RTEMS 6.1
Modules | Typedefs | Enumerations
 Clock Frequency Control
 Clock Gating Control
 Clock Group Configuration
 Clock Manager Interrupt Management
 Clock Manager Status
 Clock Source Selection
 PLL Bypass Control
 Safe Mode Options
typedef uint32_t alt_freq_t
typedef enum ALT_CLK_e ALT_CLK_t
enum  ALT_CLK_e {
  ALT_CLK_IN_PIN_OSC1 , ALT_CLK_IN_PIN_OSC2 , ALT_CLK_F2H_PERIPH_REF , ALT_CLK_F2H_SDRAM_REF ,
  ALT_CLK_IN_PIN_JTAG , ALT_CLK_IN_PIN_ULPI0 , ALT_CLK_IN_PIN_ULPI1 , ALT_CLK_IN_PIN_EMAC0_RX ,
  ALT_CLK_IN_PIN_EMAC1_RX , ALT_CLK_MAIN_PLL , ALT_CLK_PERIPHERAL_PLL , ALT_CLK_SDRAM_PLL ,
  ALT_CLK_OSC1 , ALT_CLK_MAIN_PLL_C0 , ALT_CLK_MAIN_PLL_C1 , ALT_CLK_MAIN_PLL_C2 ,
  ALT_CLK_MAIN_PLL_C3 , ALT_CLK_MAIN_PLL_C4 , ALT_CLK_MAIN_PLL_C5 , ALT_CLK_MPU ,
  ALT_CLK_MPU_L2_RAM , ALT_CLK_MPU_PERIPH , ALT_CLK_L3_MAIN , ALT_CLK_L3_MP ,
  ALT_CLK_L3_SP , ALT_CLK_L4_MAIN , ALT_CLK_L4_MP , ALT_CLK_L4_SP ,
  ALT_CLK_DBG_BASE , ALT_CLK_DBG_AT , ALT_CLK_DBG_TRACE , ALT_CLK_DBG_TIMER ,
  ALT_CLK_DBG , ALT_CLK_MAIN_QSPI , ALT_CLK_MAIN_NAND_SDMMC , ALT_CLK_CFG ,
  ALT_CLK_H2F_USER0 , ALT_CLK_PERIPHERAL_PLL_C0 , ALT_CLK_PERIPHERAL_PLL_C1 , ALT_CLK_PERIPHERAL_PLL_C2 ,
  ALT_CLK_PERIPHERAL_PLL_C3 , ALT_CLK_PERIPHERAL_PLL_C4 , ALT_CLK_PERIPHERAL_PLL_C5 , ALT_CLK_USB_MP ,
  ALT_CLK_SPI_M , ALT_CLK_QSPI , ALT_CLK_NAND_X , ALT_CLK_NAND ,
  ALT_CLK_SDMMC , ALT_CLK_EMAC0 , ALT_CLK_EMAC1 , ALT_CLK_CAN0 ,
  ALT_CLK_CAN1 , ALT_CLK_GPIO_DB , ALT_CLK_H2F_USER1 , ALT_CLK_SDRAM_PLL_C0 ,
  ALT_CLK_SDRAM_PLL_C1 , ALT_CLK_SDRAM_PLL_C2 , ALT_CLK_SDRAM_PLL_C3 , ALT_CLK_SDRAM_PLL_C4 ,
  ALT_CLK_SDRAM_PLL_C5 , ALT_CLK_DDR_DQS , ALT_CLK_DDR_2X_DQS , ALT_CLK_DDR_DQ ,
  ALT_CLK_H2F_USER2 , ALT_CLK_OUT_PIN_EMAC0_TX , ALT_CLK_OUT_PIN_EMAC1_TX , ALT_CLK_OUT_PIN_SDMMC ,
  ALT_CLK_OUT_PIN_I2C0_SCL , ALT_CLK_OUT_PIN_I2C1_SCL , ALT_CLK_OUT_PIN_I2C2_SCL , ALT_CLK_OUT_PIN_I2C3_SCL ,
  ALT_CLK_OUT_PIN_SPIM0 , ALT_CLK_OUT_PIN_SPIM1 , ALT_CLK_OUT_PIN_QSPI , ALT_CLK_UNKNOWN
This module defines the Clock Manager API for accessing, configuring, and controlling the HPS clock resources.
