#define | LPC24XX_IO_PORT_COUNT 5U |
#define | LPC24XX_IO_INDEX_MAX (LPC24XX_IO_PORT_COUNT * 32U) |
#define | LPC24XX_IO_INDEX_BY_PORT(port, bit) (((port) << 5U) + (bit)) |
#define | LPC24XX_IO_PORT(index) ((index) >> 5U) |
#define | LPC24XX_IO_PORT_BIT(index) ((index) & 0x1fU) |
#define | LPC24XX_MODULE_COUNT (LPC24XX_MODULE_USB + 1) |
#define | LPC24XX_MODULE_CLOCK_MASK 0x3U |
#define | LPC24XX_PIN(p, i, f0, f1) { { p, i, f1, 0, 0 } } |
#define | LPC24XX_PIN_WITH_TYPE(p, i, f0, f1, t) { { p, i, f1, t, 0 } } |
#define | LPC24XX_PIN_RANGE(p, i, j, f0, f1) { { p, i, f1, 0, 0 } }, { { p, j, f1, 0, 1 } } |
#define | LPC24XX_PIN_RANGE_WITH_TYPE(p, i, j, f0, f1, t) { { p, i, f1, t, 0 } }, { { p, j, f1, t, 1 } } |
#define | LPC24XX_PIN_TERMINAL { { 0x7, 0x1f, 0x7, 0xf, 0x1 } } |
| enum | lpc24xx_module {
LPC24XX_MODULE_ADC
, LPC24XX_MODULE_CAN_0
, LPC24XX_MODULE_CAN_1
, LPC24XX_MODULE_DAC
LPC24XX_MODULE_EMC
, LPC24XX_MODULE_ETHERNET
, LPC24XX_MODULE_GPDMA
, LPC24XX_MODULE_GPIO
LPC24XX_MODULE_I2C_0
, LPC24XX_MODULE_I2C_1
, LPC24XX_MODULE_I2C_2
, LPC24XX_MODULE_I2S
LPC24XX_MODULE_LCD
, LPC24XX_MODULE_MCI
, LPC24XX_MODULE_PCB
, LPC24XX_MODULE_PWM_0
LPC24XX_MODULE_PWM_1
, LPC24XX_MODULE_RTC
, LPC24XX_MODULE_SSP_0
, LPC24XX_MODULE_SSP_1
LPC24XX_MODULE_SYSCON
, LPC24XX_MODULE_TIMER_0
, LPC24XX_MODULE_TIMER_1
, LPC24XX_MODULE_TIMER_2
LPC24XX_MODULE_TIMER_3
, LPC24XX_MODULE_UART_0
, LPC24XX_MODULE_UART_1
, LPC24XX_MODULE_UART_2
LPC24XX_MODULE_UART_3
, LPC24XX_MODULE_USB
| enum | lpc24xx_module_clock {
LPC24XX_MODULE_PCLK_DEFAULT = 0x4U
, LPC24XX_MODULE_CCLK = 0x1U
, LPC24XX_MODULE_CCLK_2 = 0x2U
, LPC24XX_MODULE_CCLK_4 = 0x0U
LPC24XX_MODULE_CCLK_6 = 0x3U
, LPC24XX_MODULE_CCLK_8 = 0x3U
| enum | lpc24xx_gpio_settings {
LPC24XX_GPIO_DEFAULT = 0x0U
, LPC24XX_GPIO_RESISTOR_PULL_UP = 0x0U
, LPC24XX_GPIO_RESISTOR_NONE = 0x1U
, LPC24XX_GPIO_RESISTOR_PULL_DOWN = 0x2U
LPC24XX_GPIO_INPUT = 0x0U
, LPC24XX_GPIO_OUTPUT = 0x8000U
| enum | lpc24xx_pin_action { LPC24XX_PIN_SET_FUNCTION
