RTEMS 6.1
Test context for spec:/dev/grlib/req/irqamp-get-timestamp test case. More...
irqamp_timestampresult
 This member contains the return value of the irqamp_get_timestamp_registers() call.
irqamp irqamp_regs
 This member contains the IRQ(A)MP register block.
struct {
   size_t   pcs [1]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   DevGrlibReqIrqampGetTimestamp_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
