RTEMS 6.1
Header file of DFSDM HAL module. More...
#include "stm32h7xx_hal_def.h"Go to the source code of this file.
| struct | DFSDM_Channel_OutputClockTypeDef |
| DFSDM channel output clock structure definition. More... | |
| struct | DFSDM_Channel_InputTypeDef |
| DFSDM channel input structure definition. More... | |
| struct | DFSDM_Channel_SerialInterfaceTypeDef |
| DFSDM channel serial interface structure definition. More... | |
| struct | DFSDM_Channel_AwdTypeDef |
| DFSDM channel analog watchdog structure definition. More... | |
| struct | DFSDM_Channel_InitTypeDef |
| DFSDM channel init structure definition. More... | |
| struct | DFSDM_Channel_HandleTypeDef |
| DFSDM channel handle structure definition. More... | |
| struct | DFSDM_Filter_RegularParamTypeDef |
| DFSDM filter regular conversion parameters structure definition. More... | |
| struct | DFSDM_Filter_InjectedParamTypeDef |
| DFSDM filter injected conversion parameters structure definition. More... | |
| struct | DFSDM_Filter_FilterParamTypeDef |
| DFSDM filter parameters structure definition. More... | |
| struct | DFSDM_Filter_InitTypeDef |
| DFSDM filter init structure definition. More... | |
| struct | DFSDM_Filter_HandleTypeDef |
| DFSDM filter handle structure definition. More... | |
| struct | DFSDM_Filter_AwdParamTypeDef |
| DFSDM filter analog watchdog parameters structure definition. More... | |
Enumerations | |
| enum | HAL_DFSDM_Channel_StateTypeDef { HAL_DFSDM_CHANNEL_STATE_RESET = 0x00U , HAL_DFSDM_CHANNEL_STATE_READY = 0x01U , HAL_DFSDM_CHANNEL_STATE_ERROR = 0xFFU } |
| HAL DFSDM Channel states definition. More... | |
| enum | HAL_DFSDM_Filter_StateTypeDef { HAL_DFSDM_FILTER_STATE_RESET = 0x00U , HAL_DFSDM_FILTER_STATE_READY = 0x01U , HAL_DFSDM_FILTER_STATE_REG = 0x02U , HAL_DFSDM_FILTER_STATE_INJ = 0x03U , HAL_DFSDM_FILTER_STATE_REG_INJ = 0x04U , HAL_DFSDM_FILTER_STATE_ERROR = 0xFFU } |
| HAL DFSDM Filter states definition. More... | |
| HAL_StatusTypeDef | HAL_DFSDM_ChannelInit (DFSDM_Channel_HandleTypeDef *hdfsdm_channel) |
| HAL_StatusTypeDef | HAL_DFSDM_ChannelDeInit (DFSDM_Channel_HandleTypeDef *hdfsdm_channel) |
| void | HAL_DFSDM_ChannelMspInit (DFSDM_Channel_HandleTypeDef *hdfsdm_channel) |
| void | HAL_DFSDM_ChannelMspDeInit (DFSDM_Channel_HandleTypeDef *hdfsdm_channel) |
| HAL_StatusTypeDef | HAL_DFSDM_ChannelCkabStart (DFSDM_Channel_HandleTypeDef *hdfsdm_channel) |
| HAL_StatusTypeDef | HAL_DFSDM_ChannelCkabStart_IT (DFSDM_Channel_HandleTypeDef *hdfsdm_channel) |
| HAL_StatusTypeDef | HAL_DFSDM_ChannelCkabStop (DFSDM_Channel_HandleTypeDef *hdfsdm_channel) |
| HAL_StatusTypeDef | HAL_DFSDM_ChannelCkabStop_IT (DFSDM_Channel_HandleTypeDef *hdfsdm_channel) |
