RTEMS 6.1
smplock.h
2
12/*
13 * COPYRIGHT (c) 1989-2011.
14 * On-Line Applications Research Corporation (OAR).
15 *
16 * Copyright (C) 2013, 2016 embedded brains GmbH & Co. KG
17 *
18 * Redistribution and use in source and binary forms, with or without
19 * modification, are permitted provided that the following conditions
20 * are met:
21 * 1. Redistributions of source code must retain the above copyright
22 * notice, this list of conditions and the following disclaimer.
23 * 2. Redistributions in binary form must reproduce the above copyright
24 * notice, this list of conditions and the following disclaimer in the
25 * documentation and/or other materials provided with the distribution.
26 *
27 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
28 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
29 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
30 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
31 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
32 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
33 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
34 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
35 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
36 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
37 * POSSIBILITY OF SUCH DAMAGE.
38 */
39
40#ifndef _RTEMS_SCORE_SMPLOCK_H
41#define _RTEMS_SCORE_SMPLOCK_H
42
43#include <rtems/score/cpuopts.h>
44
64#if defined(RTEMS_SMP)
65
69
70#if defined(RTEMS_DEBUG)
71#include <rtems/score/assert.h>
72#include <rtems/score/smp.h>
73#endif
74
75#ifdef __cplusplus
76extern "C" {
77#endif /* __cplusplus */
78
79#if defined(RTEMS_DEBUG) || defined(RTEMS_PROFILING)
80#define RTEMS_SMP_LOCK_DO_NOT_INLINE
81#endif
82
86typedef struct {
87 SMP_ticket_lock_Control Ticket_lock;
88#if defined(RTEMS_DEBUG)
101 uint32_t owner;
102#endif
103#if defined(RTEMS_PROFILING)
104 SMP_lock_Stats Stats;
105#endif
106} SMP_lock_Control;
107
111typedef struct {
112 ISR_Level isr_level;
113#if defined(RTEMS_DEBUG)
114 SMP_lock_Control *lock_used_for_acquire;
115#endif
116#if defined(RTEMS_PROFILING)
117 SMP_lock_Stats_context Stats_context;
118#endif
119} SMP_lock_Context;
120
121#if defined(RTEMS_DEBUG)
122#define SMP_LOCK_NO_OWNER 0
123#endif
124
128#if defined(RTEMS_DEBUG) && defined(RTEMS_PROFILING)
129 #define SMP_LOCK_INITIALIZER( name ) \
130 { \
131 SMP_TICKET_LOCK_INITIALIZER, \
132 SMP_LOCK_NO_OWNER, \
133 SMP_LOCK_STATS_INITIALIZER( name ) \
134 }
135#elif defined(RTEMS_DEBUG)
136 #define SMP_LOCK_INITIALIZER( name ) \
137 { SMP_TICKET_LOCK_INITIALIZER, SMP_LOCK_NO_OWNER }
138#elif defined(RTEMS_PROFILING)
139 #define SMP_LOCK_INITIALIZER( name ) \
140 { SMP_TICKET_LOCK_INITIALIZER, SMP_LOCK_STATS_INITIALIZER( name ) }
141#else
142 #define SMP_LOCK_INITIALIZER( name ) { SMP_TICKET_LOCK_INITIALIZER }
143#endif
144
150static inline void _SMP_lock_Initialize_inline(
151 SMP_lock_Control *lock,
152 const char *name
153)
154{
155 _SMP_ticket_lock_Initialize( &lock->Ticket_lock );
156#if defined(RTEMS_DEBUG)
157 lock->owner = SMP_LOCK_NO_OWNER;
158#endif
159#if defined(RTEMS_PROFILING)
160 _SMP_lock_Stats_initialize( &lock->Stats, name );
161#else
162 (void) name;
163#endif
164}
165
175#if defined(RTEMS_SMP_LOCK_DO_NOT_INLINE)
176void _SMP_lock_Initialize(
177 SMP_lock_Control *lock,
178 const char *name
179);
180#else
181#define _SMP_lock_Initialize( lock, name ) \
182 _SMP_lock_Initialize_inline( lock, name )
183#endif
184
190static inline void _SMP_lock_Destroy_inline( SMP_lock_Control *lock )
191{
192 _SMP_ticket_lock_Destroy( &lock->Ticket_lock );
193 _SMP_lock_Stats_destroy( &lock->Stats );
194}
195
203#if defined(RTEMS_SMP_LOCK_DO_NOT_INLINE)
204void _SMP_lock_Destroy( SMP_lock_Control *lock );
205#else
206#define _SMP_lock_Destroy( lock ) \
207 _SMP_lock_Destroy_inline( lock )
208#endif
209
217static inline void _SMP_lock_Set_name(
218 SMP_lock_Control *lock,
219 const char *name
220)
221{
222#if defined(RTEMS_PROFILING)
223 lock->Stats.name = name;
224#else
225 (void) lock;
226 (void) name;
227#endif
228}
229
235#if defined(RTEMS_DEBUG)
236static inline uint32_t _SMP_lock_Who_am_I( void )
237{
238 /*
239 * The CPU index starts with zero. Increment it by one, to allow global SMP
240 * locks to reside in the BSS section.
