RTEMS 6.1
Header file of WWDG HAL module. More...
#include "stm32h7xx_hal_def.h"Go to the source code of this file.
| struct | WWDG_InitTypeDef |
| WWDG Init structure definition. More... | |
| struct | WWDG_HandleTypeDef |
| WWDG handle Structure definition. More... | |
| #define | WWDG_IT_EWI WWDG_CFR_EWI |
| #define | WWDG_FLAG_EWIF WWDG_SR_EWIF |
| #define | WWDG_PRESCALER_1 0x00000000u |
| #define | WWDG_PRESCALER_2 WWDG_CFR_WDGTB_0 |
| #define | WWDG_PRESCALER_4 WWDG_CFR_WDGTB_1 |
| #define | WWDG_PRESCALER_8 (WWDG_CFR_WDGTB_1 | WWDG_CFR_WDGTB_0) |
| #define | WWDG_PRESCALER_16 WWDG_CFR_WDGTB_2 |
| #define | WWDG_PRESCALER_32 (WWDG_CFR_WDGTB_2 | WWDG_CFR_WDGTB_0) |
| #define | WWDG_PRESCALER_64 (WWDG_CFR_WDGTB_2 | WWDG_CFR_WDGTB_1) |
| #define | WWDG_PRESCALER_128 WWDG_CFR_WDGTB |
| #define | WWDG_EWI_DISABLE 0x00000000u |
| #define | WWDG_EWI_ENABLE WWDG_CFR_EWI |
| #define | IS_WWDG_PRESCALER(__PRESCALER__) |
| #define | IS_WWDG_WINDOW(__WINDOW__) (((__WINDOW__) >= WWDG_CFR_W_6) && ((__WINDOW__) <= WWDG_CFR_W)) |
| #define | IS_WWDG_COUNTER(__COUNTER__) (((__COUNTER__) >= WWDG_CR_T_6) && ((__COUNTER__) <= WWDG_CR_T)) |
| #define | IS_WWDG_EWI_MODE(__MODE__) |
| #define | __HAL_WWDG_ENABLE(__HANDLE__) SET_BIT((__HANDLE__)->Instance->CR, WWDG_CR_WDGA) |
| Enable the WWDG peripheral. | |
| #define | __HAL_WWDG_ENABLE_IT(__HANDLE__, __INTERRUPT__) SET_BIT((__HANDLE__)->Instance->CFR, (__INTERRUPT__)) |
| Enable the WWDG early wakeup interrupt. | |
| #define | __HAL_WWDG_GET_IT(__HANDLE__, __INTERRUPT__) __HAL_WWDG_GET_FLAG((__HANDLE__),(__INTERRUPT__)) |
| Check whether the selected WWDG interrupt has occurred or not. | |
| #define | __HAL_WWDG_CLEAR_IT(__HANDLE__, __INTERRUPT__) __HAL_WWDG_CLEAR_FLAG((__HANDLE__), (__INTERRUPT__)) |
| Clear the WWDG interrupt pending bits. bits to clear the selected interrupt pending bits. | |
| #define | __HAL_WWDG_GET_FLAG(__HANDLE__, __FLAG__) (((__HANDLE__)->Instance->SR & (__FLAG__)) == (__FLAG__)) |
| Check whether the specified WWDG flag is set or not. | |
| #define | __HAL_WWDG_CLEAR_FLAG(__HANDLE__, __FLAG__) ((__HANDLE__)->Instance->SR = ~(__FLAG__)) |
| Clear the WWDG's pending flags. | |
| #define | __HAL_WWDG_GET_IT_SOURCE(__HANDLE__, __INTERRUPT__) |
| Check whether the specified WWDG interrupt source is enabled or not. | |
| HAL_StatusTypeDef | HAL_WWDG_Init (WWDG_HandleTypeDef *hwwdg) |
| void | HAL_WWDG_MspInit (WWDG_HandleTypeDef *hwwdg) |
| HAL_StatusTypeDef | HAL_WWDG_Refresh (WWDG_HandleTypeDef *hwwdg) |
| void | HAL_WWDG_IRQHandler (WWDG_HandleTypeDef *hwwdg) |
| void | HAL_WWDG_EarlyWakeupCallback (WWDG_HandleTypeDef *hwwdg) |
