RTEMS 6.1
Test context for spec:/rtems/signal/val/signal-constant test case. More...
Data Fields | |
| rtems_signal_set | signal_set |
| This member contains the caught signal set. | |
| rtems_signal_set | signal |
| This member contains a copy of the corresponding RtemsSignalValSignalConstant_Run() parameter. | |
| int | number |
