RTEMS 6.1
This source file contains the implementation of bsp_interrupt_lock() and bsp_interrupt_unlock(). More...
| void | bsp_interrupt_lock (void) |
| Acquires the interrupt support lock. | |
| void | bsp_interrupt_unlock (void) |
| Releases the interrupt support lock. | |
| void bsp_interrupt_lock | ( | void | ) |
The interrupt support lock is a mutex. The mutex is only acquired if the system is the SYSTEM_STATE_UP state.
| void bsp_interrupt_unlock | ( | void | ) |
The mutex is only released if the system is the SYSTEM_STATE_UP state.
