RTEMS 6.1
cpu.h File Reference
#include <rtems/score/nios2.h>
struct  Context_Control
 Thread register context. More...
struct  CPU_Exception_frame
 The set of registers that specifies the complete processor state. More...
#define CPU_SIMPLE_VECTORED_INTERRUPTS   TRUE
#define CPU_INTERRUPT_NUMBER_OF_VECTORS   32
#define CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER   (CPU_INTERRUPT_NUMBER_OF_VECTORS - 1)
#define CPU_PROVIDES_ISR_IS_IN_PROGRESS   TRUE
#define CPU_ISR_PASSES_FRAME_POINTER   FALSE
#define CPU_HARDWARE_FP   FALSE
#define CPU_SOFTWARE_FP   FALSE
#define CPU_ALL_TASKS_ARE_FP   FALSE
#define CPU_IDLE_TASK_IS_FP   FALSE
#define CPU_USE_DEFERRED_FP_SWITCH   FALSE
#define CPU_ENABLE_ROBUST_THREAD_DISPATCH   FALSE
#define CPU_STACK_GROWS_UP   FALSE
#define CPU_CACHE_LINE_BYTES   32
#define CPU_STRUCTURE_ALIGNMENT    RTEMS_SECTION( ".sdata" ) RTEMS_ALIGNED( CPU_CACHE_LINE_BYTES )
#define CPU_STACK_MINIMUM_SIZE   (4 * 1024)
#define CPU_SIZEOF_POINTER   4
#define CPU_ALIGNMENT   4
#define CPU_HEAP_ALIGNMENT   CPU_ALIGNMENT
#define CPU_STACK_ALIGNMENT   4
#define CPU_INTERRUPT_STACK_ALIGNMENT   CPU_CACHE_LINE_BYTES
#define CPU_MODES_INTERRUPT_MASK   0x3f
#define CPU_USE_GENERIC_BITFIELD_CODE   TRUE
#define CPU_USE_LIBC_INIT_FINI_ARRAY   FALSE
#define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK   0
#define CPU_MAXIMUM_PROCESSORS   32
#define _CPU_Context_Get_SP(_context)    (_context)->sp
#define _CPU_ISR_Disable(_isr_cookie)
 Macro to disable interrupts.
#define _CPU_ISR_Enable(_isr_cookie)    __builtin_wrctl( 0, (int) _isr_cookie )
 Macro to restore the processor status.
#define _CPU_ISR_Flash(_isr_cookie)
 Macro to restore the processor status and disable the interrupts again.
#define _CPU_Context_Restart_self(_the_context)    _CPU_Context_restore( (_the_context) );
#define CPU_swap_u16(value)    (((value&0xff) << 8) | ((value >> 8)&0xff))
typedef void CPU_Interrupt_frame
typedef void(* CPU_ISR_handler) (uint32_t)
typedef uint32_t CPU_Counter_ticks
typedef uintptr_t CPU_Uint32ptr
bool _CPU_ISR_Is_enabled (uint32_t level)
void _CPU_ISR_Set_level (uint32_t new_level)
 Sets the interrupt level for the executing thread.
uint32_t _CPU_ISR_Get_level (void)
 Returns the interrupt level of the executing thread.
void _CPU_Context_Initialize (Context_Control *context, void *stack_area_begin, size_t stack_area_size, uint32_t new_level, void(*entry_point)(void), bool is_fp, void *tls_area)
 Initializes the CPU context.
void _CPU_Initialize (void)
 CPU initialization.
void _CPU_ISR_install_vector (uint32_t vector, CPU_ISR_handler new_handler, CPU_ISR_handler *old_handler)
RTEMS_NO_RETURN void * _CPU_Thread_Idle_body (uintptr_t ignored)
void _CPU_Context_switch (Context_Control *run, Context_Control *heir)
 CPU switch context.
RTEMS_NO_RETURN void _CPU_Context_restore (Context_Control *new_context)
void _CPU_Exception_frame_print (const CPU_Exception_frame *frame)
 Prints the exception frame via printk().
uint32_t _CPU_Counter_frequency (void)
CPU_Counter_ticks _CPU_Counter_read (void)
◆ _CPU_ISR_Disable
#define _CPU_ISR_Disable (   _isr_cookie)
Value:
do { \
int _tmp; \
__asm__ volatile ( \
"rdctl %0, status\n" \
"movhi %1, %%hiadj(_Nios2_ISR_Status_mask)\n" \
"addi %1, %1, %%lo(_Nios2_ISR_Status_mask)\n" \
"and %1, %0, %1\n" \
"ori %1, %1, %%lo(_Nios2_ISR_Status_bits)\n" \
"wrctl status, %1" \
: "=&r" (_isr_cookie), "=&r" (_tmp) \
} while ( 0 )
The processor status before disabling the interrupts will be stored in _isr_cookie. This value will be used in _CPU_ISR_Flash() and _CPU_ISR_Enable().
The global symbol _Nios2_ISR_Status_mask will be used to clear the bits in the status register representing the interrupt level. The global symbol _Nios2_ISR_Status_bits will be used to set the bits representing an interrupt level that disables interrupts. Both global symbols must be provided by the board support package.
In case the Nios II uses the internal interrupt controller (IIC), then only the PIE status bit is used.
In case the Nios II uses the external interrupt controller (EIC), then the RSIE status bit or the IL status field is used depending on the interrupt handling variant and the shadow register usage.
◆ _CPU_ISR_Enable
#define _CPU_ISR_Enable (   _isr_cookie)     __builtin_wrctl( 0, (int) _isr_cookie )
The _isr_cookie must contain the processor status returned by _CPU_ISR_Disable(). The value is not modified.
◆ _CPU_ISR_Flash
#define _CPU_ISR_Flash (   _isr_cookie)
Value:
do { \
int _status = __builtin_rdctl( 0 ); \
__builtin_wrctl( 0, (int) _isr_cookie ); \
__builtin_wrctl( 0, _status ); \
} while ( 0 )
This flash code is optimal for all Nios II configurations. The rdctl does not flush the pipeline and has only a late result penalty. The wrctl on the other hand leads to a pipeline flush.
Typedef Documentation
◆ CPU_Uint32ptr
Type that can store a 32-bit integer or a pointer.
