RTEMS 6.1
DMAEx MUX SignalGeneratorID selection
DMAEx MUX SignalGeneratorID selection. More...
#define HAL_DMAMUX1_REQ_GEN_DMAMUX1_CH0_EVT   0U
#define HAL_DMAMUX1_REQ_GEN_DMAMUX1_CH1_EVT   1U
#define HAL_DMAMUX1_REQ_GEN_DMAMUX1_CH2_EVT   2U
#define HAL_DMAMUX1_REQ_GEN_LPTIM1_OUT   3U
#define HAL_DMAMUX1_REQ_GEN_LPTIM2_OUT   4U
#define HAL_DMAMUX1_REQ_GEN_LPTIM3_OUT   5U
#define HAL_DMAMUX1_REQ_GEN_EXTI0   6U
#define HAL_DMAMUX1_REQ_GEN_TIM12_TRGO   7U
#define HAL_DMAMUX2_REQ_GEN_DMAMUX2_CH0_EVT   0U
#define HAL_DMAMUX2_REQ_GEN_DMAMUX2_CH1_EVT   1U
#define HAL_DMAMUX2_REQ_GEN_DMAMUX2_CH2_EVT   2U
#define HAL_DMAMUX2_REQ_GEN_DMAMUX2_CH3_EVT   3U
#define HAL_DMAMUX2_REQ_GEN_DMAMUX2_CH4_EVT   4U
#define HAL_DMAMUX2_REQ_GEN_DMAMUX2_CH5_EVT   5U
#define HAL_DMAMUX2_REQ_GEN_DMAMUX2_CH6_EVT   6U
#define HAL_DMAMUX2_REQ_GEN_LPUART1_RX_WKUP   7U
#define HAL_DMAMUX2_REQ_GEN_LPUART1_TX_WKUP   8U
#define HAL_DMAMUX2_REQ_GEN_LPTIM2_WKUP   9U
#define HAL_DMAMUX2_REQ_GEN_LPTIM2_OUT   10U
#define HAL_DMAMUX2_REQ_GEN_LPTIM3_WKUP   11U
#define HAL_DMAMUX2_REQ_GEN_LPTIM3_OUT   12U
#define HAL_DMAMUX2_REQ_GEN_I2C4_WKUP   15U
#define HAL_DMAMUX2_REQ_GEN_SPI6_WKUP   16U
#define HAL_DMAMUX2_REQ_GEN_COMP1_OUT   17U
#define HAL_DMAMUX2_REQ_GEN_COMP2_OUT   18U
#define HAL_DMAMUX2_REQ_GEN_RTC_WKUP   19U
#define HAL_DMAMUX2_REQ_GEN_EXTI0   20U
#define HAL_DMAMUX2_REQ_GEN_EXTI2   21U
#define HAL_DMAMUX2_REQ_GEN_I2C4_IT_EVT   22U
#define HAL_DMAMUX2_REQ_GEN_SPI6_IT   23U
#define HAL_DMAMUX2_REQ_GEN_LPUART1_TX_IT   24U
#define HAL_DMAMUX2_REQ_GEN_LPUART1_RX_IT   25U
#define HAL_DMAMUX2_REQ_GEN_BDMA_CH0_IT   28U
#define HAL_DMAMUX2_REQ_GEN_BDMA_CH1_IT   29U
◆ HAL_DMAMUX1_REQ_GEN_DMAMUX1_CH0_EVT
DMAMUX1 Request generator Signal is DMAMUX1 Channel0 Event
◆ HAL_DMAMUX1_REQ_GEN_DMAMUX1_CH1_EVT
DMAMUX1 Request generator Signal is DMAMUX1 Channel1 Event
◆ HAL_DMAMUX1_REQ_GEN_DMAMUX1_CH2_EVT
DMAMUX1 Request generator Signal is DMAMUX1 Channel2 Event
◆ HAL_DMAMUX1_REQ_GEN_EXTI0
DMAMUX1 Request generator Signal is EXTI0 IT
◆ HAL_DMAMUX1_REQ_GEN_LPTIM1_OUT
DMAMUX1 Request generator Signal is LPTIM1 OUT
◆ HAL_DMAMUX1_REQ_GEN_LPTIM2_OUT
DMAMUX1 Request generator Signal is LPTIM2 OUT
◆ HAL_DMAMUX1_REQ_GEN_LPTIM3_OUT
DMAMUX1 Request generator Signal is LPTIM3 OUT
◆ HAL_DMAMUX1_REQ_GEN_TIM12_TRGO
