RTEMS 6.1
Data Structures | Enumerator | Variables
Flexio_uart
struct  _flexio_uart_type
 Define FlexIO UART access structure typedef. More...
struct  _flexio_uart_config
 Define FlexIO UART user configuration structure. More...
struct  _flexio_uart_transfer
 Define FlexIO UART transfer structure. More...
struct  _flexio_uart_handle
 Define FLEXIO UART handle structure. More...
FLEXIO_Type_flexio_uart_type::flexioBase
uint8_t _flexio_uart_type::TxPinIndex
uint8_t _flexio_uart_type::RxPinIndex
uint8_t _flexio_uart_type::shifterIndex [2]
uint8_t _flexio_uart_type::timerIndex [2]
bool _flexio_uart_config::enableUart
bool _flexio_uart_config::enableInDoze
bool _flexio_uart_config::enableInDebug
bool _flexio_uart_config::enableFastAccess
uint32_t _flexio_uart_config::baudRate_Bps
flexio_uart_bit_count_per_char_t _flexio_uart_config::bitCountPerChar
uint8_t *   _flexio_uart_transfer::data
uint8_t *   _flexio_uart_transfer::rxData
const uint8_t *   _flexio_uart_transfer::txData
union {
size_t _flexio_uart_transfer::dataSize
const uint8_t *volatile _flexio_uart_handle::txData
volatile size_t _flexio_uart_handle::txDataSize
uint8_t *volatile _flexio_uart_handle::rxData
volatile size_t _flexio_uart_handle::rxDataSize
size_t _flexio_uart_handle::txDataSizeAll
size_t _flexio_uart_handle::rxDataSizeAll
uint8_t * _flexio_uart_handle::rxRingBuffer
size_t _flexio_uart_handle::rxRingBufferSize
volatile uint16_t _flexio_uart_handle::rxRingBufferHead
volatile uint16_t _flexio_uart_handle::rxRingBufferTail
flexio_uart_transfer_callback_t _flexio_uart_handle::callback
void * _flexio_uart_handle::userData
volatile uint8_t _flexio_uart_handle::txState
volatile uint8_t _flexio_uart_handle::rxState
Driver version
enum  {
  kStatus_FLEXIO_UART_TxBusy = MAKE_STATUS(kStatusGroup_FLEXIO_UART, 0) , kStatus_FLEXIO_UART_RxBusy = MAKE_STATUS(kStatusGroup_FLEXIO_UART, 1) , kStatus_FLEXIO_UART_TxIdle = MAKE_STATUS(kStatusGroup_FLEXIO_UART, 2) , kStatus_FLEXIO_UART_RxIdle = MAKE_STATUS(kStatusGroup_FLEXIO_UART, 3) ,
  kStatus_FLEXIO_UART_ERROR = MAKE_STATUS(kStatusGroup_FLEXIO_UART, 4) , kStatus_FLEXIO_UART_RxRingBufferOverrun , kStatus_FLEXIO_UART_RxHardwareOverrun = MAKE_STATUS(kStatusGroup_FLEXIO_UART, 6) , kStatus_FLEXIO_UART_Timeout = MAKE_STATUS(kStatusGroup_FLEXIO_UART, 7) ,
  kStatus_FLEXIO_UART_BaudrateNotSupport =
 Error codes for the UART driver. More...
enum  _flexio_uart_bit_count_per_char { kFLEXIO_UART_7BitsPerChar = 7U , kFLEXIO_UART_8BitsPerChar = 8U , kFLEXIO_UART_9BitsPerChar = 9U }
 FlexIO UART bit count per char. More...
enum  _flexio_uart_interrupt_enable { kFLEXIO_UART_TxDataRegEmptyInterruptEnable = 0x1U , kFLEXIO_UART_RxDataRegFullInterruptEnable = 0x2U }
 Define FlexIO UART interrupt mask. More...
enum  _flexio_uart_status_flags { kFLEXIO_UART_TxDataRegEmptyFlag = 0x1U , kFLEXIO_UART_RxDataRegFullFlag = 0x2U , kFLEXIO_UART_RxOverRunFlag = 0x4U }
 Define FlexIO UART status mask. More...
typedef enum _flexio_uart_bit_count_per_char flexio_uart_bit_count_per_char_t
typedef struct _flexio_uart_type FLEXIO_UART_Type
typedef struct _flexio_uart_config flexio_uart_config_t
typedef struct _flexio_uart_transfer flexio_uart_transfer_t
typedef struct _flexio_uart_handle flexio_uart_handle_t
typedef void(* flexio_uart_transfer_callback_t) (FLEXIO_UART_Type *base, flexio_uart_handle_t *handle, status_t status, void *userData)
 FlexIO UART transfer callback function.
