RTEMS 6.1
Files | Data Structures | Macros | Typedefs | Enumerations | Functions | Variables
MPCI Handler
This group contains the MPCI Handler implementation. More...
file  mpci.h
 This header file provides interfaces of the MPCI Handler which are used by the implementation and the Application Configuration.
file  mpciimpl.h
 This header file provides interfaces of the MPCI Handler which are only used by the implementation.
file  mpci.c
 This source file contains the definition of _System_state_Is_multiprocessing, _MPCI_Semaphore, _MPCI_Remote_blocked_threads, _MPCI_table, _MPCI_Receive_server_tcb, _MPCI_Packet_processors and the implementation of _MPCI_Register_packet_processor(), _MPCI_Get_packet(), _MPCI_Send_process_packet(), _MPCI_Send_request_packet(), _MPCI_Send_response_packet(), _MPCI_Receive_packet(), _MPCI_Process_response(), _MPCI_Receive_server(), _MPCI_Announce(), _MPCI_Internal_packets_Send_process_packet(), _MPCI_Internal_packets_Process_packet(), _MPCI_Internal_packets_Get_packet(), and the MPCI Handler system initialization.
file  mpcidefault.c
 This source file contains a definition of _Objects_MP_Controls, _Thread_MP_Proxies, and _MPCI_Receive_server_stack for an application configuration with only the local MPCI node and no MP objects.
struct  MPCI_Control
struct  MPCI_Configuration
struct  MPCI_Internal_packet
#define MPCI_ALL_NODES   0
#define MPCI_DEFAULT_TIMEOUT   0xFFFFFFFF
typedef void MPCI_Entry
typedef MPCI_Entry(* MPCI_initialization_entry) (void)
typedef MPCI_Entry(* MPCI_get_packet_entry) (MP_packet_Prefix **)
typedef MPCI_Entry(* MPCI_return_packet_entry) (MP_packet_Prefix *)
typedef MPCI_Entry(* MPCI_send_entry) (uint32_t, MP_packet_Prefix *)
typedef MPCI_Entry(* MPCI_receive_entry) (MP_packet_Prefix **)
typedef void(* MPCI_Packet_processor) (MP_packet_Prefix *)
enum  MPCI_Internal_Remote_operations { MPCI_PACKETS_SYSTEM_VERIFY = 0 }
void _MPCI_Register_packet_processor (MP_packet_Classes the_class, MPCI_Packet_processor the_packet_processor)
 Registers the MPCI packet processor for the designated object class.
MP_packet_Prefix_MPCI_Get_packet (void)
 Obtains a packet by invoking the user provided MPCI get packet callout.
void _MPCI_Return_packet (MP_packet_Prefix *the_packet)
 Deallocates a packet.
void _MPCI_Send_process_packet (uint32_t destination, MP_packet_Prefix *the_packet)
 Sends a process packet.
Status_Control _MPCI_Send_request_packet (uint32_t destination, MP_packet_Prefix *the_packet, States_Control extra_state)
 Sends a request packet.
void _MPCI_Send_response_packet (uint32_t destination, MP_packet_Prefix *the_packet)
 Sends a response packet.
MP_packet_Prefix_MPCI_Receive_packet (void)
 Receives a packet.
Thread_Control_MPCI_Process_response (MP_packet_Prefix *the_packet)
 Passes a packet to the thread.
void _MPCI_Receive_server (Thread_Entry_numeric_type ignored)
 Receives and processes all packets.
void _MPCI_Announce (void)
 Announces the availability of a packet.
void _MPCI_Internal_packets_Send_process_packet (MPCI_Internal_Remote_operations operation)
 Performs a process on another node.
void _MPCI_Internal_packets_Process_packet (MP_packet_Prefix *the_packet_prefix)
 Performs requested action from another node.
MPCI_Internal_packet_MPCI_Internal_packets_Get_packet (void)
 Obtains an internal thread.
const MPCI_Configuration _MPCI_Configuration
 The MPCI configuration.
char _MPCI_Receive_server_stack []
 The MPCI receive server stack.
Thread_queue_Control _MPCI_Remote_blocked_threads
MPCI_Control_MPCI_table
Thread_Control_MPCI_Receive_server_tcb
 Pointer to MP thread control block.
MPCI_Packet_processor _MPCI_Packet_processors [MP_PACKET_CLASSES_LAST+1]
The MPCI Handler encapsulates functionality which is related to the generation, receipt, and processing of remote operations in a multiprocessor system. This handler contains the message passing support for making remote service calls as well as the server thread which processes requests from remote nodes.
◆ MPCI_ALL_NODES
The following defines the node number used when a broadcast is desired.
◆ MPCI_DEFAULT_TIMEOUT
For packets associated with requests that don't already have a timeout, use the one specified by this MPCI driver. The value specified by the MPCI driver sets an upper limit on how long a remote request should take to complete.
Typedef Documentation
◆ MPCI_Entry
This type is returned by all user provided MPCI routines.
◆ MPCI_get_packet_entry
This type defines the prototype for the get packet entry point in an Multiprocessor Communications Interface. The single parameter will point to the packet allocated.
◆ MPCI_initialization_entry
This type defines the prototype for the initization entry point in an Multiprocessor Communications Interface.
◆ MPCI_Packet_processor
The following defines the type for packet processing routines invoked by the MPCI Receive server.
◆ MPCI_receive_entry
This type defines the prototype for the receive packet entry point in an Multiprocessor Communications Interface. The single parameter will point to a packet allocated and filled in by the receive packet handler. The caller will block until a packet is received.
