RTEMS 6.1
#include <rtl-obj.h>
Data Fields | |
| rtems_chain_node | node |
| int | section |
| const char * | name |
| size_t | size |
| off_t | offset |
| uint32_t | alignment |
| int | link |
| int | info |
| uint32_t | flags |
| void * | base |
| int | load_order |
An object file is made up of sections and the can be more than one of a specific type of sections. All sections and grouped together in memory.
| uint32_t rtems_rtl_obj_sect::alignment |
Alignment of this section.
| void* rtems_rtl_obj_sect::base |
The base address of the section in memory.
| uint32_t rtems_rtl_obj_sect::flags |
The section's flags.
| int rtems_rtl_obj_sect::info |
Secfion info field.
| int rtems_rtl_obj_sect::link |
Section link field.
| int rtems_rtl_obj_sect::load_order |
Order we load sections.
| const char* rtems_rtl_obj_sect::name |
The section's name.
| rtems_chain_node rtems_rtl_obj_sect::node |
The node's link in the chain.
| off_t rtems_rtl_obj_sect::offset |
Offset into the object file. Relative to the start of the object file.
| int rtems_rtl_obj_sect::section |
The section number.
| size_t rtems_rtl_obj_sect::size |
The size of the section in memory.
