RTEMS 6.1
irq-generic.h File Reference
This header file provides interfaces of the Interrupt Manager implementation. More...
#include <stdbool.h>
#include <rtems/irq-extension.h>
#include <rtems/score/processormask.h>
#include <bsp/irq.h>
#define BSP_INTERRUPT_DISPATCH_TABLE_SIZE   BSP_INTERRUPT_VECTOR_COUNT
#define bsp_interrupt_assert(e)   _Assert(e)
void bsp_interrupt_handler_default (rtems_vector_number vector)
 Default interrupt handler.
void bsp_interrupt_initialize (void)
 Initialize Interrupt Manager implementation.
void bsp_interrupt_facility_initialize (void)
 BSP specific initialization.
rtems_status_code bsp_interrupt_get_attributes (rtems_vector_number vector, rtems_interrupt_attributes *attributes)
 Gets the attributes of the interrupt vector.
rtems_status_code bsp_interrupt_vector_is_enabled (rtems_vector_number vector, bool *enabled)
 Checks if the interrupt is enabled.
rtems_status_code bsp_interrupt_vector_enable (rtems_vector_number vector)
 Enables the interrupt vector.
rtems_status_code bsp_interrupt_vector_disable (rtems_vector_number vector)
 Disables the interrupt vector.
rtems_status_code bsp_interrupt_is_pending (rtems_vector_number vector, bool *pending)
 Checks if the interrupt is pending.
rtems_status_code bsp_interrupt_raise (rtems_vector_number vector)
 Causes the interrupt vector.
rtems_status_code bsp_interrupt_clear (rtems_vector_number vector)
 Clears the interrupt vector.
rtems_status_code bsp_interrupt_get_priority (rtems_vector_number vector, uint32_t *priority)
 Gets the priority of the interrupt vector.
rtems_status_code bsp_interrupt_set_priority (rtems_vector_number vector, uint32_t priority)
 Sets the priority of the interrupt vector.
rtems_status_code bsp_interrupt_get_affinity (rtems_vector_number vector, Processor_mask *affinity)
 Gets the processor affinity set of the interrupt vector.
rtems_status_code bsp_interrupt_set_affinity (rtems_vector_number vector, const Processor_mask *affinity)
 Sets the processor affinity set of the interrupt vector.
void bsp_interrupt_lock (void)
 Acquires the interrupt support lock.
void bsp_interrupt_unlock (void)
 Releases the interrupt support lock.
rtems_status_code bsp_interrupt_check_and_lock (rtems_vector_number vector, rtems_interrupt_handler handler)
 Checks the vector and routine. When the checks were successful, the interrupt support lock will be obtained.
rtems_interrupt_entrybsp_interrupt_entry_find (rtems_vector_number vector, rtems_interrupt_handler routine, void *arg, rtems_interrupt_entry ***previous_next)
void bsp_interrupt_entry_remove (rtems_vector_number vector, rtems_interrupt_entry *entry, rtems_interrupt_entry **previous_next)
rtems_interrupt_entry ** bsp_interrupt_get_dispatch_table_slot (rtems_vector_number index)
 Gets a reference to the interrupt handler table slot associated with the index.
rtems_interrupt_entrybsp_interrupt_dispatch_table []
 Each member of this table references the first installed entry at the corresponding interrupt vector or is NULL.
uint8_t bsp_interrupt_handler_unique_table []
 This table contains a bit map which indicates if an entry is unique or shared.
◆ bsp_interrupt_check_and_lock()
rtems_status_code bsp_interrupt_check_and_lock ( rtems_vector_number  vector,
Parameters
vectoris the interrupt vector number to check.
routineis the routine to check.
Return values
RTEMS_SUCCESSFULThe requested operation was successful.
RTEMS_INCORRECT_STATEThe interrupt support was not initialized.
RTEMS_CALLED_FROM_ISRThe function was called from within interrupt context.
RTEMS_INVALID_ADDRESSThe routine parameter was NULL.
RTEMS_INVALID_IDThere was no interrupt vector associated with the number specified by vector.
◆ bsp_interrupt_get_dispatch_table_slot()
rtems_interrupt_entry ** bsp_interrupt_get_dispatch_table_slot ( rtems_vector_number  index)
Returns
Returns a reference to the interrupt handler table slot associated with the index.
◆ bsp_interrupt_lock()
void bsp_interrupt_lock ( void  )
The interrupt support lock is a mutex. The mutex is only acquired if the system is the SYSTEM_STATE_UP state.
◆ bsp_interrupt_unlock()
void bsp_interrupt_unlock ( void  )
The mutex is only released if the system is the SYSTEM_STATE_UP state.
Variable Documentation
◆ bsp_interrupt_handler_unique_table
uint8_t bsp_interrupt_handler_unique_table[]
extern
If the bit associated with a vector is set, then the entry is unique, otherwise it may be shared. If the bit with index BSP_INTERRUPT_DISPATCH_TABLE_SIZE is set, then the interrupt support is initialized, otherwise it is not initialized.
