RTEMS 6.1
Macros | Functions
tm27.h File Reference
#include <bsp/irq.h>
#define MUST_WAIT_FOR_INTERRUPT   0
#define Install_tm27_vector(handler)
#define Cause_tm27_intr()
#define Clear_tm27_intr()
#define Lower_tm27_intr()
int assert_sw_irw (uint32_t irqnum)
int negate_sw_irw (uint32_t irqnum)
◆ Cause_tm27_intr
#define Cause_tm27_intr (   void)
Value:
do { \
assert_sw_irq(0); \
} while(0)
◆ Clear_tm27_intr
#define Clear_tm27_intr (   void)
Value:
do { \
negate_sw_irq(0); \
} while(0)
◆ Install_tm27_vector
#define Install_tm27_vector (   handler)
Value:
AU1X00_IRQ_SW0, "benchmark", 0, handler, NULL );
rtems_status_code rtems_interrupt_handler_install(rtems_vector_number vector, const char *info, rtems_option options, rtems_interrupt_handler routine, void *arg)
Installs the interrupt handler routine and argument at the interrupt vector.
Definition: irq-handler-install.c:85
◆ Lower_tm27_intr
#define Lower_tm27_intr (   void)
Value:
do { \
continue;\
} while(0)
