RTEMS 6.1
sparse-disk.h
2
11/*
12 * Copyright (c) 2012 embedded brains GmbH & Co. KG
13 *
16 * are met:
22 *
34 */
35
36#ifndef SPARSE_DISK_H
37#define SPARSE_DISK_H
38
39#include <stddef.h>
40#include <stdint.h>
41#include <rtems.h>
42#include <rtems/diskdevs.h>
43#include <rtems/thread.h>
44
45#ifdef __cplusplus
46extern "C" {
47#endif /* __cplusplus */
48
57typedef struct {
59 void *data;
61
63
64typedef void (*rtems_sparse_disk_delete_handler)(rtems_sparse_disk *sparse_disk);
65
67 rtems_mutex mutex;
68 rtems_blkdev_bnum blocks_with_buffer;
69 size_t used_count;
70 uint32_t media_block_size;
71 rtems_sparse_disk_delete_handler delete_handler;
72 uint8_t fill_pattern;
73 rtems_sparse_disk_key *key_table;
74};
75
98 const char *device_file_name,
99 uint32_t media_block_size,
100 rtems_blkdev_bnum blocks_with_buffer,
101 rtems_blkdev_bnum media_block_count,
102 uint8_t fill_pattern
103);
104
110void rtems_sparse_disk_free( rtems_sparse_disk *sparse_disk );
111
136 const char *device_file_name,
137 rtems_sparse_disk *sparse_disk,
138 uint32_t media_block_size,
139 rtems_blkdev_bnum blocks_with_buffer,
140 rtems_blkdev_bnum media_block_count,
141 uint8_t fill_pattern,
142 rtems_sparse_disk_delete_handler sparse_disk_delete
143);
144
147#ifdef __cplusplus
148}
149#endif /* __cplusplus */
150
151#endif /* SPARSE_DISK_H */
Block Device Disk Management API.
rtems_status_code
Definition: status.h:85
uint32_t rtems_blkdev_bnum
Block device block index type.
Definition: diskdevs.h:45
rtems_status_code rtems_sparse_disk_create_and_register(const char *device_file_name, uint32_t media_block_size, rtems_blkdev_bnum blocks_with_buffer, rtems_blkdev_bnum media_block_count, uint8_t fill_pattern)
Creates and registers a sparse disk.
Definition: sparse-disk.c:320
rtems_status_code rtems_sparse_disk_register(const char *device_file_name, rtems_sparse_disk *sparse_disk, uint32_t media_block_size, rtems_blkdev_bnum blocks_with_buffer, rtems_blkdev_bnum media_block_count, uint8_t fill_pattern, rtems_sparse_disk_delete_handler sparse_disk_delete)
Initializes and registers a sparse disk.
Definition: sparse-disk.c:350
void rtems_sparse_disk_free(rtems_sparse_disk *sparse_disk)
Frees a sparse disk.
Definition: sparse-disk.c:315
Definition: mutex.h:4
Definition: sparse-disk.h:57
Definition: sparse-disk.h:66
This header file provides the API of Self-Contained Objects.