| HAL_StatusTypeDef | HAL_DFSDM_ChannelScdStart (DFSDM_Channel_HandleTypeDef *hdfsdm_channel, uint32_t Threshold, uint32_t BreakSignal) |
| HAL_StatusTypeDef | HAL_DFSDM_ChannelScdStart_IT (DFSDM_Channel_HandleTypeDef *hdfsdm_channel, uint32_t Threshold, uint32_t BreakSignal) |
| HAL_StatusTypeDef | HAL_DFSDM_ChannelScdStop (DFSDM_Channel_HandleTypeDef *hdfsdm_channel) |
| HAL_StatusTypeDef | HAL_DFSDM_ChannelScdStop_IT (DFSDM_Channel_HandleTypeDef *hdfsdm_channel) |
| int16_t | HAL_DFSDM_ChannelGetAwdValue (const DFSDM_Channel_HandleTypeDef *hdfsdm_channel) |
| HAL_StatusTypeDef | HAL_DFSDM_ChannelModifyOffset (DFSDM_Channel_HandleTypeDef *hdfsdm_channel, int32_t Offset) |
| HAL_StatusTypeDef | HAL_DFSDM_ChannelPollForCkab (const DFSDM_Channel_HandleTypeDef *hdfsdm_channel, uint32_t Timeout) |
| HAL_StatusTypeDef | HAL_DFSDM_ChannelPollForScd (const DFSDM_Channel_HandleTypeDef *hdfsdm_channel, uint32_t Timeout) |
| void | HAL_DFSDM_ChannelCkabCallback (DFSDM_Channel_HandleTypeDef *hdfsdm_channel) |
| void | HAL_DFSDM_ChannelScdCallback (DFSDM_Channel_HandleTypeDef *hdfsdm_channel) |
| HAL_DFSDM_Channel_StateTypeDef | HAL_DFSDM_ChannelGetState (const DFSDM_Channel_HandleTypeDef *hdfsdm_channel) |
| HAL_StatusTypeDef | HAL_DFSDM_FilterInit (DFSDM_Filter_HandleTypeDef *hdfsdm_filter) |
| HAL_StatusTypeDef | HAL_DFSDM_FilterDeInit (DFSDM_Filter_HandleTypeDef *hdfsdm_filter) |
| void | HAL_DFSDM_FilterMspInit (DFSDM_Filter_HandleTypeDef *hdfsdm_filter) |
| void | HAL_DFSDM_FilterMspDeInit (DFSDM_Filter_HandleTypeDef *hdfsdm_filter) |
| HAL_StatusTypeDef | HAL_DFSDM_FilterConfigRegChannel (DFSDM_Filter_HandleTypeDef *hdfsdm_filter, uint32_t Channel, uint32_t ContinuousMode) |
| HAL_StatusTypeDef | HAL_DFSDM_FilterConfigInjChannel (DFSDM_Filter_HandleTypeDef *hdfsdm_filter, uint32_t Channel) |
| HAL_StatusTypeDef | HAL_DFSDM_FilterRegularStart (DFSDM_Filter_HandleTypeDef *hdfsdm_filter) |
| HAL_StatusTypeDef | HAL_DFSDM_FilterRegularStart_IT (DFSDM_Filter_HandleTypeDef *hdfsdm_filter) |
| HAL_StatusTypeDef | HAL_DFSDM_FilterRegularStart_DMA (DFSDM_Filter_HandleTypeDef *hdfsdm_filter, int32_t *pData, uint32_t Length) |
| HAL_StatusTypeDef | HAL_DFSDM_FilterRegularMsbStart_DMA (DFSDM_Filter_HandleTypeDef *hdfsdm_filter, int16_t *pData, uint32_t Length) |
| HAL_StatusTypeDef | HAL_DFSDM_FilterRegularStop (DFSDM_Filter_HandleTypeDef *hdfsdm_filter) |
| HAL_StatusTypeDef | HAL_DFSDM_FilterRegularStop_IT (DFSDM_Filter_HandleTypeDef *hdfsdm_filter) |
| HAL_StatusTypeDef | HAL_DFSDM_FilterRegularStop_DMA (DFSDM_Filter_HandleTypeDef *hdfsdm_filter) |
| HAL_StatusTypeDef | HAL_DFSDM_FilterInjectedStart (DFSDM_Filter_HandleTypeDef *hdfsdm_filter) |
| HAL_StatusTypeDef | HAL_DFSDM_FilterInjectedStart_IT (DFSDM_Filter_HandleTypeDef *hdfsdm_filter) |