#define FSL_FLEXIO_UART_DRIVER_VERSION   (MAKE_VERSION(2, 4, 0))
 FlexIO UART driver version.
#define UART_RETRY_TIMES   0U /* Defining to zero means to keep waiting for the flag until it is assert/deassert. */
 Retry times for waiting flag.
Initialization and deinitialization
status_t FLEXIO_UART_Init (FLEXIO_UART_Type *base, const flexio_uart_config_t *userConfig, uint32_t srcClock_Hz)
 Ungates the FlexIO clock, resets the FlexIO module, configures FlexIO UART hardware, and configures the FlexIO UART with FlexIO UART configuration. The configuration structure can be filled by the user or be set with default values by FLEXIO_UART_GetDefaultConfig().
void FLEXIO_UART_Deinit (FLEXIO_UART_Type *base)
 Resets the FlexIO UART shifter and timer config.
void FLEXIO_UART_GetDefaultConfig (flexio_uart_config_t *userConfig)
 Gets the default configuration to configure the FlexIO UART. The configuration can be used directly for calling the FLEXIO_UART_Init(). Example:
Status
uint32_t FLEXIO_UART_GetStatusFlags (FLEXIO_UART_Type *base)
 Gets the FlexIO UART status flags.
void FLEXIO_UART_ClearStatusFlags (FLEXIO_UART_Type *base, uint32_t mask)
Interrupts
void FLEXIO_UART_EnableInterrupts (FLEXIO_UART_Type *base, uint32_t mask)
 Enables the FlexIO UART interrupt.
void FLEXIO_UART_DisableInterrupts (FLEXIO_UART_Type *base, uint32_t mask)
 Disables the FlexIO UART interrupt.
Bus Operations
status_t FLEXIO_UART_WriteBlocking (FLEXIO_UART_Type *base, const uint8_t *txData, size_t txSize)
 Sends a buffer of data bytes.
status_t FLEXIO_UART_ReadBlocking (FLEXIO_UART_Type *base, uint8_t *rxData, size_t rxSize)
 Receives a buffer of bytes.
Transactional
status_t FLEXIO_UART_TransferCreateHandle (FLEXIO_UART_Type *base, flexio_uart_handle_t *handle, flexio_uart_transfer_callback_t callback, void *userData)
 Initializes the UART handle.
void FLEXIO_UART_TransferStartRingBuffer (FLEXIO_UART_Type *base, flexio_uart_handle_t *handle, uint8_t *ringBuffer, size_t ringBufferSize)
 Sets up the RX ring buffer.
void FLEXIO_UART_TransferStopRingBuffer (FLEXIO_UART_Type *base, flexio_uart_handle_t *handle)
 Aborts the background transfer and uninstalls the ring buffer.
status_t FLEXIO_UART_TransferSendNonBlocking (FLEXIO_UART_Type *base, flexio_uart_handle_t *handle, flexio_uart_transfer_t *xfer)
 Transmits a buffer of data using the interrupt method.
void FLEXIO_UART_TransferAbortSend (FLEXIO_UART_Type *base, flexio_uart_handle_t *handle)
 Aborts the interrupt-driven data transmit.
status_t FLEXIO_UART_TransferGetSendCount (FLEXIO_UART_Type *base, flexio_uart_handle_t *handle, size_t *count)
 Gets the number of bytes sent.
status_t FLEXIO_UART_TransferReceiveNonBlocking (FLEXIO_UART_Type *base, flexio_uart_handle_t *handle, flexio_uart_transfer_t *xfer, size_t *receivedBytes)
 Receives a buffer of data using the interrupt method.
void FLEXIO_UART_TransferAbortReceive (FLEXIO_UART_Type *base, flexio_uart_handle_t *handle)
 Aborts the receive data which was using IRQ.
status_t FLEXIO_UART_TransferGetReceiveCount (FLEXIO_UART_Type *base, flexio_uart_handle_t *handle, size_t *count)
 Gets the number of bytes received.
void FLEXIO_UART_TransferHandleIRQ (void *uartType, void *uartHandle)
 FlexIO UART IRQ handler function.