, LPC24XX_PIN_CHECK_FUNCTION
, LPC24XX_PIN_SET_INPUT
, LPC24XX_PIN_CHECK_INPUT
| enum | lpc24xx_pin_function { LPC24XX_PIN_FUNCTION_00
, LPC24XX_PIN_FUNCTION_01
, LPC24XX_PIN_FUNCTION_10
, LPC24XX_PIN_FUNCTION_11
| enum | lpc17xx_pin_type {
LPC17XX_PIN_TYPE_DEFAULT
, LPC17XX_PIN_TYPE_ADC
, LPC17XX_PIN_TYPE_DAC
, LPC17XX_PIN_TYPE_I2C
LPC17XX_PIN_TYPE_I2C_FAST_PLUS
, LPC17XX_PIN_TYPE_OPEN_DRAIN
, LPC17XX_PIN_TYPE_FAST_SLEW_RATE
| #define | LPC24XX_PIN_EMC(p, i) |
| #define | LPC24XX_PIN_EMC_RANGE(p, i, j) |
#define | LPC24XX_PIN_EMC_CS_0 LPC24XX_PIN_EMC(4, 30) |
#define | LPC24XX_PIN_EMC_CS_1 LPC24XX_PIN_EMC(4, 31) |
#define | LPC24XX_PIN_EMC_CS_2 LPC24XX_PIN_EMC(2, 14) |
#define | LPC24XX_PIN_EMC_CS_3 LPC24XX_PIN_EMC(2, 15) |
#define | LPC24XX_PIN_EMC_DYCS_0 LPC24XX_PIN_EMC(2, 20) |
#define | LPC24XX_PIN_EMC_DYCS_1 LPC24XX_PIN_EMC(2, 21) |
#define | LPC24XX_PIN_EMC_DYCS_2 LPC24XX_PIN_EMC(2, 22) |
#define | LPC24XX_PIN_EMC_DYCS_3 LPC24XX_PIN_EMC(2, 23) |
#define | LPC24XX_PIN_EMC_OE LPC24XX_PIN_EMC(4, 24) |
#define | LPC24XX_PIN_EMC_WE LPC24XX_PIN_EMC(4, 25) |
#define | LPC24XX_PIN_EMC_CAS LPC24XX_PIN_EMC(2, 16) |
#define | LPC24XX_PIN_EMC_RAS LPC24XX_PIN_EMC(2, 17) |
#define | LPC24XX_PIN_EMC_CLK_0 LPC24XX_PIN_EMC(2, 18) |
#define | LPC24XX_PIN_EMC_CLK_1 LPC24XX_PIN_EMC(2, 19) |
#define | LPC24XX_PIN_EMC_CKE_0 LPC24XX_PIN_EMC(2, 24) |
#define | LPC24XX_PIN_EMC_CKE_1 LPC24XX_PIN_EMC(2, 25) |
#define | LPC24XX_PIN_EMC_CKE_2 LPC24XX_PIN_EMC(2, 26) |
#define | LPC24XX_PIN_EMC_CKE_3 LPC24XX_PIN_EMC(2, 27) |
#define | LPC24XX_PIN_EMC_DQM_0 LPC24XX_PIN_EMC(2, 28) |
#define | LPC24XX_PIN_EMC_DQM_1 LPC24XX_PIN_EMC(2, 29) |
#define | LPC24XX_PIN_EMC_DQM_2 LPC24XX_PIN_EMC(2, 30) |
#define | LPC24XX_PIN_EMC_DQM_3 LPC24XX_PIN_EMC(2, 31) |
#define | LPC24XX_PIN_EMC_BLS0 LPC24XX_PIN_EMC(4, 26) |
#define | LPC24XX_PIN_EMC_BLS1 LPC24XX_PIN_EMC(4, 27) |
#define | LPC24XX_PIN_EMC_BLS2 LPC24XX_PIN_EMC(4, 28) |
#define | LPC24XX_PIN_EMC_BLS3 LPC24XX_PIN_EMC(4, 29) |
