◆ extra_mpci_receive_server_stack
| uint32_t MPCI_Configuration::extra_mpci_receive_server_stack |
The MPCI Receive server is assumed to have a stack of at least minimum stack size. This field specifies the amount of extra stack this task will be given in bytes.
◆ maximum_global_objects
| uint32_t MPCI_Configuration::maximum_global_objects |
This is the maximum number of global objects.
◆ maximum_nodes
| uint32_t MPCI_Configuration::maximum_nodes |
This is the maximum number of nodes in system.
◆ maximum_proxies
| uint32_t MPCI_Configuration::maximum_proxies |
This is the maximum number of proxies.
◆ node
| uint32_t MPCI_Configuration::node |
This is the local node number.
◆ User_mpci_table
This is a pointer to User/BSP provided MPCI Table.
- cpukit/include/rtems/score/mpci.h