◆ anonymous enum
anonymous enum
Transmitter is busy.
Receiver is busy.
UART transmitter is idle.
UART receiver is idle.
ERROR happens on UART.
UART RX software ring buffer overrun.
UART RX receiver overrun.
UART times out.
Baudrate is not supported in current clock source
◆ _flexio_uart_bit_count_per_char
7-bit data characters
8-bit data characters
9-bit data characters
◆ _flexio_uart_interrupt_enable
Transmit buffer empty interrupt enable.
Receive buffer full interrupt enable.
◆ _flexio_uart_status_flags
Transmit buffer empty flag.
Receive buffer full flag.
Receive buffer over run flag.
◆ FLEXIO_UART_ClearStatusFlags()
void FLEXIO_UART_ClearStatusFlags ( FLEXIO_UART_Type base,
uint32_t  mask
Parameters
basePointer to the FLEXIO_UART_Type structure.
maskStatus flag. The parameter can be any combination of the following values:
  • kFLEXIO_UART_TxDataRegEmptyFlag
  • kFLEXIO_UART_RxEmptyFlag
  • kFLEXIO_UART_RxOverRunFlag
brief Gets the FlexIO UART status flags.
param base Pointer to the FLEXIO_UART_Type structure. param mask Status flag. The parameter can be any combination of the following values: arg kFLEXIO_UART_TxDataRegEmptyFlag arg kFLEXIO_UART_RxEmptyFlag arg kFLEXIO_UART_RxOverRunFlag
◆ FLEXIO_UART_Deinit()
void FLEXIO_UART_Deinit ( FLEXIO_UART_Type base)
Note
After calling this API, call the FLEXO_UART_Init to use the FlexIO UART module.
Parameters
basePointer to FLEXIO_UART_Type structure
brief Resets the FlexIO UART shifter and timer config.
note After calling this API, call the FLEXO_UART_Init to use the FlexIO UART module.
param base Pointer to FLEXIO_UART_Type structure
◆ FLEXIO_UART_DisableInterrupts()
void FLEXIO_UART_DisableInterrupts ( FLEXIO_UART_Type base,
uint32_t  mask
This function disables the FlexIO UART interrupt.
Parameters
maskInterrupt source.
brief Disables the FlexIO UART interrupt.
param base Pointer to the FLEXIO_UART_Type structure. param mask Interrupt source.
◆ FLEXIO_UART_EnableInterrupts()
void FLEXIO_UART_EnableInterrupts ( FLEXIO_UART_Type base,
uint32_t  mask
This function enables the FlexIO UART interrupt.
Parameters
brief Enables the FlexIO UART interrupt.
◆ FLEXIO_UART_GetDefaultConfig()
void FLEXIO_UART_GetDefaultConfig ( flexio_uart_config_t userConfig)
void FLEXIO_UART_GetDefaultConfig(flexio_uart_config_t *userConfig)
Gets the default configuration to configure the FlexIO UART. The configuration can be used directly f...
Definition: fsl_flexio_uart.c:290
Definition: fsl_flexio_uart.h:86
Definition: deflate.c:114
Parameters
userConfigPointer to the flexio_uart_config_t structure.
brief Gets the default configuration to configure the FlexIO UART. The configuration can be used directly for calling the FLEXIO_UART_Init(). Example: code flexio_uart_config_t config; FLEXIO_UART_GetDefaultConfig(&userConfig); endcode param userConfig Pointer to the flexio_uart_config_t structure.
