RTEMS 6.1
RTEMS Flattened Device Tree Shell Command. More...
#include <rtems/rtems-fdt.h>Go to the source code of this file.
Typedefs | |
| typedef void(* | rtems_fdt_write_handler) (uintptr_t address, uint32_t value) |
| typedef uint32_t(* | rtems_fdt_read_handler) (uintptr_t address) |
| void | rtems_fdt_add_shell_command (void) |
| rtems_fdt_handle * | rtems_fdt_get_shell_handle (void) |
| rtems_fdt_write_handler | rtems_fdt_set_shell_write_handler (rtems_fdt_write_handler handler) |
| rtems_fdt_read_handler | rtems_fdt_set_shell_read_handler (rtems_fdt_read_handler handler) |
Support for loading, managing and accessing FDT blobs in RTEMS.
| typedef uint32_t(* rtems_fdt_read_handler) (uintptr_t address) |
Read handler call to read from the address property.
| typedef void(* rtems_fdt_write_handler) (uintptr_t address, uint32_t value) |
Write handler call to write from the address property.
| void rtems_fdt_add_shell_command | ( | void | ) |
Add a shell command to access memory and registers associated with the DTF.
| rtems_fdt_handle * rtems_fdt_get_shell_handle | ( | void | ) |
Get a pointer to the handle. You can use this to load files or register blobs and have the shell command access them.
| rtems_fdt_read_handler rtems_fdt_set_shell_read_handler | ( | rtems_fdt_read_handler | handler | ) |
Set the read handler returning the current handler.
| rtems_fdt_write_handler rtems_fdt_set_shell_write_handler | ( | rtems_fdt_write_handler | handler | ) |
Set the write handler returning the current handler.
