RTEMS 6.1
DFSDM_Channel_InputTypeDef Struct Reference
DFSDM channel input structure definition. More...
#include <stm32h7xx_hal_dfsdm.h>
uint32_t Multiplexer
uint32_t DataPacking
uint32_t Pins
Field Documentation
◆ DataPacking
uint32_t DFSDM_Channel_InputTypeDef::DataPacking
Standard, interleaved or dual mode for internal register. This parameter can be a value of DFSDM channel input data packing
◆ Multiplexer
uint32_t DFSDM_Channel_InputTypeDef::Multiplexer
Input is external serial inputs, internal register or ADC output. This parameter can be a value of DFSDM channel input multiplexer
◆ Pins
uint32_t DFSDM_Channel_InputTypeDef::Pins
Input pins are taken from same or following channel. This parameter can be a value of DFSDM channel input pins