◆ FLEXIO_UART_GetStatusFlags()
uint32_t FLEXIO_UART_GetStatusFlags ( FLEXIO_UART_Type base)
Parameters
Returns
param base Pointer to the FLEXIO_UART_Type structure. return FlexIO UART status flags.
◆ FLEXIO_UART_Init()
status_t FLEXIO_UART_Init ( FLEXIO_UART_Type base,
const flexio_uart_config_t userConfig,
Example
.flexioBase = FLEXIO,
.TxPinIndex = 0,
.RxPinIndex = 1,
.shifterIndex = {0,1},
.timerIndex = {0,1}
.enableInDoze = false,
.enableInDebug = true,
.enableFastAccess = false,
.baudRate_Bps = 115200U,
.bitCountPerChar = 8
FLEXIO_UART_Init(base, &config, srcClock_Hz);
status_t FLEXIO_UART_Init(FLEXIO_UART_Type *base, const flexio_uart_config_t *userConfig, uint32_t srcClock_Hz)
Ungates the FlexIO clock, resets the FlexIO module, configures FlexIO UART hardware,...
Definition: fsl_flexio_uart.c:124
Definition: fsl_flexio_uart.h:76
Parameters
srcClock_HzFlexIO source clock in Hz.
Return values
kStatus_SuccessConfiguration success.
kStatus_FLEXIO_UART_BaudrateNotSupportBaudrate is not supported for current clock source frequency.
brief Ungates the FlexIO clock, resets the FlexIO module, configures FlexIO UART hardware, and configures the FlexIO UART with FlexIO UART configuration. The configuration structure can be filled by the user or be set with default values by FLEXIO_UART_GetDefaultConfig().
Example code FLEXIO_UART_Type base = { .flexioBase = FLEXIO, .TxPinIndex = 0, .RxPinIndex = 1, .shifterIndex = {0,1}, .timerIndex = {0,1} }; flexio_uart_config_t config = { .enableInDoze = false, .enableInDebug = true, .enableFastAccess = false, .baudRate_Bps = 115200U, .bitCountPerChar = 8 }; FLEXIO_UART_Init(base, &config, srcClock_Hz); endcode
param base Pointer to the FLEXIO_UART_Type structure. param userConfig Pointer to the flexio_uart_config_t structure. param srcClock_Hz FlexIO source clock in Hz. retval kStatus_Success Configuration success. retval kStatus_FLEXIO_UART_BaudrateNotSupport Baudrate is not supported for current clock source frequency.
◆ FLEXIO_UART_ReadBlocking()
status_t FLEXIO_UART_ReadBlocking ( FLEXIO_UART_Type base,
uint8_t *  rxData,
size_t  rxSize
Note
This function blocks using the polling method until all bytes have been received.
Parameters
rxDataThe buffer to store the received bytes.
rxSizeThe number of data bytes to be received.
Return values
kStatus_FLEXIO_UART_TimeoutTransmission timed out and was aborted.
kStatus_SuccessSuccessfully received all data.
brief Receives a buffer of bytes.
note This function blocks using the polling method until all bytes have been received.
param base Pointer to the FLEXIO_UART_Type structure. param rxData The buffer to store the received bytes. param rxSize The number of data bytes to be received. retval kStatus_FLEXIO_UART_Timeout Transmission timed out and was aborted. retval kStatus_Success Successfully received all data.
◆ FLEXIO_UART_TransferAbortReceive()
void FLEXIO_UART_TransferAbortReceive ( FLEXIO_UART_Type base,
flexio_uart_handle_t handle
This function aborts the receive data which was using IRQ.
Parameters
handlePointer to the flexio_uart_handle_t structure to store the transfer state.
brief Aborts the receive data which was using IRQ.
param base Pointer to the FLEXIO_UART_Type structure. param handle Pointer to the flexio_uart_handle_t structure to store the transfer state.
◆ FLEXIO_UART_TransferAbortSend()
void FLEXIO_UART_TransferAbortSend ( FLEXIO_UART_Type base,
This function aborts the interrupt-driven data sending. Get the remainBytes to find out how many bytes are still not sent out.
Parameters
brief Aborts the interrupt-driven data transmit.
