RTEMS 6.1
RTEMS Run-Time Link Editor Shell Commands. More...
#include <inttypes.h>#include <sys/stat.h>#include <regex.h>#include <string.h>#include <dlfcn.h>#include <rtems/printer.h>#include <rtems/rtl/rtl.h>#include <rtems/rtl/rtl-archive.h>#include <rtems/rtl/rtl-shell.h>#include <rtems/rtl/rtl-trace.h>#include "rtl-chain-iterator.h"Data Structures | |
| struct | rtems_rtl_shell_cmd |
| struct | rtems_rtl_obj_summary |
| struct | rtems_rtl_obj_print |
| struct | rtems_rtl_dep_data |
| #define | SYM_DUPLICATE (((size_t) 1) << ((8 * sizeof (size_t)) - 1)) |
| #define | CALL_ARG_COUNT (4) |
Typedefs | |
| typedef int(* | rtems_rtl_shell_handler) (const rtems_printer *printer, int argc, char *argv[]) |
| int | rtems_rtl_shell_list (const rtems_printer *printer, int argc, char *argv[]) |
| int | rtems_rtl_shell_sym (const rtems_printer *printer, int argc, char *argv[]) |
| int | rtems_rtl_shell_object (const rtems_printer *printer, int argc, char *argv[]) |
| int | rtems_rtl_shell_archive (const rtems_printer *printer, int argc, char *argv[]) |
| int | rtems_rtl_shell_call (const rtems_printer *printer, int argc, char *argv[]) |
| int | rtems_rtl_shell_command (int argc, char *argv[]) |
A simple RTL command to aid using the RTL.
| typedef int(* rtems_rtl_shell_handler) (const rtems_printer *printer, int argc, char *argv[]) |
The type of the shell handlers we have.
| int rtems_rtl_shell_archive | ( | const rtems_printer * | printer, |
| int | argc, | ||
| char * | argv[] | ||
Archive files.
| int rtems_rtl_shell_call | ( | const rtems_printer * | printer, |
| int | argc, | ||
Call text symbol.
| int rtems_rtl_shell_command | ( | int | argc, |
The RTL single shell command contains sub-commands.
| argc | The argument count. |
| argv | Array of argument strings. |
| 0 | No error. |
| int rtems_rtl_shell_list | ( | const rtems_printer * | printer, |
| int | argc, | ||
List object files.
| int rtems_rtl_shell_object | ( | const rtems_printer * | printer, |
| int | argc, | ||
Object files.
| int rtems_rtl_shell_sym | ( | const rtems_printer * | printer, |
| int | argc, | ||
Symbols.
