RTEMS 6.1
cpu.h File Reference
#include <rtems/score/or1k.h>
#include <rtems/score/or1k-utility.h>
struct  Context_Control
 Thread register context. More...
struct  CPU_Exception_frame
 The set of registers that specifies the complete processor state. More...
#define CPU_ISR_PASSES_FRAME_POINTER   TRUE
#define CPU_HARDWARE_FP   FALSE
#define CPU_SOFTWARE_FP   FALSE
#define CPU_ALL_TASKS_ARE_FP   FALSE
#define CPU_IDLE_TASK_IS_FP   FALSE
#define CPU_USE_DEFERRED_FP_SWITCH   TRUE
#define CPU_ENABLE_ROBUST_THREAD_DISPATCH   FALSE
#define CPU_STACK_GROWS_UP   FALSE
#define CPU_CACHE_LINE_BYTES   32
#define CPU_STRUCTURE_ALIGNMENT   RTEMS_ALIGNED( CPU_CACHE_LINE_BYTES )
#define CPU_MODES_INTERRUPT_MASK   0x00000001
#define or1kreg   uint32_t
#define _CPU_Context_Get_SP(_context)    (_context)->r1
#define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK   0
#define CPU_STACK_MINIMUM_SIZE   4096
#define CPU_ALIGNMENT   8
#define CPU_PROVIDES_ISR_IS_IN_PROGRESS   FALSE
#define CPU_SIZEOF_POINTER   4
#define CPU_HEAP_ALIGNMENT   CPU_ALIGNMENT
#define CPU_STACK_ALIGNMENT   CPU_ALIGNMENT
#define CPU_INTERRUPT_STACK_ALIGNMENT   CPU_CACHE_LINE_BYTES
#define _CPU_ISR_Disable(_level)    _level = or1k_interrupt_disable()
#define _CPU_ISR_Enable(_level)    or1k_interrupt_enable( _level )
#define _CPU_ISR_Flash(_level)
#define OR1K_FAST_CONTEXT_SWITCH_ENABLED   FALSE
#define _CPU_Context_Restart_self(_the_context)    _CPU_Context_restore( (_the_context) );
#define CPU_USE_GENERIC_BITFIELD_CODE   TRUE
#define CPU_USE_LIBC_INIT_FINI_ARRAY   TRUE
#define CPU_MAXIMUM_PROCESSORS   32
#define CPU_swap_u16(value)    (((value&0xff) << 8) | ((value >> 8)&0xff))
typedef Context_Control CPU_Interrupt_frame
typedef void(* CPU_ISR_raw_handler) (uint32_t, CPU_Exception_frame *)
typedef void(* CPU_ISR_handler) (uint32_t)
typedef uint32_t CPU_Counter_ticks
typedef uintptr_t CPU_Uint32ptr
void _CPU_ISR_Set_level (uint32_t level)
 Sets the interrupt level for the executing thread.
uint32_t _CPU_ISR_Get_level (void)
 Returns the interrupt level of the executing thread.
void _CPU_Context_Initialize (Context_Control *context, void *stack_area_begin, size_t stack_area_size, uint32_t new_level, void(*entry_point)(void), bool is_fp, void *tls_area)
 Initializes the CPU context.
void _CPU_Exception_frame_print (const CPU_Exception_frame *frame)
 Prints the exception frame via printk().
void _CPU_Initialize (void)
 CPU initialization.
void _CPU_ISR_install_raw_handler (uint32_t vector, CPU_ISR_raw_handler new_handler, CPU_ISR_raw_handler *old_handler)
RTEMS_NO_RETURN void * _CPU_Thread_Idle_body (uintptr_t ignored)
void _CPU_Context_switch (Context_Control *run, Context_Control *heir)
 CPU switch context.
RTEMS_NO_RETURN void _CPU_Context_restore (Context_Control *new_context)
void _CPU_Context_save_fp (void **fp_context_ptr)
void _CPU_Context_restore_fp (void **fp_context_ptr)
uint32_t _CPU_Counter_frequency (void)
 Gets the current CPU counter frequency in Hz.
CPU_Counter_ticks _CPU_Counter_read (void)
 Gets the current CPU counter value.
◆ _CPU_ISR_Flash
#define _CPU_ISR_Flash (   _level)
Value:
do{ \
_CPU_ISR_Enable( _level ); \
_OR1K_mtspr(CPU_OR1K_SPR_SR, (_level & ~CPU_OR1K_SPR_SR_IEE)); \
} while(0)
◆ CPU_SIZEOF_POINTER [1/2]
Size of a pointer.
This must be an integer literal that can be used by the assembler. This value will be used to calculate offsets of structure members. These offsets will be used in assembler code.
◆ CPU_SIZEOF_POINTER [2/2]
Size of a pointer.
Typedef Documentation
◆ CPU_Uint32ptr
Type that can store a 32-bit integer or a pointer.
