RTEMS 6.1
Test context for spec:/score/tq/req/enqueue-priority-inherit test case. More...
rtems_task_priority queue_priority
 This member specifies the priority of a thread on the thread queue with an eligible scheduler equal to an eligible scheduler of the enqueueing thread.
size_t other_before
 If this member is true, then a thread those eligible schedulers are ineligible scheduler to the enqueueing task should be enqueued before a thread with an eligible scheduler equal to an eligible scheduler of the enqueueing thread.
size_t other_after
 If this member is true, then a thread those eligible schedulers are ineligible scheduler to the enqueueing task should be enqueued after a thread with an eligible scheduler equal to an eligible scheduler of the enqueueing thread.
bool vital_priority
 This this member is true, then the priorities of the enqueueing thread shall be dispensable for the owner of the thread queue.
bool vital_scheduler
 This this member is true, then the eligible scheduler of the enqueueing thread shall be dispensable for the owner of the thread queue.
rtems_task_priority owner_priority [4]
 This member contains the priorities of the thread queue owner after the enqueue.
rtems_task_priority owner_owner_priority [4]
 This member contains the priorities of the owner of the thread queue on which the thread queue owner is blocked after the enqueue.
rtems_event_set owner_obtain
 This member specifies which mutex obtain event shall be used to block the thread queue owner.
rtems_event_set owner_release
 This member specifies which mutex release event shall be used to unblock the thread queue owner.
TQContexttq_ctx
 This member contains a copy of the corresponding ScoreTqReqEnqueuePriorityInherit_Run() parameter.
struct {
   size_t   pcs [6]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   ScoreTqReqEnqueuePriorityInherit_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
