RTEMS 6.1
NOR handle Structure definition. More...
#include <stm32h7xx_hal_nor.h>
Data Fields | |
| FMC_NORSRAM_TypeDef * | Instance |
| FMC_NORSRAM_EXTENDED_TypeDef * | Extended |
| FMC_NORSRAM_InitTypeDef | Init |
| HAL_LockTypeDef | Lock |
| __IO HAL_NOR_StateTypeDef | State |
| uint32_t | CommandSet |
| uint32_t NOR_HandleTypeDef::CommandSet |
NOR algorithm command set and control
| FMC_NORSRAM_EXTENDED_TypeDef* NOR_HandleTypeDef::Extended |
Extended mode register base address
| FMC_NORSRAM_InitTypeDef NOR_HandleTypeDef::Init |
NOR device control configuration parameters
| FMC_NORSRAM_TypeDef* NOR_HandleTypeDef::Instance |
Register base address
| HAL_LockTypeDef NOR_HandleTypeDef::Lock |
NOR locking object
| __IO HAL_NOR_StateTypeDef NOR_HandleTypeDef::State |
NOR device access state
