received. retval kStatus_Success Succeed get the transfer count. retval kStatus_NoTransferInProgress There is not a non-blocking transaction currently in progress.
◆ FLEXIO_I2S_TransferGetSendCount()
status_t FLEXIO_I2S_TransferGetSendCount ( FLEXIO_I2S_Type base,
size_t *  count
Parameters
countBytes sent.
Return values
brief Gets the remaining bytes to be sent.
param base Pointer to FLEXIO_I2S_Type structure. param handle Pointer to flexio_i2s_handle_t structure which stores the transfer state param count Bytes sent. retval kStatus_Success Succeed get the transfer count. retval kStatus_NoTransferInProgress There is not a non-blocking transaction currently in progress.
◆ FLEXIO_I2S_TransferReceiveNonBlocking()
status_t FLEXIO_I2S_TransferReceiveNonBlocking ( FLEXIO_I2S_Type base,
flexio_i2s_transfer_t xfer
Note
The API returns immediately after transfer initiates. Call FLEXIO_I2S_GetRemainingBytes to poll the transfer status to check whether the transfer is finished. If the return status is 0, the transfer is finished.
Parameters
xferPointer to flexio_i2s_transfer_t structure
Return values
kStatus_SuccessSuccessfully start the data receive.
kStatus_FLEXIO_I2S_RxBusyPrevious receive still not finished.
kStatus_InvalidArgumentThe input parameter is invalid.
brief Performs an interrupt non-blocking receive transfer on FlexIO I2S.
note The API returns immediately after transfer initiates. Call FLEXIO_I2S_GetRemainingBytes to poll the transfer status to check whether the transfer is finished. If the return status is 0, the transfer is finished.
param base Pointer to FLEXIO_I2S_Type structure. param handle Pointer to flexio_i2s_handle_t structure which stores the transfer state param xfer Pointer to flexio_i2s_transfer_t structure retval kStatus_Success Successfully start the data receive. retval kStatus_FLEXIO_I2S_RxBusy Previous receive still not finished. retval kStatus_InvalidArgument The input parameter is invalid.
◆ FLEXIO_I2S_TransferRxCreateHandle()
void FLEXIO_I2S_TransferRxCreateHandle ( FLEXIO_I2S_Type base,
void *  userData
This function initializes the FlexIO I2S handle which can be used for other FlexIO I2S transactional APIs. Call this API once to get the initialized handle.
Parameters
handlePointer to flexio_i2s_handle_t structure to store the transfer state.
callbackFlexIO I2S callback function, which is called while finished a block.
userDataUser parameter for the FlexIO I2S callback.
brief Initializes the FlexIO I2S receive handle.
param base Pointer to FLEXIO_I2S_Type structure. param handle Pointer to flexio_i2s_handle_t structure to store the transfer state. param callback FlexIO I2S callback function, which is called while finished a block. param userData User parameter for the FlexIO I2S callback.
◆ FLEXIO_I2S_TransferRxHandleIRQ()
void FLEXIO_I2S_TransferRxHandleIRQ ( void *  i2sBase,
void *  i2sHandle
Parameters
i2sBasePointer to FLEXIO_I2S_Type structure.
i2sHandlePointer to flexio_i2s_handle_t structure.
brief Rx interrupt handler.
param i2sBase Pointer to FLEXIO_I2S_Type structure. param i2sHandle Pointer to flexio_i2s_handle_t structure.
◆ FLEXIO_I2S_TransferSendNonBlocking()
status_t FLEXIO_I2S_TransferSendNonBlocking ( FLEXIO_I2S_Type base,
Note
The API returns immediately after transfer initiates. Call FLEXIO_I2S_GetRemainingBytes to poll the transfer status and check whether the transfer is finished. If the return status is 0, the transfer is finished.
Parameters
Return values
kStatus_SuccessSuccessfully start the data transmission.
kStatus_FLEXIO_I2S_TxBusyPrevious transmission still not finished, data not all written to TX register yet.
brief Performs an interrupt non-blocking send transfer on FlexIO I2S.
note The API returns immediately after transfer initiates. Call FLEXIO_I2S_GetRemainingBytes to poll the transfer status and check whether the transfer is finished. If the return status is 0, the transfer is finished.
param base Pointer to FLEXIO_I2S_Type structure. param handle Pointer to flexio_i2s_handle_t structure which stores the transfer state param xfer Pointer to flexio_i2s_transfer_t structure retval kStatus_Success Successfully start the data transmission. retval kStatus_FLEXIO_I2S_TxBusy Previous transmission still not finished, data not all written to TX register yet. retval kStatus_InvalidArgument The input parameter is invalid.
◆ FLEXIO_I2S_TransferSetFormat()
void FLEXIO_I2S_TransferSetFormat ( FLEXIO_I2S_Type base,
Audio format can be changed at run-time of FlexIO I2S. This function configures the sample rate and audio data format to be transferred.
Parameters
handleFlexIO I2S handle pointer.
formatPointer to audio data format structure.
srcClock_HzFlexIO I2S bit clock source frequency in Hz. This parameter should be 0 while in slave mode.
brief Configures the FlexIO I2S audio format.
param base Pointer to FLEXIO_I2S_Type structure. param handle FlexIO I2S handle pointer. param format Pointer to audio data format structure. param srcClock_Hz FlexIO I2S bit clock source frequency in Hz. This parameter should be 0 while in slave mode.
◆ FLEXIO_I2S_TransferTxCreateHandle()
void FLEXIO_I2S_TransferTxCreateHandle ( FLEXIO_I2S_Type base,
void *  userData
Parameters
brief Initializes the FlexIO I2S handle.
param base Pointer to FLEXIO_I2S_Type structure param handle Pointer to flexio_i2s_handle_t structure to store the transfer state. param callback FlexIO I2S callback function, which is called while finished a block. param userData User parameter for the FlexIO I2S callback.
◆ FLEXIO_I2S_TransferTxHandleIRQ()
void FLEXIO_I2S_TransferTxHandleIRQ ( void *  i2sBase,
void *  i2sHandle
Parameters
brief Tx interrupt handler.
◆ FLEXIO_I2S_WriteBlocking()
status_t FLEXIO_I2S_WriteBlocking ( FLEXIO_I2S_Type base,
uint8_t  bitWidth,
uint8_t *  txData,
size_t  size
Note
Parameters
baseFlexIO I2S base pointer.
txDataPointer to the data to be written.
sizeBytes to be written.
Return values
kStatus_SuccessSuccessfully write data.
brief Sends data using a blocking method.
param base FlexIO I2S base pointer. param bitWidth How many bits in a audio word, usually 8/16/24/32 bits. param txData Pointer to the data to be written. param size Bytes to be written. retval kStatus_Success Successfully write data. retval kStatus_FLEXIO_I2C_Timeout Timeout polling status flags.
