RTEMS 6.1
Modules | Files | Variables
spec:/testsuites/bsps/validation-bsp-0
This general purpose validation test suite provides enough resources to run target-specific tests. More...
 spec:/bsp/sparc/leon3/val/gr712rc
 This test case collection provides validation test cases for the sparc/gr712rc BSP.
 spec:/bsp/sparc/leon3/val/gr740
 This test case collection provides validation test cases for the sparc/gr740 BSP.
 spec:/dev/clock/xil-ttc/val/tick-catch-up
 Tests some Xilinx TTC clock driver functions.
 spec:/dev/grlib/req/apbuart-inbyte-nonblocking
 spec:/dev/grlib/req/irqamp-get-timestamp
 spec:/dev/grlib/val/io
 Tests some GRLIB directives.
file  ts-validation-bsp-0.c
const char rtems_test_name [] = "TestsuitesBspsValidationBsp0"
 Each test must define a test name string.