#define | LPC24XX_PIN_EMC_D_0_15 LPC24XX_PIN_EMC_RANGE(3, 0, 15) |
#define | LPC24XX_PIN_EMC_D_15_31 LPC24XX_PIN_EMC_RANGE(3, 15, 31) |
#define | LPC24XX_PIN_EMC_D_0_31 LPC24XX_PIN_EMC_RANGE(3, 0, 31) |
#define | LPC24XX_PIN_EMC_A_0_12 LPC24XX_PIN_EMC_RANGE(4, 0, 12) |
#define | LPC24XX_PIN_EMC_A_0_13 LPC24XX_PIN_EMC_RANGE(4, 0, 13) |
#define | LPC24XX_PIN_EMC_A_0_14 LPC24XX_PIN_EMC_RANGE(4, 0, 14) |
#define | LPC24XX_PIN_EMC_A_0_15 LPC24XX_PIN_EMC_RANGE(4, 0, 15) |
| #define | LPC24XX_PIN_EMC_A_0_16 |
| #define | LPC24XX_PIN_EMC_A_0_17 |
| #define | LPC24XX_PIN_EMC_A_0_18 |
| #define | LPC24XX_PIN_EMC_A_0_19 |
| #define | LPC24XX_PIN_EMC_A_0_20 |
| #define | LPC24XX_PIN_EMC_A_0_21 |
| #define | LPC24XX_PIN_EMC_A_0_22 |
| #define | LPC24XX_PIN_EMC_A_0_23 |
| #define | LPC24XX_PIN_EMC_A_0_24 |
| #define | LPC24XX_PIN_EMC_A_0_25 |
#define | LPC24XX_PIN_I2S_RX_CLK_P0_4 LPC24XX_PIN(0, 4, LPC24XX_PIN_FUNCTION_01, 1) |
#define | LPC24XX_PIN_I2S_RX_CLK_P0_23 LPC24XX_PIN(0, 23, LPC24XX_PIN_FUNCTION_10, 2) |
#define | LPC24XX_PIN_I2S_RX_WS_P0_5 LPC24XX_PIN(0, 5, LPC24XX_PIN_FUNCTION_01, 1) |
#define | LPC24XX_PIN_I2S_RX_WS_P0_24 LPC24XX_PIN(0, 24, LPC24XX_PIN_FUNCTION_10, 2) |
#define | LPC24XX_PIN_I2S_RX_SDA_P0_6 LPC24XX_PIN(0, 6, LPC24XX_PIN_FUNCTION_01, 1) |
#define | LPC24XX_PIN_I2S_RX_SDA_P0_25 LPC24XX_PIN(0, 25, LPC24XX_PIN_FUNCTION_10, 2) |
#define | LPC24XX_PIN_I2S_TX_CLK_P0_7 LPC24XX_PIN(0, 7, LPC24XX_PIN_FUNCTION_01, 1) |
#define | LPC24XX_PIN_I2S_TX_CLK_P2_11 LPC24XX_PIN(2, 11, LPC24XX_PIN_FUNCTION_11, 3) |
#define | LPC24XX_PIN_I2S_TX_WS_P0_8 LPC24XX_PIN(0, 8, LPC24XX_PIN_FUNCTION_01, 1) |
#define | LPC24XX_PIN_I2S_TX_WS_P2_12 LPC24XX_PIN(2, 12, LPC24XX_PIN_FUNCTION_11, 3) |
#define | LPC24XX_PIN_I2S_TX_SDA_P0_9 LPC24XX_PIN(0, 9, LPC24XX_PIN_FUNCTION_01, 1) |
#define | LPC24XX_PIN_I2S_TX_SDA_P2_13 LPC24XX_PIN(2, 13, LPC24XX_PIN_FUNCTION_11, 3) |
#define | LPC24XX_PIN_LCD_PWR LPC24XX_PIN(2, 0, LPC24XX_PIN_FUNCTION_11, 7) |
#define | LPC24XX_PIN_LCD_LE LPC24XX_PIN(2, 1, LPC24XX_PIN_FUNCTION_11, 7) |
#define | LPC24XX_PIN_LCD_DCLK LPC24XX_PIN(2, 2, LPC24XX_PIN_FUNCTION_11, 7) |
#define | LPC24XX_PIN_LCD_FP LPC24XX_PIN(2, 3, LPC24XX_PIN_FUNCTION_11, 7) |
#define | LPC24XX_PIN_LCD_ENAB_M LPC24XX_PIN(2, 4, LPC24XX_PIN_FUNCTION_11, 7) |
#define | LPC24XX_PIN_LCD_LP LPC24XX_PIN(2, 5, LPC24XX_PIN_FUNCTION_11, 7) |
#define | LPC24XX_PIN_LCD_CLKIN LPC24XX_PIN(2, 11, LPC24XX_PIN_FUNCTION_01, 7) |
#define | LPC24XX_PIN_LCD_VD_0_P0_4 LPC24XX_PIN(0, 4, LPC24XX_PIN_FUNCTION_01, 7) |
#define | LPC24XX_PIN_LCD_VD_0_P2_6 LPC24XX_PIN(2, 6, LPC24XX_PIN_FUNCTION_11, 6) |
#define | LPC24XX_PIN_LCD_VD_1_P0_5 LPC24XX_PIN(0, 5, LPC24XX_PIN_FUNCTION_01, 7) |
#define | LPC24XX_PIN_LCD_VD_1_P2_7 LPC24XX_PIN(2, 7, LPC24XX_PIN_FUNCTION_11, 6) |
#define | LPC24XX_PIN_LCD_VD_2_P2_8 LPC24XX_PIN(2, 8, LPC24XX_PIN_FUNCTION_11, 6) |
#define | LPC24XX_PIN_LCD_VD_2_P4_28 LPC24XX_PIN(4, 28, LPC24XX_PIN_FUNCTION_10, 7) |
#define | LPC24XX_PIN_LCD_VD_3_P2_9 LPC24XX_PIN(2, 9, LPC24XX_PIN_FUNCTION_11, 6) |
#define | LPC24XX_PIN_LCD_VD_3_P2_12 LPC24XX_PIN(2, 12, LPC24XX_PIN_FUNCTION_01, 5) |
#define | LPC24XX_PIN_LCD_VD_3_P4_29 LPC24XX_PIN(4, 29, LPC24XX_PIN_FUNCTION_10, 7) |
#define | LPC24XX_PIN_LCD_VD_4_P2_6 LPC24XX_PIN(2, 6, LPC24XX_PIN_FUNCTION_11, 7) |
#define | LPC24XX_PIN_LCD_VD_4_P2_12 LPC24XX_PIN(2, 12, LPC24XX_PIN_FUNCTION_01, 4) |
#define | LPC24XX_PIN_LCD_VD_5_P2_7 LPC24XX_PIN(2, 7, LPC24XX_PIN_FUNCTION_11, 7) |
#define | LPC24XX_PIN_LCD_VD_5_P2_13 LPC24XX_PIN(2, 13, LPC24XX_PIN_FUNCTION_01, 5) |
#define | LPC24XX_PIN_LCD_VD_6_P1_20 LPC24XX_PIN(1, 20, LPC24XX_PIN_FUNCTION_01, 6) |
#define | LPC24XX_PIN_LCD_VD_6_P2_8 LPC24XX_PIN(2, 8, LPC24XX_PIN_FUNCTION_11, 7) |
#define | LPC24XX_PIN_LCD_VD_6_P4_28 LPC24XX_PIN(4, 28, LPC24XX_PIN_FUNCTION_10, 5) |
#define | LPC24XX_PIN_LCD_VD_7_P1_21 LPC24XX_PIN(1, 21, LPC24XX_PIN_FUNCTION_01, 6) |
#define | LPC24XX_PIN_LCD_VD_7_P2_9 LPC24XX_PIN(2, 9, LPC24XX_PIN_FUNCTION_11, 7) |