◆ FLEXIO_UART_TransferCreateHandle()
status_t FLEXIO_UART_TransferCreateHandle ( FLEXIO_UART_Type base,
flexio_uart_handle_t handle,
void *  userData
This function initializes the FlexIO UART handle, which can be used for other FlexIO UART transactional APIs. Call this API once to get the initialized handle.
The UART driver supports the "background" receiving, which means that users can set up a RX ring buffer optionally. Data received is stored into the ring buffer even when the user doesn't call the FLEXIO_UART_TransferReceiveNonBlocking() API. If there is already data received in the ring buffer, users can get the received data from the ring buffer directly. The ring buffer is disabled if passing NULL as ringBuffer.
Parameters
baseto FLEXIO_UART_Type structure.
callbackThe callback function.
userDataThe parameter of the callback function.
Return values
kStatus_SuccessSuccessfully create the handle.
kStatus_OutOfRangeThe FlexIO type/handle/ISR table out of range.
brief Initializes the UART handle.
The UART driver supports the "background" receiving, which means that users can set up a RX ring buffer optionally. Data received is stored into the ring buffer even when the user doesn't call the FLEXIO_UART_TransferReceiveNonBlocking() API. If there is already data received in the ring buffer, users can get the received data from the ring buffer directly. The ring buffer is disabled if passing NULL as p ringBuffer.
param base to FLEXIO_UART_Type structure. param handle Pointer to the flexio_uart_handle_t structure to store the transfer state. param callback The callback function. param userData The parameter of the callback function. retval kStatus_Success Successfully create the handle. retval kStatus_OutOfRange The FlexIO type/handle/ISR table out of range.
◆ FLEXIO_UART_TransferGetReceiveCount()
status_t FLEXIO_UART_TransferGetReceiveCount ( FLEXIO_UART_Type base,
size_t *  count
This function gets the number of bytes received driven by interrupt.
Parameters
countNumber of bytes received so far by the non-blocking transaction.
Return values
kStatus_NoTransferInProgresstransfer has finished or no transfer in progress.
kStatus_SuccessSuccessfully return the count.
brief Gets the number of bytes received.
param base Pointer to the FLEXIO_UART_Type structure. param handle Pointer to the flexio_uart_handle_t structure to store the transfer state. param count Number of bytes received so far by the non-blocking transaction. retval kStatus_NoTransferInProgress transfer has finished or no transfer in progress. retval kStatus_Success Successfully return the count.
◆ FLEXIO_UART_TransferGetSendCount()
status_t FLEXIO_UART_TransferGetSendCount ( FLEXIO_UART_Type base,
size_t *  count
This function gets the number of bytes sent driven by interrupt.
Parameters
countNumber of bytes sent so far by the non-blocking transaction.
Return values
brief Gets the number of bytes sent.
param base Pointer to the FLEXIO_UART_Type structure. param handle Pointer to the flexio_uart_handle_t structure to store the transfer state. param count Number of bytes sent so far by the non-blocking transaction. retval kStatus_NoTransferInProgress transfer has finished or no transfer in progress. retval kStatus_Success Successfully return the count.
◆ FLEXIO_UART_TransferHandleIRQ()
void FLEXIO_UART_TransferHandleIRQ ( void *  uartType,
void *  uartHandle
This function processes the FlexIO UART transmit and receives the IRQ request.
Parameters
uartTypePointer to the FLEXIO_UART_Type structure.
uartHandlePointer to the flexio_uart_handle_t structure to store the transfer state.
brief FlexIO UART IRQ handler function.
param uartType Pointer to the FLEXIO_UART_Type structure. param uartHandle Pointer to the flexio_uart_handle_t structure to store the transfer state.
