int | _POSIX_Shm_Object_create_from_workspace (POSIX_Shm_Object *shm_obj, size_t size) |
| | object_create operation for shm objects stored in RTEMS Workspace.
int | _POSIX_Shm_Object_delete_from_workspace (POSIX_Shm_Object *shm_obj) |
| | object_delete operation for shm objects stored in RTEMS Workspace.
int | _POSIX_Shm_Object_resize_from_workspace (POSIX_Shm_Object *shm_obj, size_t size) |
| | object_resize operation for shm objects stored in RTEMS Workspace.
int | _POSIX_Shm_Object_read_from_workspace (POSIX_Shm_Object *shm_obj, void *buf, size_t count) |
| | object_read operation for shm objects stored in RTEMS Workspace.
void * | _POSIX_Shm_Object_mmap_from_workspace (POSIX_Shm_Object *shm_obj, size_t len, int prot, off_t off) |
| | object_mmap operation for shm objects stored in RTEMS Workspace.
int | _POSIX_Shm_Object_create_from_heap (POSIX_Shm_Object *shm_obj, size_t size) |
| | object_create operation for shm objects stored in C program heap.
int | _POSIX_Shm_Object_delete_from_heap (POSIX_Shm_Object *shm_obj) |
| | object_delete operation for shm objects stored in C program heap.
int | _POSIX_Shm_Object_resize_from_heap (POSIX_Shm_Object *shm_obj, size_t size) |
| | object_resize operation for shm objects stored in C program heap.
int | _POSIX_Shm_Object_read_from_heap (POSIX_Shm_Object *shm_obj, void *buf, size_t count) |
| | object_read operation for shm objects stored in C program heap.
void * | _POSIX_Shm_Object_mmap_from_heap (POSIX_Shm_Object *shm_obj, size_t len, int prot, off_t off) |
| | object_mmap operation for shm objects stored in C program heap.
Internal implementation support for POSIX shared memory.
