RTEMS 6.1
apimutex.h
2
12/*
13 * COPYRIGHT (c) 1989-2008.
14 * On-Line Applications Research Corporation (OAR).
15 *
16 * Redistribution and use in source and binary forms, with or without
17 * modification, are permitted provided that the following conditions
18 * are met:
19 * 1. Redistributions of source code must retain the above copyright
20 * notice, this list of conditions and the following disclaimer.
21 * 2. Redistributions in binary form must reproduce the above copyright
22 * notice, this list of conditions and the following disclaimer in the
23 * documentation and/or other materials provided with the distribution.
24 *
25 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
26 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
27 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
28 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
29 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
30 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
31 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
32 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
33 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
34 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
35 * POSSIBILITY OF SUCH DAMAGE.
36 */
37
38#ifndef _RTEMS_SCORE_APIMUTEX_H
39#define _RTEMS_SCORE_APIMUTEX_H
40
41#include <rtems/score/thread.h>
42
43#include <sys/lock.h>
44
58#ifdef __cplusplus
59extern "C" {
60#endif
61
65typedef struct {
69 struct _Mutex_recursive_Control Mutex;
70
77
81#define API_MUTEX_INITIALIZER( name ) \
82 { _MUTEX_RECURSIVE_NAMED_INITIALIZER( name ), 0 }
83
90
97
104
121void _RTEMS_Lock_allocator( void );
122
123void _RTEMS_Unlock_allocator( void );
124
125bool _RTEMS_Allocator_is_owner( void );
126
129#ifdef __cplusplus
130}
131#endif
132
133#endif
134/* end of include file */
bool _API_Mutex_Is_owner(const API_Mutex_Control *mutex)
Checks if the specified API mutex is owned by the executing thread.
Definition: apimutexisowner.c:45
void _API_Mutex_Lock(API_Mutex_Control *mutex)
Acquires the specified API mutex.
Definition: apimutexlock.c:45
void _API_Mutex_Unlock(API_Mutex_Control *mutex)
Releases the specified API mutex.
Definition: apimutexunlock.c:45
unsigned int Thread_Life_state
This type represents the thread life state.
Definition: thread.h:747
This header file provides interfaces of the Thread Handler which are used by the implementation and t...
Control block used to manage each API mutex.
Definition: apimutex.h:65
Thread_Life_state previous_thread_life_state
The thread life protection state before the outer-most mutex obtain.
Definition: apimutex.h:75
Definition: mutex.h:4
