RTEMS 6.1
#include <MIMXRT1166_cm4.h>
uint8_t RESERVED_0 [4]
__IO uint32_t CM_AUTHEN_CTRL
__IO uint32_t CM_INT_CTRL
__IO uint32_t CM_MISC
__IO uint32_t CM_MODE_CTRL
__I uint32_t CM_MODE_STAT
uint8_t RESERVED_1 [232]
__IO uint32_t CM_IRQ_WAKEUP_MASK [8]
uint8_t RESERVED_2 [32]
__IO uint32_t CM_NON_IRQ_WAKEUP_MASK
uint8_t RESERVED_3 [12]
__I uint32_t CM_IRQ_WAKEUP_STAT [8]
uint8_t RESERVED_4 [32]
__I uint32_t CM_NON_IRQ_WAKEUP_STAT
uint8_t RESERVED_5 [108]
__IO uint32_t CM_SLEEP_SSAR_CTRL
uint8_t RESERVED_6 [4]
__IO uint32_t CM_SLEEP_LPCG_CTRL
uint8_t RESERVED_7 [4]
__IO uint32_t CM_SLEEP_PLL_CTRL
uint8_t RESERVED_8 [4]
__IO uint32_t CM_SLEEP_ISO_CTRL
uint8_t RESERVED_9 [4]
__IO uint32_t CM_SLEEP_RESET_CTRL
uint8_t RESERVED_10 [4]
__IO uint32_t CM_SLEEP_POWER_CTRL
uint8_t RESERVED_11 [100]
__IO uint32_t CM_WAKEUP_POWER_CTRL
uint8_t RESERVED_12 [4]
__IO uint32_t CM_WAKEUP_RESET_CTRL
uint8_t RESERVED_13 [4]
__IO uint32_t CM_WAKEUP_ISO_CTRL
uint8_t RESERVED_14 [4]
__IO uint32_t CM_WAKEUP_PLL_CTRL
uint8_t RESERVED_15 [4]
__IO uint32_t CM_WAKEUP_LPCG_CTRL
uint8_t RESERVED_16 [4]
__IO uint32_t CM_WAKEUP_SSAR_CTRL
uint8_t RESERVED_17 [68]
__IO uint32_t CM_SP_CTRL
__I uint32_t CM_SP_STAT
uint8_t RESERVED_18 [8]
__IO uint32_t CM_RUN_MODE_MAPPING
__IO uint32_t CM_WAIT_MODE_MAPPING
__IO uint32_t CM_STOP_MODE_MAPPING
__IO uint32_t CM_SUSPEND_MODE_MAPPING
__IO uint32_t CM_SP_MAPPING [16]
uint8_t RESERVED_19 [32]
__IO uint32_t CM_STBY_CTRL
GPC_CPU_MODE_CTRL - Register Layout Typedef
The documentation for this struct was generated from the following files:
