RTEMS 6.1
#include <MIMXRT1166_cm4.h>
Data Fields | |
| __IO uint32_t | ECC_CTRL |
| __IO uint32_t | ERR_STATUS |
| __IO uint32_t | ERR_STAT_EN |
| __IO uint32_t | ERR_SIG_EN |
| __IO uint32_t | ERR_DATA_INJ |
| __IO uint32_t | ERR_ECC_INJ |
| __I uint32_t | SINGLE_ERR_ADDR |
| __I uint32_t | SINGLE_ERR_DATA |
| __I uint32_t | SINGLE_ERR_ECC |
| __I uint32_t | SINGLE_ERR_POS |
| __I uint32_t | SINGLE_ERR_BIT_FIELD |
| __I uint32_t | MULTI_ERR_ADDR |
| __I uint32_t | MULTI_ERR_DATA |
| __I uint32_t | MULTI_ERR_ECC |
| __I uint32_t | MULTI_ERR_BIT_FIELD |
| __IO uint32_t | ECC_BASE_ADDR0 |
| __IO uint32_t | ECC_END_ADDR0 |
| __IO uint32_t | ECC_BASE_ADDR1 |
| __IO uint32_t | ECC_END_ADDR1 |
| __IO uint32_t | ECC_BASE_ADDR2 |
| __IO uint32_t | ECC_END_ADDR2 |
| __IO uint32_t | ECC_BASE_ADDR3 |
| __IO uint32_t | ECC_END_ADDR3 |
XECC - Register Layout Typedef
