RTEMS 6.1
rtems_nvdisk_device_desc Struct Reference
#include <nvdisk.h>
uint32_t flags
void * base
uint32_t size
const rtems_nvdisk_driver_handlersnv_ops
NV Device Descriptor holds the description of a device that is part of the NV disk.
Typically this structure is part of a table of the device which is referenced in the nvdisk configuration table. The reference is kept in the driver and used all the time to manage the nv device, therefore it must always exist.
Field Documentation
◆ base
void* rtems_nvdisk_device_desc::base
Base address of the device.
◆ flags
uint32_t rtems_nvdisk_device_desc::flags
Private user flags.
◆ nv_ops
const rtems_nvdisk_driver_handlers* rtems_nvdisk_device_desc::nv_ops
Device handlers.
◆ size
uint32_t rtems_nvdisk_device_desc::size
Size of the device.