DMAMUX1 Request generator Signal is TIM12 TRGO
◆ HAL_DMAMUX2_REQ_GEN_BDMA_CH0_IT
DMAMUX2 Request generator Signal is BDMA Channel 0 IT
◆ HAL_DMAMUX2_REQ_GEN_BDMA_CH1_IT
DMAMUX2 Request generator Signal is BDMA Channel 1 IT
◆ HAL_DMAMUX2_REQ_GEN_COMP1_OUT
DMAMUX2 Request generator Signal is Comparator 1 output
◆ HAL_DMAMUX2_REQ_GEN_COMP2_OUT
DMAMUX2 Request generator Signal is Comparator 2 output
◆ HAL_DMAMUX2_REQ_GEN_DMAMUX2_CH0_EVT
DMAMUX2 Request generator Signal is DMAMUX2 Channel0 Event
◆ HAL_DMAMUX2_REQ_GEN_DMAMUX2_CH1_EVT
DMAMUX2 Request generator Signal is DMAMUX2 Channel1 Event
◆ HAL_DMAMUX2_REQ_GEN_DMAMUX2_CH2_EVT
DMAMUX2 Request generator Signal is DMAMUX2 Channel2 Event
◆ HAL_DMAMUX2_REQ_GEN_DMAMUX2_CH3_EVT
DMAMUX2 Request generator Signal is DMAMUX2 Channel3 Event
◆ HAL_DMAMUX2_REQ_GEN_DMAMUX2_CH4_EVT
DMAMUX2 Request generator Signal is DMAMUX2 Channel4 Event
◆ HAL_DMAMUX2_REQ_GEN_DMAMUX2_CH5_EVT
DMAMUX2 Request generator Signal is DMAMUX2 Channel5 Event
◆ HAL_DMAMUX2_REQ_GEN_DMAMUX2_CH6_EVT
DMAMUX2 Request generator Signal is DMAMUX2 Channel6 Event
◆ HAL_DMAMUX2_REQ_GEN_EXTI0
DMAMUX2 Request generator Signal is EXTI0
◆ HAL_DMAMUX2_REQ_GEN_EXTI2
DMAMUX2 Request generator Signal is EXTI2
◆ HAL_DMAMUX2_REQ_GEN_I2C4_IT_EVT
DMAMUX2 Request generator Signal is I2C4 IT Event
◆ HAL_DMAMUX2_REQ_GEN_I2C4_WKUP
DMAMUX2 Request generator Signal is I2C4 Wakeup
◆ HAL_DMAMUX2_REQ_GEN_LPTIM2_OUT
DMAMUX2 Request generator Signal is LPTIM2 OUT
◆ HAL_DMAMUX2_REQ_GEN_LPTIM2_WKUP
DMAMUX2 Request generator Signal is LPTIM2 Wakeup
◆ HAL_DMAMUX2_REQ_GEN_LPTIM3_OUT
DMAMUX2 Request generator Signal is LPTIM3 OUT
◆ HAL_DMAMUX2_REQ_GEN_LPTIM3_WKUP
DMAMUX2 Request generator Signal is LPTIM3 Wakeup
◆ HAL_DMAMUX2_REQ_GEN_LPUART1_RX_IT
DMAMUX2 Request generator Signal is LPUART1 Rx IT
◆ HAL_DMAMUX2_REQ_GEN_LPUART1_RX_WKUP
DMAMUX2 Request generator Signal is LPUART1 RX Wakeup
◆ HAL_DMAMUX2_REQ_GEN_LPUART1_TX_IT
DMAMUX2 Request generator Signal is LPUART1 Tx IT
◆ HAL_DMAMUX2_REQ_GEN_LPUART1_TX_WKUP
DMAMUX2 Request generator Signal is LPUART1 TX Wakeup
◆ HAL_DMAMUX2_REQ_GEN_RTC_WKUP
DMAMUX2 Request generator Signal is RTC Wakeup
◆ HAL_DMAMUX2_REQ_GEN_SPI6_IT
DMAMUX2 Request generator Signal is SPI6 IT
◆ HAL_DMAMUX2_REQ_GEN_SPI6_WKUP
DMAMUX2 Request generator Signal is SPI6 Wakeup
