RTEMS 6.1
rtems-fdt-shell.h
2
3/*
4 * COPYRIGHT (c) 2013-2017 Chris Johns <chrisj@rtems.org>
5 *
6 * Redistribution and use in source and binary forms, with or without
7 * modification, are permitted provided that the following conditions
8 * are met:
9 * 1. Redistributions of source code must retain the above copyright
10 * notice, this list of conditions and the following disclaimer.
11 * 2. Redistributions in binary form must reproduce the above copyright
12 * notice, this list of conditions and the following disclaimer in the
13 * documentation and/or other materials provided with the distribution.
14 *
15 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
16 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
17 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
18 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
19 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
20 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
21 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
22 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
23 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
24 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
25 * POSSIBILITY OF SUCH DAMAGE.
26 */
37#if !defined (_RTEMS_FDT_SHELL_H_)
38#define _RTEMS_FDT_SHELL_H_
39
40#include <rtems/rtems-fdt.h>
41
42#ifdef __cplusplus
43extern "C" {
44#endif /* __cplusplus */
45
50
56
60typedef void (*rtems_fdt_write_handler)(uintptr_t address, uint32_t value);
61
65typedef uint32_t (*rtems_fdt_read_handler)(uintptr_t address);
66
72
78
79#ifdef __cplusplus
80}
81#endif /* __cplusplus */
82
83#endif
rtems_fdt_handle * rtems_fdt_get_shell_handle(void)
Definition: rtems-fdt-shell.c:806
uint32_t(* rtems_fdt_read_handler)(uintptr_t address)
Definition: rtems-fdt-shell.h:65
rtems_fdt_read_handler rtems_fdt_set_shell_read_handler(rtems_fdt_read_handler handler)
Definition: rtems-fdt-shell.c:820
rtems_fdt_write_handler rtems_fdt_set_shell_write_handler(rtems_fdt_write_handler handler)
Definition: rtems-fdt-shell.c:812
void(* rtems_fdt_write_handler)(uintptr_t address, uint32_t value)
Definition: rtems-fdt-shell.h:60
void rtems_fdt_add_shell_command(void)
Definition: rtems-fdt-shell.c:799
RTEMS Flattened Device Tree.
Definition: rtems-fdt.h:63
