RTEMS 6.1
Files | Data Structures | Typedefs | Enumerations | Functions
spec:/score/tq/req/enqueue-priority-inherit
file  tr-tq-enqueue-priority-inherit.c
file  tr-tq-enqueue-priority-inherit.h
struct  ScoreTqReqEnqueuePriorityInherit_Entry
struct  ScoreTqReqEnqueuePriorityInherit_Context
 Test context for spec:/score/tq/req/enqueue-priority-inherit test case. More...
typedef ScoreTqReqEnqueuePriorityInherit_Context Context
enum  ScoreTqReqEnqueuePriorityInherit_Pre_Scheduler {
  ScoreTqReqEnqueuePriorityInherit_Pre_Scheduler_One , ScoreTqReqEnqueuePriorityInherit_Pre_Scheduler_Two , ScoreTqReqEnqueuePriorityInherit_Pre_Scheduler_Three , ScoreTqReqEnqueuePriorityInherit_Pre_Scheduler_More ,
  ScoreTqReqEnqueuePriorityInherit_Pre_Scheduler_NA
enum  ScoreTqReqEnqueuePriorityInherit_Pre_QueueEligible {
  ScoreTqReqEnqueuePriorityInherit_Pre_QueueEligible_None , ScoreTqReqEnqueuePriorityInherit_Pre_QueueEligible_High , ScoreTqReqEnqueuePriorityInherit_Pre_QueueEligible_Equal , ScoreTqReqEnqueuePriorityInherit_Pre_QueueEligible_Low ,
  ScoreTqReqEnqueuePriorityInherit_Pre_QueueEligible_NA
enum  ScoreTqReqEnqueuePriorityInherit_Pre_QueueIneligible {
  ScoreTqReqEnqueuePriorityInherit_Pre_QueueIneligible_None , ScoreTqReqEnqueuePriorityInherit_Pre_QueueIneligible_Only , ScoreTqReqEnqueuePriorityInherit_Pre_QueueIneligible_Before , ScoreTqReqEnqueuePriorityInherit_Pre_QueueIneligible_After ,
  ScoreTqReqEnqueuePriorityInherit_Pre_QueueIneligible_NA
enum  ScoreTqReqEnqueuePriorityInherit_Pre_PriorityForOwner { ScoreTqReqEnqueuePriorityInherit_Pre_PriorityForOwner_Vital , ScoreTqReqEnqueuePriorityInherit_Pre_PriorityForOwner_Dispensable , ScoreTqReqEnqueuePriorityInherit_Pre_PriorityForOwner_NA }
enum  ScoreTqReqEnqueuePriorityInherit_Pre_SchedulerForOwner { ScoreTqReqEnqueuePriorityInherit_Pre_SchedulerForOwner_Vital , ScoreTqReqEnqueuePriorityInherit_Pre_SchedulerForOwner_Dispensable , ScoreTqReqEnqueuePriorityInherit_Pre_SchedulerForOwner_NA }
enum  ScoreTqReqEnqueuePriorityInherit_Pre_OwnerState {
  ScoreTqReqEnqueuePriorityInherit_Pre_OwnerState_NotEnqueued , ScoreTqReqEnqueuePriorityInherit_Pre_OwnerState_FIFO , ScoreTqReqEnqueuePriorityInherit_Pre_OwnerState_Priority , ScoreTqReqEnqueuePriorityInherit_Pre_OwnerState_PriorityInherit ,
  ScoreTqReqEnqueuePriorityInherit_Pre_OwnerState_NA
enum  ScoreTqReqEnqueuePriorityInherit_Post_Position {
  ScoreTqReqEnqueuePriorityInherit_Post_Position_InitialFirst , ScoreTqReqEnqueuePriorityInherit_Post_Position_InitialLast , ScoreTqReqEnqueuePriorityInherit_Post_Position_First , ScoreTqReqEnqueuePriorityInherit_Post_Position_Second ,
  ScoreTqReqEnqueuePriorityInherit_Post_Position_FirstFirst , ScoreTqReqEnqueuePriorityInherit_Post_Position_SecondFirst , ScoreTqReqEnqueuePriorityInherit_Post_Position_FirstLast , ScoreTqReqEnqueuePriorityInherit_Post_Position_SecondLast ,
  ScoreTqReqEnqueuePriorityInherit_Post_Position_NA
enum  ScoreTqReqEnqueuePriorityInherit_Post_OwnerPriority { ScoreTqReqEnqueuePriorityInherit_Post_OwnerPriority_Raise , ScoreTqReqEnqueuePriorityInherit_Post_OwnerPriority_Nop , ScoreTqReqEnqueuePriorityInherit_Post_OwnerPriority_NA }
enum  ScoreTqReqEnqueuePriorityInherit_Post_OwnerScheduler { ScoreTqReqEnqueuePriorityInherit_Post_OwnerScheduler_NewHelper , ScoreTqReqEnqueuePriorityInherit_Post_OwnerScheduler_Nop , ScoreTqReqEnqueuePriorityInherit_Post_OwnerScheduler_NA }
enum  ScoreTqReqEnqueuePriorityInherit_Post_OwnerOwnerPriority { ScoreTqReqEnqueuePriorityInherit_Post_OwnerOwnerPriority_Raise , ScoreTqReqEnqueuePriorityInherit_Post_OwnerOwnerPriority_Nop , ScoreTqReqEnqueuePriorityInherit_Post_OwnerOwnerPriority_NA }
enum  ScoreTqReqEnqueuePriorityInherit_Post_OwnerOwnerScheduler { ScoreTqReqEnqueuePriorityInherit_Post_OwnerOwnerScheduler_NewHelper , ScoreTqReqEnqueuePriorityInherit_Post_OwnerOwnerScheduler_Nop , ScoreTqReqEnqueuePriorityInherit_Post_OwnerOwnerScheduler_NA }
void ScoreTqReqEnqueuePriorityInherit_Run (TQContext *tq_ctx)
 Runs the parameterized test case.
◆ ScoreTqReqEnqueuePriorityInherit_Run()
void ScoreTqReqEnqueuePriorityInherit_Run ( TQContext tq_ctx)
Parameters
[in,out]tq_ctxis the thread queue context.