#define | LPC24XX_PIN_LCD_VD_7_P4_29 LPC24XX_PIN(4, 29, LPC24XX_PIN_FUNCTION_10, 5) |
#define | LPC24XX_PIN_LCD_VD_8_P0_6 LPC24XX_PIN(0, 6, LPC24XX_PIN_FUNCTION_01, 7) |
#define | LPC24XX_PIN_LCD_VD_8_P1_22 LPC24XX_PIN(1, 22, LPC24XX_PIN_FUNCTION_01, 6) |
#define | LPC24XX_PIN_LCD_VD_8_P2_12 LPC24XX_PIN(2, 12, LPC24XX_PIN_FUNCTION_01, 6) |
#define | LPC24XX_PIN_LCD_VD_9_P0_7 LPC24XX_PIN(0, 7, LPC24XX_PIN_FUNCTION_01, 7) |
#define | LPC24XX_PIN_LCD_VD_9_P1_23 LPC24XX_PIN(1, 23, LPC24XX_PIN_FUNCTION_01, 6) |
#define | LPC24XX_PIN_LCD_VD_9_P2_13 LPC24XX_PIN(2, 13, LPC24XX_PIN_FUNCTION_01, 6) |
#define | LPC24XX_PIN_LCD_VD_10_P1_20 LPC24XX_PIN(1, 20, LPC24XX_PIN_FUNCTION_01, 7) |
#define | LPC24XX_PIN_LCD_VD_10_P1_24 LPC24XX_PIN(1, 24, LPC24XX_PIN_FUNCTION_01, 6) |
#define | LPC24XX_PIN_LCD_VD_10_P4_28 LPC24XX_PIN(4, 28, LPC24XX_PIN_FUNCTION_10, 6) |
#define | LPC24XX_PIN_LCD_VD_11_P1_21 LPC24XX_PIN(1, 21, LPC24XX_PIN_FUNCTION_01, 7) |
#define | LPC24XX_PIN_LCD_VD_11_P1_25 LPC24XX_PIN(1, 25, LPC24XX_PIN_FUNCTION_01, 6) |
#define | LPC24XX_PIN_LCD_VD_11_P4_29 LPC24XX_PIN(4, 29, LPC24XX_PIN_FUNCTION_10, 6) |
#define | LPC24XX_PIN_LCD_VD_12_P1_22 LPC24XX_PIN(1, 22, LPC24XX_PIN_FUNCTION_01, 7) |
#define | LPC24XX_PIN_LCD_VD_12_P1_26 LPC24XX_PIN(1, 26, LPC24XX_PIN_FUNCTION_01, 6) |
#define | LPC24XX_PIN_LCD_VD_13_P1_23 LPC24XX_PIN(1, 23, LPC24XX_PIN_FUNCTION_01, 7) |
#define | LPC24XX_PIN_LCD_VD_13_P1_27 LPC24XX_PIN(1, 27, LPC24XX_PIN_FUNCTION_01, 6) |
#define | LPC24XX_PIN_LCD_VD_14_P1_24 LPC24XX_PIN(1, 24, LPC24XX_PIN_FUNCTION_01, 7) |
#define | LPC24XX_PIN_LCD_VD_14_P1_28 LPC24XX_PIN(1, 28, LPC24XX_PIN_FUNCTION_01, 6) |
#define | LPC24XX_PIN_LCD_VD_15_P1_25 LPC24XX_PIN(1, 25, LPC24XX_PIN_FUNCTION_01, 7) |
#define | LPC24XX_PIN_LCD_VD_15_P1_29 LPC24XX_PIN(1, 29, LPC24XX_PIN_FUNCTION_01, 6) |
#define | LPC24XX_PIN_LCD_VD_16_P0_8 LPC24XX_PIN(0, 8, LPC24XX_PIN_FUNCTION_01, 7) |
#define | LPC24XX_PIN_LCD_VD_17_P0_9 LPC24XX_PIN(0, 9, LPC24XX_PIN_FUNCTION_01, 7) |
