RTEMS 6.1
WWDG_InitTypeDef Struct Reference
WWDG Init structure definition. More...
#include <stm32h7xx_hal_wwdg.h>
uint32_t Prescaler
uint32_t Window
uint32_t Counter
uint32_t EWIMode
Field Documentation
◆ Counter
uint32_t WWDG_InitTypeDef::Counter
Specifies the WWDG free-running downcounter value. This parameter must be a number between Min_Data = 0x40 and Max_Data = 0x7F
◆ EWIMode
uint32_t WWDG_InitTypeDef::EWIMode
Specifies if WWDG Early Wakeup Interrupt is enable or not. This parameter can be a value of WWDG Early Wakeup Interrupt Mode
◆ Prescaler
uint32_t WWDG_InitTypeDef::Prescaler
Specifies the prescaler value of the WWDG. This parameter can be a value of WWDG Prescaler
◆ Window
uint32_t WWDG_InitTypeDef::Window
Specifies the WWDG window value to be compared to the downcounter. This parameter must be a number Min_Data = 0x40 and Max_Data = 0x7F