Typedef Documentation
◆ ALT_CLK_t
This type definition enumerates the names of the clock and PLL resources managed by the Clock Manager.
◆ alt_freq_t
This type definition is an opaque type definition for clock frequency values in Hz.
◆ ALT_CLK_e
enum ALT_CLK_e
ALT_CLK_IN_PIN_OSC1
OSC_CLK_1_HPS External oscillator input:
  • Input Pin
  • Clock source to Main PLL
  • Clock source to SDRAM PLL and Peripheral PLL if selected via register write
  • Clock source for clock in safe mode
ALT_CLK_IN_PIN_OSC2
OSC_CLK_2_HPS External Oscillator input:
  • Input Pin
  • Optional clock source to SDRAM PLL and Peripheral PLL if selected
  • Typically used for Ethernet reference clock
ALT_CLK_IN_PIN_JTAG
JTAG_TCK_HPS
  • Input Pin
  • External HPS JTAG clock input.
ULPI0_CLK ULPI Clock provided by external USB0 PHY
  • Input Pin
ULPI1_CLK ULPI Clock provided by external USB1 PHY
  • Input Pin
EMAC0:RX_CLK Rx Reference Clock for EMAC0
  • Input Pin
EMAC1:RX_CLK Rx Reference Clock for EMAC1
  • Input Pin
ALT_CLK_MAIN_PLL
main_pll_ref_clkin Main PLL input reference clock, used to designate the Main PLL in PLL clock selections.
periph_pll_ref_clkin Peripheral PLL input reference clock, used to designate the Peripheral PLL in PLL clock selections.
ALT_CLK_SDRAM_PLL
sdram_pll_ref_clkin SDRAM PLL input reference clock, used to designate the SDRAM PLL in PLL clock selections.
ALT_CLK_OSC1
osc1_clk OSC1 Clock Group - The OSC1 clock group contains those clocks which are derived directly from the osc_clk_1_HPS pin.
  • alias for ALT_CLK_IN_PIN_OSC1
ALT_CLK_MAIN_PLL_C0
Main PLL C0 Output
ALT_CLK_MAIN_PLL_C1
Main PLL C1 Output
ALT_CLK_MAIN_PLL_C2
Main PLL C2 Output
ALT_CLK_MAIN_PLL_C3
Main PLL C3 Output
ALT_CLK_MAIN_PLL_C4
Main PLL C4 Output
ALT_CLK_MAIN_PLL_C5
Main PLL C5 Output
ALT_CLK_MPU
mpu_clk Main PLL C0 Output. Clock for MPU subsystem, including CPU0 and CPU1.
  • Alias for ALT_CLK_MAIN_PLL_C0
ALT_CLK_MPU_L2_RAM
mpu_l2_ram_clk Clock for MPU level 2 (L2) RAM
ALT_CLK_MPU_PERIPH
mpu_periph_clk Clock for MPU snoop control unit (SCU) peripherals, such as the general interrupt controller (GIC)
ALT_CLK_L3_MAIN
main_clk Main PLL C1 Output
  • Alias for ALT_CLK_MAIN_PLL_C1
ALT_CLK_L3_MP
l3_mp_clk Clock for L3 Master Peripheral Switch
ALT_CLK_L3_SP
l3_sp_clk Clock for L3 Slave Peripheral Switch
ALT_CLK_L4_MAIN
l4_main_clk Clock for L4 main bus
  • Clock for DMA
  • Clock for SPI masters
ALT_CLK_L4_MP
l4_mp_clk Clock for L4 master peripherals (MP) bus
ALT_CLK_L4_SP
l4_sp_clk Clock for L4 slave peripherals (SP) bus
ALT_CLK_DBG_BASE
dbg_base_clk Main PLL C2 Output
  • Alias for ALT_CLK_MAIN_PLL_C2
ALT_CLK_DBG_AT
dbg_at_clk Clock for CoreSight debug Advanced Microcontroller Bus Architecture (AMBA) Trace Bus (ATB)
ALT_CLK_DBG_TRACE
dbg_trace_clk Clock for CoreSight debug Trace Port Interface Unit (TPIU)
ALT_CLK_DBG_TIMER
dbg_timer_clk Clock for the trace timestamp generator
ALT_CLK_DBG
dbg_clk Clock for Debug Access Port (DAP) and debug Advanced Peripheral Bus (APB)
ALT_CLK_MAIN_QSPI
main_qspi_clk Main PLL C3 Output. Quad SPI flash internal logic clock.
