Tests a signal constant of the Signal Manager using the signal set of the executing task.
More...
This test case performs the following actions:
- Validate the signal constant.
- Check that the signal constant is equal to the integer representation of the signal in the signal set.
- Validate the signal delivery.
- Check that the caught signal set represents exactly the sent signal.
◆ RtemsSignalValSignalConstant_Run()
Runs the parameterized test case.
- Parameters
| signal | is the signal constant. |
| number | is the signal number. |
