RTEMS 6.1
This header file defines the Semaphore Manager API. More...
#include <stdint.h>#include <rtems/rtems/attr.h>#include <rtems/rtems/options.h>#include <rtems/rtems/status.h>#include <rtems/rtems/types.h>Go to the source code of this file.
| rtems_status_code | rtems_semaphore_create (rtems_name name, uint32_t count, rtems_attribute attribute_set, rtems_task_priority priority_ceiling, rtems_id *id) |
| Creates a semaphore. | |
| rtems_status_code | rtems_semaphore_ident (rtems_name name, uint32_t node, rtems_id *id) |
| Identifies a semaphore by the object name. | |
| rtems_status_code | rtems_semaphore_delete (rtems_id id) |
| Deletes the semaphore. | |
| rtems_status_code | rtems_semaphore_obtain (rtems_id id, rtems_option option_set, rtems_interval timeout) |
| Obtains the semaphore. | |
| rtems_status_code | rtems_semaphore_release (rtems_id id) |
| Releases the semaphore. | |
| rtems_status_code | rtems_semaphore_flush (rtems_id id) |
| Flushes the semaphore. | |
| rtems_status_code | rtems_semaphore_set_priority (rtems_id semaphore_id, rtems_id scheduler_id, rtems_task_priority new_priority, rtems_task_priority *old_priority) |
| Sets the priority by scheduler for the semaphore. | |
