RTEMS 6.1
__I2S_HandleTypeDef Struct Reference
I2S handle Structure definition. More...
#include <stm32h7xx_hal_i2s.h>
SPI_TypeDefInstance
I2S_InitTypeDef Init
const uint16_t * pTxBuffPtr
__IO uint16_t TxXferSize
__IO uint16_t TxXferCount
uint16_t * pRxBuffPtr
__IO uint16_t RxXferSize
__IO uint16_t RxXferCount
void(* RxISR )(struct __I2S_HandleTypeDef *hi2s)
void(* TxISR )(struct __I2S_HandleTypeDef *hi2s)
DMA_HandleTypeDefhdmatx
DMA_HandleTypeDefhdmarx
__IO HAL_LockTypeDef Lock
__IO HAL_I2S_StateTypeDef State
__IO uint32_t ErrorCode
Field Documentation
◆ ErrorCode
__IO uint32_t __I2S_HandleTypeDef::ErrorCode
I2S Error code This parameter can be a value of I2S Error
◆ hdmarx
DMA_HandleTypeDef* __I2S_HandleTypeDef::hdmarx
I2S Rx DMA handle parameters
◆ hdmatx
DMA_HandleTypeDef* __I2S_HandleTypeDef::hdmatx
I2S Tx DMA handle parameters
◆ Init
I2S_InitTypeDef __I2S_HandleTypeDef::Init
I2S communication parameters
◆ Instance
SPI_TypeDef* __I2S_HandleTypeDef::Instance
I2S registers base address
◆ Lock
__IO HAL_LockTypeDef __I2S_HandleTypeDef::Lock
I2S locking object
◆ pRxBuffPtr
uint16_t* __I2S_HandleTypeDef::pRxBuffPtr
Pointer to I2S Rx transfer buffer
◆ pTxBuffPtr
const uint16_t* __I2S_HandleTypeDef::pTxBuffPtr
Pointer to I2S Tx transfer buffer
◆ RxISR
void(* __I2S_HandleTypeDef::RxISR) (struct __I2S_HandleTypeDef *hi2s)
function pointer on Rx ISR
◆ RxXferCount
__IO uint16_t __I2S_HandleTypeDef::RxXferCount
I2S Rx transfer counter (This field is initialized at the same value as transfer size at the beginning of the transfer and decremented when a sample is received NbSamplesReceived = RxBufferSize-RxBufferCount)
◆ RxXferSize
__IO uint16_t __I2S_HandleTypeDef::RxXferSize
I2S Rx transfer size
◆ State
__IO HAL_I2S_StateTypeDef __I2S_HandleTypeDef::State
I2S communication state
◆ TxISR
void(* __I2S_HandleTypeDef::TxISR) (struct __I2S_HandleTypeDef *hi2s)
function pointer on Tx ISR
◆ TxXferCount
__IO uint16_t __I2S_HandleTypeDef::TxXferCount
I2S Tx transfer Counter
◆ TxXferSize
__IO uint16_t __I2S_HandleTypeDef::TxXferSize
I2S Tx transfer size
