RTEMS 6.1
rtl-elf.c File Reference
RTEMS Run-Time Link Editor. More...
#include <fcntl.h>
#include <inttypes.h>
#include <unistd.h>
#include <rtems/rtl/rtl.h>
#include "rtl-elf.h"
#include "rtl-error.h"
#include <rtems/rtl/rtl-trace.h>
#include "rtl-trampoline.h"
#include "rtl-unwind.h"
#include <rtems/rtl/rtl-unresolved.h>
struct  rtems_rtl_elf_reloc_data
struct  rtems_rtl_elf_common_data
struct  rtems_rtl_tramp_data
#define REL_R_OFFSET   (0)
#define REL_R_INFO   (1)
#define REL_R_ADDEND   (2)
#define SEPARATED_PREFIX(_p)   { _p, sizeof (_p) - 1 }
typedef bool(* rtems_rtl_elf_reloc_handler) (rtems_rtl_obj *obj, bool is_rela, void *relbuf, rtems_rtl_obj_sect *targetsect, rtems_rtl_obj_sym *symbol, Elf_Sym *sym, const char *symname, Elf_Word symvalue, bool resolved, void *data)
typedef struct rtems_rtl_tramp_data rtems_rtl_tramp_data
bool rtems_rtl_obj_relocate_unresolved (rtems_rtl_unresolv_reloc *reloc, rtems_rtl_obj_sym *sym)
bool rtems_rtl_elf_file_check (rtems_rtl_obj *obj, int fd)
bool rtems_rtl_elf_file_load (rtems_rtl_obj *obj, int fd)
bool rtems_rtl_elf_file_unload (rtems_rtl_obj *obj)
rtems_rtl_loader_formatrtems_rtl_elf_file_sig (void)
This is the RTL implementation.
◆ REL_R_OFFSET
The offsets in the reloc words.
Typedef Documentation
◆ rtems_rtl_elf_reloc_handler
Relocation worker routine.
◆ rtems_rtl_tramp_data
Struct to handle trampoline reloc recs in the unresolved table.
◆ rtems_rtl_elf_file_check()
bool rtems_rtl_elf_file_check ( rtems_rtl_obj obj,
int  fd
The ELF format check handler.
Parameters
objThe object being checked.
fdThe file descriptor.
◆ rtems_rtl_elf_file_load()
bool rtems_rtl_elf_file_load ( rtems_rtl_obj obj,
int  fd
The ELF format load handler.
Parameters
objThe object to load.
◆ rtems_rtl_elf_file_sig()
rtems_rtl_loader_format * rtems_rtl_elf_file_sig ( void  )
The ELF format signature handler.
Returns
rtems_rtl_loader_format* The format's signature.
◆ rtems_rtl_elf_file_unload()
bool rtems_rtl_elf_file_unload ( rtems_rtl_obj obj)
The ELF format unload handler.
Parameters
objThe object to unload.
◆ rtems_rtl_obj_relocate_unresolved()
bool rtems_rtl_obj_relocate_unresolved ( rtems_rtl_unresolv_reloc reloc,
rtems_rtl_obj_sym sym
Relocate an object file's unresolved reference.
Parameters
recThe unresolved relocation record.
symThe unresolved relocation's referenced symbol.
Return values
trueThe object file record was relocated.
falseThe relocation failed. The RTL error is set.