| HAL_StatusTypeDef | HAL_DFSDM_FilterInjectedStart_DMA (DFSDM_Filter_HandleTypeDef *hdfsdm_filter, int32_t *pData, uint32_t Length) |
| HAL_StatusTypeDef | HAL_DFSDM_FilterInjectedMsbStart_DMA (DFSDM_Filter_HandleTypeDef *hdfsdm_filter, int16_t *pData, uint32_t Length) |
| HAL_StatusTypeDef | HAL_DFSDM_FilterInjectedStop (DFSDM_Filter_HandleTypeDef *hdfsdm_filter) |
| HAL_StatusTypeDef | HAL_DFSDM_FilterInjectedStop_IT (DFSDM_Filter_HandleTypeDef *hdfsdm_filter) |
| HAL_StatusTypeDef | HAL_DFSDM_FilterInjectedStop_DMA (DFSDM_Filter_HandleTypeDef *hdfsdm_filter) |
| HAL_StatusTypeDef | HAL_DFSDM_FilterAwdStart_IT (DFSDM_Filter_HandleTypeDef *hdfsdm_filter, const DFSDM_Filter_AwdParamTypeDef *awdParam) |
| HAL_StatusTypeDef | HAL_DFSDM_FilterAwdStop_IT (DFSDM_Filter_HandleTypeDef *hdfsdm_filter) |
| HAL_StatusTypeDef | HAL_DFSDM_FilterExdStart (DFSDM_Filter_HandleTypeDef *hdfsdm_filter, uint32_t Channel) |
| HAL_StatusTypeDef | HAL_DFSDM_FilterExdStop (DFSDM_Filter_HandleTypeDef *hdfsdm_filter) |
| int32_t | HAL_DFSDM_FilterGetRegularValue (const DFSDM_Filter_HandleTypeDef *hdfsdm_filter, uint32_t *Channel) |
| int32_t | HAL_DFSDM_FilterGetInjectedValue (const DFSDM_Filter_HandleTypeDef *hdfsdm_filter, uint32_t *Channel) |
| int32_t | HAL_DFSDM_FilterGetExdMaxValue (const DFSDM_Filter_HandleTypeDef *hdfsdm_filter, uint32_t *Channel) |
| int32_t | HAL_DFSDM_FilterGetExdMinValue (const DFSDM_Filter_HandleTypeDef *hdfsdm_filter, uint32_t *Channel) |
| uint32_t | HAL_DFSDM_FilterGetConvTimeValue (const DFSDM_Filter_HandleTypeDef *hdfsdm_filter) |
| void | HAL_DFSDM_IRQHandler (DFSDM_Filter_HandleTypeDef *hdfsdm_filter) |
| HAL_StatusTypeDef | HAL_DFSDM_FilterPollForRegConversion (DFSDM_Filter_HandleTypeDef *hdfsdm_filter, uint32_t Timeout) |
| HAL_StatusTypeDef | HAL_DFSDM_FilterPollForInjConversion (DFSDM_Filter_HandleTypeDef *hdfsdm_filter, uint32_t Timeout) |
| void | HAL_DFSDM_FilterRegConvCpltCallback (DFSDM_Filter_HandleTypeDef *hdfsdm_filter) |
| void | HAL_DFSDM_FilterRegConvHalfCpltCallback (DFSDM_Filter_HandleTypeDef *hdfsdm_filter) |
| void | HAL_DFSDM_FilterInjConvCpltCallback (DFSDM_Filter_HandleTypeDef *hdfsdm_filter) |
| void | HAL_DFSDM_FilterInjConvHalfCpltCallback (DFSDM_Filter_HandleTypeDef *hdfsdm_filter) |
| void | HAL_DFSDM_FilterAwdCallback (DFSDM_Filter_HandleTypeDef *hdfsdm_filter, uint32_t Channel, uint32_t Threshold) |
| void | HAL_DFSDM_FilterErrorCallback (DFSDM_Filter_HandleTypeDef *hdfsdm_filter) |
| HAL_DFSDM_Filter_StateTypeDef | HAL_DFSDM_FilterGetState (const DFSDM_Filter_HandleTypeDef *hdfsdm_filter) |
| uint32_t | HAL_DFSDM_FilterGetError (const DFSDM_Filter_HandleTypeDef *hdfsdm_filter) |
