RTEMS 6.1
POSIX_Shm_Object_operations Struct Reference
Operations on POSIX Shared Memory Objects. More...
#include <shm.h>
int(* object_create )(POSIX_Shm_Object *shm_obj, size_t size)
 Allocates a new shm_obj with initial size.
int(* object_resize )(POSIX_Shm_Object *shm_obj, size_t size)
 Changes the shm_obj size to size.
int(* object_delete )(POSIX_Shm_Object *shm_obj)
 Deletes the shm_obj.
int(* object_read )(POSIX_Shm_Object *shm_obj, void *buf, size_t count)
 Copies up to @count bytes of the shm_obj data into buf.
void *(* object_mmap )(POSIX_Shm_Object *shm_obj, size_t len, int prot, off_t off)
 Maps a shared memory object.
Field Documentation
◆ object_create
int(* POSIX_Shm_Object_operations::object_create) (POSIX_Shm_Object *shm_obj, size_t size)
New shared memory is initialized to zeroes.
Returns 0 for success.
◆ object_delete
int(* POSIX_Shm_Object_operations::object_delete) (POSIX_Shm_Object *shm_obj)
Zeroes out the memory.
◆ object_mmap
void *(* POSIX_Shm_Object_operations::object_mmap) (POSIX_Shm_Object *shm_obj, size_t len, int prot, off_t off)
Establishes a memory mapping between the shared memory object and the caller.
Returns the mapped address of the object.
◆ object_read
int(* POSIX_Shm_Object_operations::object_read) (POSIX_Shm_Object *shm_obj, void *buf, size_t count)
Returns the number of bytes read (copied) into buf.
◆ object_resize
int(* POSIX_Shm_Object_operations::object_resize) (POSIX_Shm_Object *shm_obj, size_t size)
Zeroes out the portion of the shared memory object that shrinks or grows.