#define | LPC24XX_PIN_LCD_VD_18_P2_12 LPC24XX_PIN(2, 12, LPC24XX_PIN_FUNCTION_01, 7) |
#define | LPC24XX_PIN_LCD_VD_19_P2_13 LPC24XX_PIN(2, 13, LPC24XX_PIN_FUNCTION_01, 7) |
#define | LPC24XX_PIN_LCD_VD_20_P1_26 LPC24XX_PIN(1, 26, LPC24XX_PIN_FUNCTION_01, 7) |
#define | LPC24XX_PIN_LCD_VD_21_P1_27 LPC24XX_PIN(1, 27, LPC24XX_PIN_FUNCTION_01, 7) |
#define | LPC24XX_PIN_LCD_VD_22_P1_28 LPC24XX_PIN(1, 28, LPC24XX_PIN_FUNCTION_01, 7) |
#define | LPC24XX_PIN_LCD_VD_23_P1_29 LPC24XX_PIN(1, 29, LPC24XX_PIN_FUNCTION_01, 7) |
#define | LPC24XX_PIN_PWM_0_CHANNEL_1_P1_2 LPC24XX_PIN(1, 2, LPC24XX_PIN_FUNCTION_11, 3) |
#define | LPC24XX_PIN_PWM_0_CHANNEL_1_P3_16 LPC24XX_PIN(3, 16, LPC24XX_PIN_FUNCTION_10, 2) |
#define | LPC24XX_PIN_PWM_0_CHANNEL_2_P1_3 LPC24XX_PIN(1, 3, LPC24XX_PIN_FUNCTION_11, 3) |
#define | LPC24XX_PIN_PWM_0_CHANNEL_2_P3_17 LPC24XX_PIN(3, 17, LPC24XX_PIN_FUNCTION_10, 2) |
#define | LPC24XX_PIN_PWM_0_CHANNEL_3_P1_5 LPC24XX_PIN(1, 5, LPC24XX_PIN_FUNCTION_11, 3) |
#define | LPC24XX_PIN_PWM_0_CHANNEL_3_P3_18 LPC24XX_PIN(3, 18, LPC24XX_PIN_FUNCTION_10, 2) |
#define | LPC24XX_PIN_PWM_0_CHANNEL_4_P1_6 LPC24XX_PIN(1, 6, LPC24XX_PIN_FUNCTION_11, 3) |
#define | LPC24XX_PIN_PWM_0_CHANNEL_4_P3_19 LPC24XX_PIN(3, 19, LPC24XX_PIN_FUNCTION_10, 2) |
#define | LPC24XX_PIN_PWM_0_CHANNEL_5_P1_7 LPC24XX_PIN(1, 7, LPC24XX_PIN_FUNCTION_11, 3) |
#define | LPC24XX_PIN_PWM_0_CHANNEL_5_P3_20 LPC24XX_PIN(3, 20, LPC24XX_PIN_FUNCTION_10, 2) |
#define | LPC24XX_PIN_PWM_0_CHANNEL_6_P1_11 LPC24XX_PIN(1, 11, LPC24XX_PIN_FUNCTION_11, 3) |
#define | LPC24XX_PIN_PWM_0_CHANNEL_6_P3_21 LPC24XX_PIN(3, 21, LPC24XX_PIN_FUNCTION_10, 2) |
#define | LPC24XX_PIN_PWM_0_CAPTURE_0_P1_12 LPC24XX_PIN(1, 12, LPC24XX_PIN_FUNCTION_11, 3) |
#define | LPC24XX_PIN_PWM_0_CAPTURE_0_P3_22 LPC24XX_PIN(3, 22, LPC24XX_PIN_FUNCTION_10, 2) |
#define | LPC24XX_PIN_PWM_1_CHANNEL_1_P1_18 LPC24XX_PIN(1, 18, LPC24XX_PIN_FUNCTION_10, 2) |
#define | LPC24XX_PIN_PWM_1_CHANNEL_1_P2_0 LPC24XX_PIN(2, 0, LPC24XX_PIN_FUNCTION_01, 1) |
