RTEMS 6.1
nvdisk.h File Reference
Non-volatile Disk Block Device Implementation. More...
#include <stdint.h>
#include <sys/ioctl.h>
struct  rtems_nvdisk_monitor_data
struct  rtems_nvdisk_driver_handlers
struct  rtems_nvdisk_device_desc
struct  rtems_nvdisk_config
#define RTEMS_NVDISK_DEVICE_BASE_NAME   "/dev/nvd"
#define RTEMS_NVDISK_IOCTL_ERASE_DISK   _IO('B', 128)
#define RTEMS_NVDISK_IOCTL_MONITORING   _IO('B', 129)
#define RTEMS_NVDISK_IOCTL_INFO_LEVEL   _IO('B', 130)
#define RTEMS_NVDISK_IOCTL_PRINT_STATUS   _IO('B', 131)
#define RTEMS_NVDISK_KBYTES(_k)   ((_k) * 1024)
#define RTEMS_NVDISK_CHECK_PAGES   (1 << 0)
typedef struct rtems_nvdisk_monitor_data rtems_nvdisk_monitor_data
typedef struct rtems_nvdisk_driver_handlers rtems_nvdisk_driver_handlers
typedef struct rtems_nvdisk_device_desc rtems_nvdisk_device_desc
typedef struct rtems_nvdisk_config rtems_nvdisk_config
rtems_device_driver rtems_nvdisk_initialize (rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
const rtems_nvdisk_config rtems_nvdisk_configuration []
uint32_t rtems_nvdisk_configuration_size
◆ RTEMS_NVDISK_CHECK_PAGES
Check the pages during initialisation to see which pages are valid and which are not. This could slow down initialising the disk driver.
◆ RTEMS_NVDISK_DEVICE_BASE_NAME
The Non-volatile disk provides a simple directly mapped disk driver with checksums for each. It is designed to provied a disk that can survive a restart. Examples are EEPROM devices which have byte writeable locations, or a battery backed up RAM disk.
The low level driver provides the physical access to the hardware. The base name of the nv disks.
◆ RTEMS_NVDISK_IOCTL_ERASE_DISK
NV disk specific ioctl request types. To use open the device and issue the ioctl call.
int fd = open ("/dev/nvdisk0", O_WRONLY, 0);
if (fd < 0)
printf ("driver open failed: %s\n", strerror (errno));
exit (1);
if (ioctl (fd, RTEMS_NVDISK_IOCTL_ERASE_DISK) < 0)
printf ("driver erase failed: %s\n", strerror (errno));
exit (1);
close (fd);
Definition: nvdisk.h:80
int open(const char *path, int oflag,...)
Definition: open.c:181
◆ RTEMS_NVDISK_KBYTES
#define RTEMS_NVDISK_KBYTES (   _k)    ((_k) * 1024)
Return the number of kilo-bytes.
Typedef Documentation
◆ rtems_nvdisk_config
RTEMS Non-Volatile Disk configuration table used to initialise the driver.
◆ rtems_nvdisk_device_desc
NV Device Descriptor holds the description of a device that is part of the NV disk.
Typically this structure is part of a table of the device which is referenced in the nvdisk configuration table. The reference is kept in the driver and used all the time to manage the nv device, therefore it must always exist.
◆ rtems_nvdisk_driver_handlers
NV Low Level driver handlers.
Typically this structure is part of a table of handlers in the device which is referenced in the nvdisk configuration table. The reference is kept in the driver and used all the time to manage the nv device, therefore it must always exist.
◆ rtems_nvdisk_monitor_data
NV Disk Monitoring Data allows a user to obtain the current status of the disk.
◆ rtems_nvdisk_initialize()
rtems_device_driver rtems_nvdisk_initialize ( rtems_device_major_number  major,
void *  arg
Non-volatile disk device driver initialization. Place in a table as the initialisation entry and remainder of the entries are the RTEMS block device generic handlers.
Parameters
majorNV disk major device number.
minorMinor device number, not applicable.
argInitialization argument, not applicable.
Returns
The rtems_device_driver is actually just rtems_status_code.
Variable Documentation
◆ rtems_nvdisk_configuration
const rtems_nvdisk_config rtems_nvdisk_configuration[]
extern
External reference to the configuration. Please supply. Support is present in confdefs.h for providing this variable.
◆ rtems_nvdisk_configuration_size
extern
External reference to the number of configurations. Please supply. Support is present in confdefs.h for providing this variable.
