RTEMS 6.1
| struct | _flexio_uart_edma_handle |
| UART eDMA handle. More... | |
Driver version | |
| typedef struct _flexio_uart_edma_handle | flexio_uart_edma_handle_t |
| typedef void(* | flexio_uart_edma_transfer_callback_t) (FLEXIO_UART_Type *base, flexio_uart_edma_handle_t *handle, status_t status, void *userData) |
| UART transfer callback function. | |
| #define | FSL_FLEXIO_UART_EDMA_DRIVER_VERSION (MAKE_VERSION(2, 4, 1)) |
| FlexIO UART EDMA driver version. | |
| void FLEXIO_UART_TransferAbortReceiveEDMA | ( | FLEXIO_UART_Type * | base, |
| flexio_uart_edma_handle_t * | handle | ||
Aborts the receive data which using eDMA.
This function aborts the receive data which using eDMA.
| base | Pointer to FLEXIO_UART_Type |
| handle | Pointer to flexio_uart_edma_handle_t structure |
brief Aborts the receive data which using eDMA.
param base Pointer to FLEXIO_UART_Type param handle Pointer to flexio_uart_edma_handle_t structure
| void FLEXIO_UART_TransferAbortSendEDMA | ( | FLEXIO_UART_Type * | base, |
Aborts the sent data which using eDMA.
This function aborts sent data which using eDMA.
brief Aborts the sent data which using eDMA.
| status_t FLEXIO_UART_TransferCreateHandleEDMA | ( | FLEXIO_UART_Type * | base, |
| flexio_uart_edma_handle_t * | handle, | ||
| flexio_uart_edma_transfer_callback_t | callback, | ||
| void * | userData, | ||
| edma_handle_t * | txEdmaHandle, | ||
| edma_handle_t * | rxEdmaHandle | ||
Initializes the UART handle which is used in transactional functions.
| base | Pointer to FLEXIO_UART_Type. |
| handle | Pointer to flexio_uart_edma_handle_t structure. |
| callback | The callback function. |
| userData | The parameter of the callback function. |
| rxEdmaHandle | User requested DMA handle for RX DMA transfer. |
| txEdmaHandle | User requested DMA handle for TX DMA transfer. |
| kStatus_Success | Successfully create the handle. |
| kStatus_OutOfRange | The FlexIO SPI eDMA type/handle table out of range. |
brief Initializes the UART handle which is used in transactional functions.
param base Pointer to FLEXIO_UART_Type. param handle Pointer to flexio_uart_edma_handle_t structure. param callback The callback function. param userData The parameter of the callback function. param rxEdmaHandle User requested DMA handle for RX DMA transfer. param txEdmaHandle User requested DMA handle for TX DMA transfer. retval kStatus_Success Successfully create the handle. retval kStatus_OutOfRange The FlexIO SPI eDMA type/handle table out of range.
| status_t FLEXIO_UART_TransferGetReceiveCountEDMA | ( | FLEXIO_UART_Type * | base, |
| size_t * | count | ||
Gets the number of bytes received.
This function gets the number of bytes received.
| count | Number of bytes received so far by the non-blocking transaction. |
| kStatus_NoTransferInProgress | transfer has finished or no transfer in progress. |
| kStatus_Success | Successfully return the count. |
brief Gets the number of bytes received.
param base Pointer to FLEXIO_UART_Type param handle Pointer to flexio_uart_edma_handle_t structure param count Number of bytes received so far by the non-blocking transaction. retval kStatus_NoTransferInProgress transfer has finished or no transfer in progress. retval kStatus_Success Successfully return the count.
| status_t FLEXIO_UART_TransferGetSendCountEDMA | ( | FLEXIO_UART_Type * | base, |
Gets the number of bytes sent out.
This function gets the number of bytes sent out.
| count | Number of bytes sent so far by the non-blocking transaction. |
brief Gets the number of bytes sent out.
param base Pointer to FLEXIO_UART_Type param handle Pointer to flexio_uart_edma_handle_t structure param count Number of bytes sent so far by the non-blocking transaction. retval kStatus_NoTransferInProgress transfer has finished or no transfer in progress. retval kStatus_Success Successfully return the count.
| status_t FLEXIO_UART_TransferReceiveEDMA | ( | FLEXIO_UART_Type * | base, |
| flexio_uart_transfer_t * | xfer | ||
Receives data using eDMA.
This function receives data using eDMA. This is a non-blocking function, which returns right away. When all data is received, the receive callback function is called.
| xfer | UART eDMA transfer structure, see flexio_uart_transfer_t. |
| kStatus_Success | if succeed, others failed. |
| kStatus_UART_RxBusy | Previous transfer on going. |
brief Receives data using eDMA.
param base Pointer to FLEXIO_UART_Type param handle Pointer to flexio_uart_edma_handle_t structure param xfer UART eDMA transfer structure, see flexio_uart_transfer_t. retval kStatus_Success if succeed, others failed. retval kStatus_UART_RxBusy Previous transfer on going.
| status_t FLEXIO_UART_TransferSendEDMA | ( | FLEXIO_UART_Type * | base, |
Sends data using eDMA.
This function sends data using eDMA. This is a non-blocking function, which returns right away. When all data is sent out, the send callback function is called.
| handle | UART handle pointer. |
| kStatus_FLEXIO_UART_TxBusy | Previous transfer on going. |
brief Sends data using eDMA.
param base Pointer to FLEXIO_UART_Type param handle UART handle pointer. param xfer UART eDMA transfer structure, see flexio_uart_transfer_t. retval kStatus_Success if succeed, others failed. retval kStatus_FLEXIO_UART_TxBusy Previous transfer on going.
| flexio_uart_edma_transfer_callback_t _flexio_uart_edma_handle::callback |
Callback function.
| uint8_t _flexio_uart_edma_handle::nbytes |
eDMA minor byte transfer count initially configured.
| size_t _flexio_uart_edma_handle::rxDataSizeAll |
Total bytes to be received.
| edma_handle_t* _flexio_uart_edma_handle::rxEdmaHandle |
The eDMA RX channel used.
| volatile uint8_t _flexio_uart_edma_handle::rxState |
RX transfer state
| size_t _flexio_uart_edma_handle::txDataSizeAll |
Total bytes to be sent.
| edma_handle_t* _flexio_uart_edma_handle::txEdmaHandle |
The eDMA TX channel used.
| volatile uint8_t _flexio_uart_edma_handle::txState |
TX transfer state.
| void* _flexio_uart_edma_handle::userData |
UART callback function parameter.