#define | LPC24XX_PIN_PWM_1_CHANNEL_1_P3_24 LPC24XX_PIN(3, 24, LPC24XX_PIN_FUNCTION_11, 2) |
#define | LPC24XX_PIN_PWM_1_CHANNEL_2_P1_20 LPC24XX_PIN(1, 20, LPC24XX_PIN_FUNCTION_10, 2) |
#define | LPC24XX_PIN_PWM_1_CHANNEL_2_P2_1 LPC24XX_PIN(2, 1, LPC24XX_PIN_FUNCTION_01, 1) |
#define | LPC24XX_PIN_PWM_1_CHANNEL_2_P3_25 LPC24XX_PIN(3, 25, LPC24XX_PIN_FUNCTION_11, 2) |
#define | LPC24XX_PIN_PWM_1_CHANNEL_3_P1_21 LPC24XX_PIN(1, 21, LPC24XX_PIN_FUNCTION_10, 2) |
#define | LPC24XX_PIN_PWM_1_CHANNEL_3_P2_2 LPC24XX_PIN(2, 2, LPC24XX_PIN_FUNCTION_01, 1) |
#define | LPC24XX_PIN_PWM_1_CHANNEL_3_P3_26 LPC24XX_PIN(3, 26, LPC24XX_PIN_FUNCTION_11, 2) |
#define | LPC24XX_PIN_PWM_1_CHANNEL_4_P1_23 LPC24XX_PIN(1, 23, LPC24XX_PIN_FUNCTION_10, 2) |
#define | LPC24XX_PIN_PWM_1_CHANNEL_4_P2_3 LPC24XX_PIN(2, 3, LPC24XX_PIN_FUNCTION_01, 1) |
#define | LPC24XX_PIN_PWM_1_CHANNEL_4_P3_27 LPC24XX_PIN(3, 27, LPC24XX_PIN_FUNCTION_11, 2) |
#define | LPC24XX_PIN_PWM_1_CHANNEL_5_P1_24 LPC24XX_PIN(1, 24, LPC24XX_PIN_FUNCTION_10, 2) |
#define | LPC24XX_PIN_PWM_1_CHANNEL_5_P2_4 LPC24XX_PIN(2, 4, LPC24XX_PIN_FUNCTION_01, 1) |
#define | LPC24XX_PIN_PWM_1_CHANNEL_5_P3_28 LPC24XX_PIN(3, 28, LPC24XX_PIN_FUNCTION_11, 2) |
#define | LPC24XX_PIN_PWM_1_CHANNEL_6_P1_26 LPC24XX_PIN(1, 26, LPC24XX_PIN_FUNCTION_10, 2) |
#define | LPC24XX_PIN_PWM_1_CHANNEL_6_P2_5 LPC24XX_PIN(2, 5, LPC24XX_PIN_FUNCTION_01, 1) |
#define | LPC24XX_PIN_PWM_1_CHANNEL_6_P3_29 LPC24XX_PIN(3, 29, LPC24XX_PIN_FUNCTIO9_11, 2) |
#define | LPC24XX_PIN_PWM_1_CAPTURE_0_P1_28 LPC24XX_PIN(1, 28, LPC24XX_PIN_FUNCTION_10, 2) |
#define | LPC24XX_PIN_PWM_1_CAPTURE_0_P2_7 LPC24XX_PIN(2, 6, LPC24XX_PIN_FUNCTION_01, 1) |
#define | LPC24XX_PIN_PWM_1_CAPTURE_0_P3_23 LPC24XX_PIN(3, 23, LPC24XX_PIN_FUNCTION_11, 2) |
#define | LPC24XX_PIN_PWM_1_CAPTURE_1_P1_29 LPC24XX_PIN(1, 29, LPC24XX_PIN_FUNCTION_10, 2) |
#define | LPC24XX_PIN_SSP_0_SCK_P0_15 LPC24XX_PIN(0, 15, LPC24XX_PIN_FUNCTION_10, 2) |
#define | LPC24XX_PIN_SSP_0_SCK_P1_20 LPC24XX_PIN(1, 20, LPC24XX_PIN_FUNCTION_11, 5) |