◆ MPCI_return_packet_entry
This type defines the prototype for the return packet entry point in an Multiprocessor Communications Interface. The single parameter will point to a packet previously allocated by the get packet MPCI entry.
◆ MPCI_send_entry
This type defines the prototype for send get packet entry point in an Multiprocessor Communications Interface. The single parameter will point to a packet previously allocated by the get packet entry point that has been filled in by the caller.
◆ MPCI_Internal_Remote_operations
The following enumerated type defines the list of internal MP operations.
◆ _MPCI_Announce()
void _MPCI_Announce ( void  )
This routine informs RTEMS of the availability of an MPCI packet.
◆ _MPCI_Get_packet()
MP_packet_Prefix * _MPCI_Get_packet ( void  )
Returns
Returns a pointer to a MPCI packet which can be filled in by the caller and used to perform a subsequent remote operation.
◆ _MPCI_Internal_packets_Get_packet()
MPCI_Internal_packet * _MPCI_Internal_packets_Get_packet ( void  )
_MPCI_Internal_packets_Send_object_was_deleted
This routine is invoked indirectly by the thread queue when a proxy has been removed from the thread queue and the remote node must be informed of this.
This routine is not needed since there are no objects deleted by this manager. _MPCI_Internal_packets_Send_extract_proxy
This routine is invoked when a task is deleted and it has a proxy which must be removed from a thread queue and the remote node must be informed of this.
This routine is used to obtain an internal threads MP packet.
Return values
pointerThe pointer to the obtained packet.
NULLSomething went wrong.
◆ _MPCI_Internal_packets_Process_packet()
void _MPCI_Internal_packets_Process_packet ( MP_packet_Prefix the_packet_prefix)
_MPCI_Internal_packets_Send_request_packet
This routine performs a remote procedure call so that a directive operation can be initiated on another node.
This routine is not needed since there are no request packets to be sent by this manager. _MPCI_Internal_packets_Send_response_packet
This routine performs a remote procedure call so that a directive can be performed on another node.
This routine is not needed since there are no response packets to be sent by this manager.
This routine performs the actions specific to this package for the request from another node.
Parameters
the_packet_prefixThe packet prefix for this method.
◆ _MPCI_Internal_packets_Send_process_packet()
void _MPCI_Internal_packets_Send_process_packet ( MPCI_Internal_Remote_operations  operation)
This routine performs a remote procedure call so that a process operation can be performed on another node.
Parameters
operationThe remote operation to perform.
◆ _MPCI_Process_response()
Thread_Control * _MPCI_Process_response ( MP_packet_Prefix the_packet)
This routine is responsible for passing the_packet to the thread waiting on the remote operation to complete. The unblocked thread is responsible for eventually freeing the_packet.
Parameters
the_packetis the response packet to be processed.
Return values
pointerThis method returns a pointer to the thread which was unblocked
NULLThe waiting thread no longer exists.
◆ _MPCI_Receive_packet()
MP_packet_Prefix * _MPCI_Receive_packet ( void  )
Receives a packet.
This routine receives a packet by invoking the user provided MPCI receive callout.
Returns
This method returns the packet received.
◆ _MPCI_Receive_server()
void _MPCI_Receive_server ( Thread_Entry_numeric_type  ignored)
This is the server thread which receives and processes all MCPI packets.
Parameters
ignoredThe thread argument. It is not used.
◆ _MPCI_Register_packet_processor()
void _MPCI_Register_packet_processor ( MP_packet_Classes  the_class,
Parameters
the_classThe class indicator for packets which will be processed by the_packet_processor method.
the_packet_processorPointer to a method which is invoked when packets with the_class are received.
◆ _MPCI_Return_packet()
void _MPCI_Return_packet ( MP_packet_Prefix the_packet)
This routine deallocates a packet by invoking the user provided MPCI return packet callout.
Parameters
[out]the_packetThe MP packet to deallocate.
◆ _MPCI_Send_process_packet()
void _MPCI_Send_process_packet ( uint32_t  destination,
This routine sends a process packet by invoking the user provided MPCI send callout.
Parameters
destinationThe node which should receive this packet.
the_packetThe packet to be sent.
◆ _MPCI_Send_request_packet()
Status_Control _MPCI_Send_request_packet ( uint32_t  destination,
MP_packet_Prefix the_packet,
This routine sends a request packet by invoking the user provided MPCI send callout.
Parameters
extra_stateThe extra thread state bits which should be set in addition to the remote operation pending state. It may indicate the caller is blocking on a message queue operation.
@ret This method returns the operation status from the remote node.
◆ _MPCI_Send_response_packet()
void _MPCI_Send_response_packet ( uint32_t  destination,
This routine sends a response packet by invoking the user provided MPCI send callout.
Parameters
Variable Documentation
◆ _MPCI_Configuration
extern
Provided by the application via <rtems/confdefs.h>.
◆ _MPCI_Packet_processors
MPCI_Packet_processor _MPCI_Packet_processors[MP_PACKET_CLASSES_LAST+1]
extern
The following table contains the process packet routines provided by each object that supports MP operations.
◆ _MPCI_Receive_server_stack
char _MPCI_Receive_server_stack[]
extern
◆ _MPCI_Receive_server_tcb
Thread_Control* _MPCI_Receive_server_tcb
extern
The following is used to determine when the multiprocessing receive thread is executing so that a proxy can be allocated instead of blocking the multiprocessing receive thread.
◆ _MPCI_Remote_blocked_threads
extern
The following thread queue is used to maintain a list of tasks which currently have outstanding remote requests.
◆ _MPCI_table
MPCI_Control* _MPCI_table
extern
The following define the internal pointers to the user's configuration information.
