RTEMS 6.1
tm27.h
1
5/*
6 * The license and distribution terms for this file may be
7 * found in the file LICENSE in this distribution or at
8 * http://www.rtems.org/license/LICENSE.
9 */
10
11#ifndef _RTEMS_TMTEST27
12#error "This is an RTEMS internal file you must not include directly."
13#endif
14
15#ifndef __tm27_h
16#define __tm27_h
17
18#include <bsp/irq.h>
19
20/*
21 * Define the interrupt mechanism for Time Test 27
22 */
23
24int assert_sw_irw(uint32_t irqnum);
25int negate_sw_irw(uint32_t irqnum);
26
27#define MUST_WAIT_FOR_INTERRUPT 0
28
29#define Install_tm27_vector( handler ) \
30 rtems_interrupt_handler_install( \
31 AU1X00_IRQ_SW0, "benchmark", 0, handler, NULL );
32
33#define Cause_tm27_intr() \
34 do { \
35 assert_sw_irq(0); \
36 } while(0)
37
38#define Clear_tm27_intr() \
39 do { \
40 negate_sw_irq(0); \
41 } while(0)
42
43#define Lower_tm27_intr() \
44 do { \
45 continue;\
46 } while(0)
47
48#endif