#define | LPC24XX_PIN_SSP_0_SCK_P2_22 LPC24XX_PIN(2, 22, LPC24XX_PIN_FUNCTION_11, 2) |
#define | LPC24XX_PIN_SSP_0_SSEL_P0_16 LPC24XX_PIN(0, 16, LPC24XX_PIN_FUNCTION_10, 2) |
#define | LPC24XX_PIN_SSP_0_SSEL_P1_21 LPC24XX_PIN(1, 21, LPC24XX_PIN_FUNCTION_11, 3) |
#define | LPC24XX_PIN_SSP_0_SSEL_P2_23 LPC24XX_PIN(2, 23, LPC24XX_PIN_FUNCTION_11, 2) |
#define | LPC24XX_PIN_SSP_0_MISO_P0_17 LPC24XX_PIN(0, 17, LPC24XX_PIN_FUNCTION_10, 2) |
#define | LPC24XX_PIN_SSP_0_MISO_P1_23 LPC24XX_PIN(1, 23, LPC24XX_PIN_FUNCTION_11, 5) |
#define | LPC24XX_PIN_SSP_0_MISO_P2_26 LPC24XX_PIN(2, 26, LPC24XX_PIN_FUNCTION_11, 2) |
#define | LPC24XX_PIN_SSP_0_MOSI_P0_18 LPC24XX_PIN(0, 18, LPC24XX_PIN_FUNCTION_10, 2) |
#define | LPC24XX_PIN_SSP_0_MOSI_P1_24 LPC24XX_PIN(1, 24, LPC24XX_PIN_FUNCTION_11, 5) |
#define | LPC24XX_PIN_SSP_0_MOSI_P2_27 LPC24XX_PIN(2, 27, LPC24XX_PIN_FUNCTION_11, 2) |
#define | LPC24XX_PIN_SSP_1_SCK_P0_6 LPC24XX_PIN(0, 7, LPC24XX_PIN_FUNCTION_10, 2) |
#define | LPC24XX_PIN_SSP_1_SCK_P0_12 LPC24XX_PIN(1, 31, LPC24XX_PIN_FUNCTION_10, 2) |
#define | LPC24XX_PIN_SSP_1_SCK_P4_20 LPC24XX_PIN(4, 20, LPC24XX_PIN_FUNCTION_11, 3) |
#define | LPC24XX_PIN_SSP_1_SSEL_P0_7 LPC24XX_PIN(0, 6, LPC24XX_PIN_FUNCTION_10, 2) |
#define | LPC24XX_PIN_SSP_1_SSEL_P0_13 LPC24XX_PIN(0, 14, LPC24XX_PIN_FUNCTION_11, 2) |
#define | LPC24XX_PIN_SSP_1_SSEL_P4_21 LPC24XX_PIN(4, 21, LPC24XX_PIN_FUNCTION_11, 3) |
#define | LPC24XX_PIN_SSP_1_MISO_P0_8 LPC24XX_PIN(0, 8, LPC24XX_PIN_FUNCTION_10, 2) |
#define | LPC24XX_PIN_SSP_1_MISO_P0_14 LPC24XX_PIN(0, 12, LPC24XX_PIN_FUNCTION_10, 2) |
#define | LPC24XX_PIN_SSP_1_MISO_P4_22 LPC24XX_PIN(4, 22, LPC24XX_PIN_FUNCTION_11, 3) |
#define | LPC24XX_PIN_SSP_1_MOSI_P0_9 LPC24XX_PIN(0, 9, LPC24XX_PIN_FUNCTION_10, 2) |
#define | LPC24XX_PIN_SSP_1_MOSI_P1_31 LPC24XX_PIN(0, 13, LPC24XX_PIN_FUNCTION_10, 2) |
#define | LPC24XX_PIN_SSP_1_MOSI_P4_23 LPC24XX_PIN(4, 23, LPC24XX_PIN_FUNCTION_11, 3) |
Input and output module.
