RTEMS 6.1
rtl-shell.h
2
3/*
4 * COPYRIGHT (c) 2012 Chris Johns <chrisj@rtems.org>
5 *
6 * Redistribution and use in source and binary forms, with or without
7 * modification, are permitted provided that the following conditions
8 * are met:
9 * 1. Redistributions of source code must retain the above copyright
10 * notice, this list of conditions and the following disclaimer.
11 * 2. Redistributions in binary form must reproduce the above copyright
12 * notice, this list of conditions and the following disclaimer in the
13 * documentation and/or other materials provided with the distribution.
14 *
15 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
16 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
17 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
18 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
19 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
20 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
21 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
22 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
23 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
24 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
25 * POSSIBILITY OF SUCH DAMAGE.
26 */
35#if !defined (_RTEMS_RTL_SHELL_H_)
36#define _RTEMS_RTL_SHELL_H_
37
38#include <rtems/print.h>
39
40#ifdef __cplusplus
41extern "C" {
42#endif /* __cplusplus */
43
52int rtems_rtl_shell_command (int argc, char* argv[]);
53
57int rtems_rtl_shell_list (const rtems_printer* printer, int argc, char* argv[]);
58
62int rtems_rtl_shell_sym (const rtems_printer* printer, int argc, char* argv[]);
63
67int rtems_rtl_shell_object (const rtems_printer* printer, int argc, char* argv[]);
68
69
73int rtems_rtl_shell_archive (const rtems_printer* printer, int argc, char* argv[]);
74
78int rtems_rtl_shell_call (const rtems_printer* printer, int argc, char* argv[]);
79
80#ifdef __cplusplus
81}
82#endif /* __cplusplus */
83
84#endif
User print interface to the bspIO print plug in.
int rtems_rtl_shell_list(const rtems_printer *printer, int argc, char *argv[])
Definition: rtl-shell.c:617
int rtems_rtl_shell_sym(const rtems_printer *printer, int argc, char *argv[])
Definition: rtl-shell.c:660
int rtems_rtl_shell_archive(const rtems_printer *printer, int argc, char *argv[])
Definition: rtl-shell.c:811
int rtems_rtl_shell_call(const rtems_printer *printer, int argc, char *argv[])
Definition: rtl-shell.c:997
int rtems_rtl_shell_command(int argc, char *argv[])
Definition: rtl-shell.c:1194
int rtems_rtl_shell_object(const rtems_printer *printer, int argc, char *argv[])
Definition: rtl-shell.c:698
Definition: printer.h:76
