RTEMS 6.1
DFSDM_Channel_InitTypeDef Struct Reference
DFSDM channel init structure definition. More...
#include <stm32h7xx_hal_dfsdm.h>
DFSDM_Channel_OutputClockTypeDef OutputClock
DFSDM_Channel_InputTypeDef Input
DFSDM_Channel_SerialInterfaceTypeDef SerialInterface
DFSDM_Channel_AwdTypeDef Awd
int32_t Offset
uint32_t RightBitShift
Field Documentation
◆ Awd
DFSDM_Channel_AwdTypeDef DFSDM_Channel_InitTypeDef::Awd
DFSDM channel analog watchdog parameters
◆ Input
DFSDM_Channel_InputTypeDef DFSDM_Channel_InitTypeDef::Input
DFSDM channel input parameters
◆ Offset
int32_t DFSDM_Channel_InitTypeDef::Offset
DFSDM channel offset. This parameter must be a number between Min_Data = -8388608 and Max_Data = 8388607
◆ OutputClock
DFSDM_Channel_OutputClockTypeDef DFSDM_Channel_InitTypeDef::OutputClock
DFSDM channel output clock parameters
◆ RightBitShift
uint32_t DFSDM_Channel_InitTypeDef::RightBitShift
DFSDM channel right bit shift. This parameter must be a number between Min_Data = 0x00 and Max_Data = 0x1F
◆ SerialInterface
DFSDM_Channel_SerialInterfaceTypeDef DFSDM_Channel_InitTypeDef::SerialInterface
DFSDM channel serial interface parameters