  • Alias for ALT_CLK_MAIN_PLL_C3
main_nand_sdmmc_clk Main PLL C4 Output. Input clock to flash controller clocks block.
  • Alias for ALT_CLK_MAIN_PLL_C4
ALT_CLK_CFG
cfg_clk FPGA manager configuration clock.
ALT_CLK_H2F_USER0
h2f_user0_clock Clock to FPGA fabric
Peripheral PLL C0 Output
Peripheral PLL C1 Output
Peripheral PLL C2 Output
Peripheral PLL C3 Output
Peripheral PLL C4 Output
Peripheral PLL C5 Output
ALT_CLK_USB_MP
usb_mp_clk Clock for USB
ALT_CLK_SPI_M
spi_m_clk Clock for L4 SPI master bus
ALT_CLK_QSPI
qspi_clk Clock for Quad SPI
ALT_CLK_NAND_X
nand_x_clk NAND flash controller master and slave clock
ALT_CLK_NAND
nand_clk Main clock for NAND flash controller
ALT_CLK_SDMMC
sdmmc_clk Clock for SD/MMC logic input clock
ALT_CLK_EMAC0
emac0_clk EMAC 0 clock - Peripheral PLL C0 Output
  • Alias for ALT_CLK_PERIPHERAL_PLL_C0
ALT_CLK_EMAC1
emac1_clk EMAC 1 clock - Peripheral PLL C1 Output
  • Alias for ALT_CLK_PERIPHERAL_PLL_C1
ALT_CLK_CAN0
can0_clk Controller area network (CAN) controller 0 clock
ALT_CLK_CAN1
can1_clk Controller area network (CAN) controller 1 clock
ALT_CLK_GPIO_DB
gpio_db_clk Debounce clock for GPIO0, GPIO1, and GPIO2
ALT_CLK_H2F_USER1
h2f_user1_clock Clock to FPGA fabric - Peripheral PLL C5 Output
  • Alias for ALT_CLK_PERIPHERAL_PLL_C5
SDRAM PLL C0 Output
SDRAM PLL C1 Output
SDRAM PLL C2 Output
SDRAM PLL C3 Output
SDRAM PLL C4 Output
SDRAM PLL C5 Output
ALT_CLK_DDR_DQS
ddr_dqs_clk Clock for MPFE, single-port controller, CSR access, and PHY - SDRAM PLL C0 Output
  • Alias for ALT_CLK_SDRAM_PLL_C0
ALT_CLK_DDR_2X_DQS
ddr_2x_dqs_clk Clock for PHY - SDRAM PLL C1 Output
  • Alias for ALT_CLK_SDRAM_PLL_C1
ALT_CLK_DDR_DQ
ddr_dq_clk Clock for PHY - SDRAM PLL C2 Output
  • Alias for ALT_CLK_SDRAM_PLL_C2
ALT_CLK_H2F_USER2
h2f_user2_clock Clock to FPGA fabric - SDRAM PLL C5 Output
  • Alias for ALT_CLK_SDRAM_PLL_C5
EMAC0:TX_CLK Tx Reference Clock for EMAC0
  • Output Pin
EMAC1:TX_CLK Tx Reference Clock for EMAC1
  • Output Pin
SDMMC:CLK SD/MMC Card Clock
  • Output Pin
I2C0:SCL I2C Clock for I2C0
  • Output Pin
I2C1:SCL I2C Clock for I2C1
  • Output Pin
I2C2:SCL I2C Clock for I2C2/2 wire
  • Output Pin
I2C3:SCL I2C Clock for I2C1/2 wire
  • Output Pin
SPIM0:CLK SPI Clock
  • Output Pin
SPIM1:CLK SPI Clock
  • Output Pin
QSPI:CLK QSPI Flash Clock
  • Output Pin