◆ FLEXIO_UART_TransferReceiveNonBlocking()
status_t FLEXIO_UART_TransferReceiveNonBlocking ( FLEXIO_UART_Type base,
flexio_uart_transfer_t xfer,
size_t *  receivedBytes
This function receives data using the interrupt method. This is a non-blocking function, which returns without waiting for all data to be received. If the RX ring buffer is used and not empty, the data in ring buffer is copied and the parameter receivedBytes shows how many bytes are copied from the ring buffer. After copying, if the data in ring buffer is not enough to read, the receive request is saved by the UART driver. When new data arrives, the receive request is serviced first. When all data is received, the UART driver notifies the upper layer through a callback function and passes the status parameter kStatus_UART_RxIdle. For example, if the upper layer needs 10 bytes but there are only 5 bytes in the ring buffer, the 5 bytes are copied to xfer->data. This function returns with the parameter receivedBytes set to 5. For the last 5 bytes, newly arrived data is saved from the xfer->data[5]. When 5 bytes are received, the UART driver notifies upper layer. If the RX ring buffer is not enabled, this function enables the RX and RX interrupt to receive data to xfer->data. When all data is received, the upper layer is notified.
Parameters
xferUART transfer structure. See flexio_uart_transfer_t.
receivedBytesBytes received from the ring buffer directly.
Return values
kStatus_SuccessSuccessfully queue the transfer into the transmit queue.
kStatus_FLEXIO_UART_RxBusyPrevious receive request is not finished.
brief Receives a buffer of data using the interrupt method.
This function receives data using the interrupt method. This is a non-blocking function, which returns without waiting for all data to be received. If the RX ring buffer is used and not empty, the data in ring buffer is copied and the parameter p receivedBytes shows how many bytes are copied from the ring buffer. After copying, if the data in ring buffer is not enough to read, the receive request is saved by the UART driver. When new data arrives, the receive request is serviced first. When all data is received, the UART driver notifies the upper layer through a callback function and passes the status parameter ref kStatus_UART_RxIdle. For example, if the upper layer needs 10 bytes but there are only 5 bytes in the ring buffer, the 5 bytes are copied to xfer->data. This function returns with the parameter p receivedBytes set to 5. For the last 5 bytes, newly arrived data is saved from the xfer->data[5]. When 5 bytes are received, the UART driver notifies upper layer. If the RX ring buffer is not enabled, this function enables the RX and RX interrupt to receive data to xfer->data. When all data is received, the upper layer is notified.
param base Pointer to the FLEXIO_UART_Type structure. param handle Pointer to the flexio_uart_handle_t structure to store the transfer state. param xfer UART transfer structure. See flexio_uart_transfer_t. param receivedBytes Bytes received from the ring buffer directly. retval kStatus_Success Successfully queue the transfer into the transmit queue. retval kStatus_FLEXIO_UART_RxBusy Previous receive request is not finished.
◆ FLEXIO_UART_TransferSendNonBlocking()
status_t FLEXIO_UART_TransferSendNonBlocking ( FLEXIO_UART_Type base,
This function sends data using an interrupt method. This is a non-blocking function, which returns directly without waiting for all data to be written to the TX register. When all data is written to the TX register in ISR, the FlexIO UART driver calls the callback function and passes the kStatus_FLEXIO_UART_TxIdle as status parameter.
Note
The kStatus_FLEXIO_UART_TxIdle is passed to the upper layer when all data is written to the TX register. However, it does not ensure that all data is sent out.
Parameters
xferFlexIO UART transfer structure. See flexio_uart_transfer_t.
Return values
kStatus_SuccessSuccessfully starts the data transmission.
kStatus_UART_TxBusyPrevious transmission still not finished, data not written to the TX register.
brief Transmits a buffer of data using the interrupt method.
This function sends data using an interrupt method. This is a non-blocking function, which returns directly without waiting for all data to be written to the TX register. When all data is written to the TX register in ISR, the FlexIO UART driver calls the callback function and passes the ref kStatus_FLEXIO_UART_TxIdle as status parameter.
note The kStatus_FLEXIO_UART_TxIdle is passed to the upper layer when all data is written to the TX register. However, it does not ensure that all data is sent out.
param base Pointer to the FLEXIO_UART_Type structure. param handle Pointer to the flexio_uart_handle_t structure to store the transfer state. param xfer FlexIO UART transfer structure. See flexio_uart_transfer_t. retval kStatus_Success Successfully starts the data transmission. retval kStatus_UART_TxBusy Previous transmission still not finished, data not written to the TX register.
