RTEMS 6.1
options.h
2
11/*
12 * Copyright (C) 2020 embedded brains GmbH & Co. KG
13 * Copyright (C) 1989, 2008 On-Line Applications Research Corporation (OAR)
14 *
16 * modification, are permitted provided that the following conditions
17 * are met:
18 * 1. Redistributions of source code must retain the above copyright
19 * notice, this list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright
21 * notice, this list of conditions and the following disclaimer in the
22 * documentation and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34 * POSSIBILITY OF SUCH DAMAGE.
35 */
36
37/*
38 * This file is part of the RTEMS quality process and was automatically
39 * generated. If you find something that needs to be fixed or
40 * worded better please post a report or patch to an RTEMS mailing list
41 * or raise a bug report:
42 *
43 * https://www.rtems.org/bugs.html
44 *
45 * For information on updating and regenerating please refer to the How-To
46 * section in the Software Requirements Engineering chapter of the
47 * RTEMS Software Engineering manual. The manual is provided as a part of
48 * a release. For development sources please refer to the online
49 * documentation at:
50 *
51 * https://docs.rtems.org
52 */
53
54/* Generated from spec:/rtems/option/if/header */
55
56#ifndef _RTEMS_RTEMS_OPTIONS_H
57#define _RTEMS_RTEMS_OPTIONS_H
58
59#include <stdint.h>
60
61#ifdef __cplusplus
62extern "C" {
63#endif
64
65/* Generated from spec:/rtems/option/if/group */
66
75/* Generated from spec:/rtems/option/if/default */
76
82#define RTEMS_DEFAULT_OPTIONS 0x00000000
83
84/* Generated from spec:/rtems/option/if/event-all */
85
93#define RTEMS_EVENT_ALL 0x00000000
94
95/* Generated from spec:/rtems/option/if/event-any */
96
104#define RTEMS_EVENT_ANY 0x00000002
105
106/* Generated from spec:/rtems/option/if/no-wait */
107
117#define RTEMS_NO_WAIT 0x00000001
118
119/* Generated from spec:/rtems/option/if/option */
120
126typedef uint32_t rtems_option;
127
128/* Generated from spec:/rtems/option/if/wait */
129
139#define RTEMS_WAIT 0x00000000
140
141#ifdef __cplusplus
142}
143#endif
144
145#endif /* _RTEMS_RTEMS_OPTIONS_H */
This type represents a Classic API directive option set.
Definition: options.h:126