241 */
242 return _SMP_Get_current_processor() + 1;
243}
244#endif
245
252static inline void _SMP_lock_Acquire_inline(
253 SMP_lock_Control *lock,
254 SMP_lock_Context *context
255)
256{
257#if defined(RTEMS_DEBUG)
258 context->lock_used_for_acquire = lock;
259#else
260 (void) context;
261#endif
262 _SMP_ticket_lock_Acquire(
263 &lock->Ticket_lock,
264 &lock->Stats,
265 &context->Stats_context
266 );
267#if defined(RTEMS_DEBUG)
268 lock->owner = _SMP_lock_Who_am_I();
269#endif
270}
271
283void _SMP_lock_Acquire(
284 SMP_lock_Control *lock,
285 SMP_lock_Context *context
286);
287
294static inline void _SMP_lock_Release_inline(
295 SMP_lock_Control *lock,
296 SMP_lock_Context *context
297)
298{
299#if defined(RTEMS_DEBUG)
300 _Assert( context->lock_used_for_acquire == lock );
301 context->lock_used_for_acquire = NULL;
302 _Assert( lock->owner == _SMP_lock_Who_am_I() );
303 lock->owner = SMP_LOCK_NO_OWNER;
304#else
305 (void) context;
306#endif
307 _SMP_ticket_lock_Release(
308 &lock->Ticket_lock,
309 &context->Stats_context
310 );
311}
312
320#if defined(RTEMS_SMP_LOCK_DO_NOT_INLINE)
321void _SMP_lock_Release(
322 SMP_lock_Control *lock,
323 SMP_lock_Context *context
324);
325#else
326#define _SMP_lock_Release( lock, context ) \
327 _SMP_lock_Release_inline( lock, context )
328#endif
329
336static inline void _SMP_lock_ISR_disable_and_acquire_inline(
337 SMP_lock_Control *lock,
338 SMP_lock_Context *context
339)
340{
341 _ISR_Local_disable( context->isr_level );
342 _SMP_lock_Acquire_inline( lock, context );
343}
344
352void _SMP_lock_ISR_disable_and_acquire(
353 SMP_lock_Control *lock,
354 SMP_lock_Context *context
355);
356
363static inline void _SMP_lock_Release_and_ISR_enable_inline(
364 SMP_lock_Control *lock,
365 SMP_lock_Context *context
366)
367{
368 _SMP_lock_Release_inline( lock, context );
369 _ISR_Local_enable( context->isr_level );
370}
371
379#if defined(RTEMS_SMP_LOCK_DO_NOT_INLINE)
380void _SMP_lock_Release_and_ISR_enable(
381 SMP_lock_Control *lock,
382 SMP_lock_Context *context
383);
384#else
385#define _SMP_lock_Release_and_ISR_enable( lock, context ) \
386 _SMP_lock_Release_and_ISR_enable_inline( lock, context )
387#endif
388
389#if defined(RTEMS_DEBUG)
398bool _SMP_lock_Is_owner( const SMP_lock_Control *lock );
399#endif
400
403#ifdef __cplusplus
404}
405#endif /* __cplusplus */
406
407#endif /* RTEMS_SMP */
408
409#endif /* _RTEMS_SCORE_SMPLOCK_H */
This header file provides the interfaces of the Assert Handler.
This header file provides interfaces of the SMP Support which are used by the implementation and the ...
#define _Assert(_e)
Assertion similar to assert() controlled via RTEMS_DEBUG instead of NDEBUG and static analysis runs.
Definition: assert.h:96
#define _ISR_Local_disable(_level)
Disables interrupts on this processor.
Definition: isrlevel.h:76
#define _ISR_Local_enable(_level)
Enables interrupts on this processor.
Definition: isrlevel.h:93
uint32_t ISR_Level
Definition: isrlevel.h:60
This header file provides the ISR_Level related interfaces of the ISR Handler.
rtems_termios_device_context * context
Definition: console-config.c:62
This header file provides the interfaces of the SMP Locks related to lock statistics.
This header file provides the interfaces of the SMP Locks related to ticket locks.
