RTEMS 6.1
Data Structures | Typedefs | Functions
Sparse disk block device API. More...
#include <stddef.h>
#include <stdint.h>
#include <rtems/diskdevs.h>
#include <rtems/thread.h>
struct  rtems_sparse_disk_key
typedef struct rtems_sparse_disk rtems_sparse_disk
typedef void(* rtems_sparse_disk_delete_handler) (rtems_sparse_disk *sparse_disk)
rtems_status_code rtems_sparse_disk_create_and_register (const char *device_file_name, uint32_t media_block_size, rtems_blkdev_bnum blocks_with_buffer, rtems_blkdev_bnum media_block_count, uint8_t fill_pattern)
 Creates and registers a sparse disk.
void rtems_sparse_disk_free (rtems_sparse_disk *sparse_disk)
 Frees a sparse disk.
rtems_status_code rtems_sparse_disk_register (const char *device_file_name, rtems_sparse_disk *sparse_disk, uint32_t media_block_size, rtems_blkdev_bnum blocks_with_buffer, rtems_blkdev_bnum media_block_count, uint8_t fill_pattern, rtems_sparse_disk_delete_handler sparse_disk_delete)
 Initializes and registers a sparse disk.
