RTEMS 6.1
#include <alt_clock_manager.h>
ALT_CLK_t ref_clk
uint32_t mult
uint32_t div
uint32_t cntrs [6]
uint32_t pshift [6]
This type definition defines a structure to contain the generalized configuration settings for a PLL.
Field Documentation
◆ cntrs
uint32_t ALT_CLK_PLL_CFG_s::cntrs[6]
Post-Scale Counters (C0 - C5) - range 1 to 512
◆ div
uint32_t ALT_CLK_PLL_CFG_s::div
VCO Frequency Configuration - Divider (N) value, range 1 to 64
◆ mult
uint32_t ALT_CLK_PLL_CFG_s::mult
VCO Frequency Configuration - Multiplier (M) value, range 1 to 4096
◆ pshift
uint32_t ALT_CLK_PLL_CFG_s::pshift[6]
Phase Shift - 1/8 (45 degrees) of negative phase shift per increment, range 0 to 4096
◆ ref_clk
ALT_CLK_t ALT_CLK_PLL_CFG_s::ref_clk
PLL Reference Clock Source
