RTEMS 6.1
I2S_InitTypeDef Struct Reference
I2S Init structure definition. More...
#include <stm32h7xx_hal_i2s.h>
uint32_t Mode
uint32_t Standard
uint32_t DataFormat
uint32_t MCLKOutput
uint32_t AudioFreq
uint32_t CPOL
uint32_t FirstBit
uint32_t WSInversion
uint32_t Data24BitAlignment
uint32_t MasterKeepIOState
Field Documentation
◆ AudioFreq
uint32_t I2S_InitTypeDef::AudioFreq
Specifies the frequency selected for the I2S communication. This parameter can be a value of I2S Audio Frequency
◆ CPOL
uint32_t I2S_InitTypeDef::CPOL
Specifies the idle state of the I2S clock. This parameter can be a value of I2S FullDuplex Mode
◆ Data24BitAlignment
uint32_t I2S_InitTypeDef::Data24BitAlignment
Specifies the Data Padding for 24 bits data length This parameter can be a value of Data Padding 24Bit
◆ DataFormat
uint32_t I2S_InitTypeDef::DataFormat
Specifies the data format for the I2S communication. This parameter can be a value of I2S Data Format
◆ FirstBit
uint32_t I2S_InitTypeDef::FirstBit
Specifies whether data transfers start from MSB or LSB bit. This parameter can be a value of I2S MSB LSB Transmission
◆ MasterKeepIOState
uint32_t I2S_InitTypeDef::MasterKeepIOState
Control of Alternate function GPIOs state This parameter can be a value of Keep IO State
◆ MCLKOutput
uint32_t I2S_InitTypeDef::MCLKOutput
Specifies whether the I2S MCLK output is enabled or not. This parameter can be a value of I2S MCLK Output
◆ Mode
uint32_t I2S_InitTypeDef::Mode
Specifies the I2S operating mode. This parameter can be a value of I2S Mode
◆ Standard
uint32_t I2S_InitTypeDef::Standard
Specifies the standard used for the I2S communication. This parameter can be a value of I2S Standard
◆ WSInversion
uint32_t I2S_InitTypeDef::WSInversion
Control the Word Select Inversion. This parameter can be a value of I2S Word Select Inversion
