RTEMS 6.1
Xecc
struct  _xecc_config
 XECC user configuration. More...
struct  _xecc_single_error_info
 XECC single error information, including single error address, ECC code, error data, error bit position and error bit field. More...
struct  _xecc_multi_error_info
 XECC multiple error information, including multiple error address, ECC code, error data and error bit field. More...
Driver version
enum  { kXECC_SingleErrorInterruptEnable = XECC_ERR_SIG_EN_SINGLE_ERR_SIG_EN_MASK , kXECC_MultiErrorInterruptEnable = XECC_ERR_SIG_EN_MULTI_ERR_SIG_EN_MASK , kXECC_AllInterruptsEnable }
 XECC interrupt configuration structure, , xecc_interrupt_enable_t. More...
enum  { kXECC_SingleErrorInterruptStatusEnable , kXECC_MultiErrorInterruptStatusEnable , kXECC_AllInterruptsStatusEnable }
 XECC interrupt status configuration structure, xecc_interrupt_status_enable_t. More...
enum  { kXECC_SingleErrorInterruptFlag , kXECC_MultiErrorInterruptFlag , kXECC_AllInterruptsFlag }
 XECC status flags, xecc_interrupt_status_t. More...
typedef struct _xecc_config xecc_config_t
typedef struct _xecc_single_error_info xecc_single_error_info_t
typedef struct _xecc_multi_error_info xecc_multi_error_info_t
#define FSL_XECC_DRIVER_VERSION   (MAKE_VERSION(2U, 0U, 0U))
 Driver version 2.0.0.
Initialization and deinitialization
void XECC_Init (XECC_Type *base, const xecc_config_t *config)
 XECC module initialization function.
void XECC_Deinit (XECC_Type *base)
 Deinitializes the XECC.
void XECC_GetDefaultConfig (xecc_config_t *config)
 Sets the XECC configuration structure to default values.
functional
status_t XECC_ErrorInjection (XECC_Type *base, uint32_t errordata, uint8_t erroreccdata)
 XECC module error injection.
void XECC_GetSingleErrorInfo (XECC_Type *base, xecc_single_error_info_t *info)
 XECC module get single error information.
void XECC_GetMultiErrorInfo (XECC_Type *base, xecc_multi_error_info_t *info)
 XECC module get multiple error information.
◆ anonymous enum
anonymous enum
This structure contains the settings for all of the XECC interrupt configurations.
Single bit error interrupt enable
Multiple bit error interrupt enable
all interrupts enable
◆ anonymous enum
anonymous enum
This structure contains the settings for all of the XECC interrupt status configurations.
Single bit error interrupt status enable
Multiple bits error interrupt status enable
◆ anonymous enum
anonymous enum
This provides constants for the XECC status flags for use in the XECC functions.
Single bit error interrupt happens on read data
Multiple bits error interrupt happens on read data
all interrupts happens on read data
◆ XECC_Deinit()
void XECC_Deinit ( XECC_Type base)
Parameters
baseXECC base address.
brief Deinitializes the XECC.
◆ XECC_ErrorInjection()
status_t XECC_ErrorInjection ( XECC_Type base,
uint32_t  errordata,
Parameters
errordataerror data.
erroreccdataecc code.
Return values
kStatus_Success.
◆ XECC_GetDefaultConfig()
void XECC_GetDefaultConfig ( xecc_config_t config)
Parameters
configpointer to the XECC configuration structure.
◆ XECC_GetMultiErrorInfo()
void XECC_GetMultiErrorInfo ( XECC_Type base,
xecc_multi_error_info_t info
Parameters
infomultiple error information.
◆ XECC_GetSingleErrorInfo()
void XECC_GetSingleErrorInfo ( XECC_Type base,
xecc_single_error_info_t info
Parameters
infosingle error information.
◆ XECC_Init()
void XECC_Init ( XECC_Type base,
const xecc_config_t config
Parameters
brief XECC module initialization function.
param base XECC base address.
