RTEMS 6.1
HAL_DMA_MuxRequestGeneratorConfigTypeDef Struct Reference
HAL DMAMUX request generator parameters structure definition. More...
#include <stm32h7xx_hal_dma_ex.h>
uint32_t SignalID
uint32_t Polarity
uint32_t RequestNumber
Field Documentation
◆ Polarity
uint32_t HAL_DMA_MuxRequestGeneratorConfigTypeDef::Polarity
Specifies the polarity of the signal on which the request is generated. This parameter can be a value of DMAEx MUX RequestGeneneratorPolarity selection
◆ RequestNumber
uint32_t HAL_DMA_MuxRequestGeneratorConfigTypeDef::RequestNumber
Specifies the number of DMA request that will be generated after a signal event. This parameters can be in the range 1 to 32
◆ SignalID
uint32_t HAL_DMA_MuxRequestGeneratorConfigTypeDef::SignalID
Specifies the ID of the signal used for DMAMUX request generator This parameter can be a value of DMAEx MUX SignalGeneratorID selection