◆ FLEXIO_UART_TransferStartRingBuffer()
void FLEXIO_UART_TransferStartRingBuffer ( FLEXIO_UART_Type base,
uint8_t *  ringBuffer,
This function sets up the RX ring buffer to a specific UART handle.
When the RX ring buffer is used, data received is stored into the ring buffer even when the user doesn't call the UART_ReceiveNonBlocking() API. If there is already data received in the ring buffer, users can get the received data from the ring buffer directly.
Note
When using the RX ring buffer, one byte is reserved for internal use. In other words, if ringBufferSize is 32, only 31 bytes are used for saving data.
Parameters
ringBufferStart address of ring buffer for background receiving. Pass NULL to disable the ring buffer.
ringBufferSizeSize of the ring buffer.
brief Sets up the RX ring buffer.
note When using the RX ring buffer, one byte is reserved for internal use. In other words, if p ringBufferSize is 32, only 31 bytes are used for saving data.
param base Pointer to the FLEXIO_UART_Type structure. param handle Pointer to the flexio_uart_handle_t structure to store the transfer state. param ringBuffer Start address of ring buffer for background receiving. Pass NULL to disable the ring buffer. param ringBufferSize Size of the ring buffer.
◆ FLEXIO_UART_TransferStopRingBuffer()
void FLEXIO_UART_TransferStopRingBuffer ( FLEXIO_UART_Type base,
This function aborts the background transfer and uninstalls the ring buffer.
Parameters
brief Aborts the background transfer and uninstalls the ring buffer.
◆ FLEXIO_UART_WriteBlocking()
status_t FLEXIO_UART_WriteBlocking ( FLEXIO_UART_Type base,
const uint8_t *  txData,
size_t  txSize
Note
This function blocks using the polling method until all bytes have been sent.
Parameters
txDataThe data bytes to send.
txSizeThe number of data bytes to send.
Return values
kStatus_SuccessSuccessfully wrote all data.
brief Sends a buffer of data bytes.
note This function blocks using the polling method until all bytes have been sent.
param base Pointer to the FLEXIO_UART_Type structure. param txData The data bytes to send. param txSize The number of data bytes to send. retval kStatus_FLEXIO_UART_Timeout Transmission timed out and was aborted. retval kStatus_Success Successfully wrote all data.
Variable Documentation
◆ baudRate_Bps
Baud rate in Bps.
◆ bitCountPerChar
number of bits, 7/8/9 -bit
◆ callback
Callback function.
◆ data [1/2]
uint8_t* _flexio_uart_transfer::data
The buffer of data to be transfer.
◆  [2/2]
uint8_t* { ... } ::data
◆ dataSize
Transfer size
◆ enableFastAccess
Enable/disable fast access to FlexIO registers, fast access requires the FlexIO clock to be at least twice the frequency of the bus clock.
◆ enableInDebug
Enable/disable FlexIO operation in debug mode
◆ enableInDoze
Enable/disable FlexIO operation in doze mode
◆ enableUart
Enable/disable FlexIO UART TX & RX.
◆ flexioBase
FLEXIO_Type* _flexio_uart_type::flexioBase
FlexIO base pointer.
◆ rxData [1/3]
uint8_t* _flexio_uart_transfer::rxData
The buffer to receive data.
◆  [2/3]
uint8_t* { ... } ::rxData
◆ rxData [3/3]
uint8_t* volatile _flexio_uart_handle::rxData
Address of remaining data to receive.
◆ rxDataSize
Size of the remaining data to receive.
◆ rxDataSizeAll
Total bytes to be received.
◆ RxPinIndex
Pin select for UART_Rx.
◆ rxRingBuffer
uint8_t* _flexio_uart_handle::rxRingBuffer
Start address of the receiver ring buffer.
◆ rxRingBufferHead
Index for the driver to store received data into ring buffer.
◆ rxRingBufferSize
◆ rxRingBufferTail
Index for the user to get data from the ring buffer.
◆ rxState
RX transfer state
◆ shifterIndex
uint8_t _flexio_uart_type::shifterIndex[2]
Shifter index used in FlexIO UART.
◆ timerIndex
uint8_t _flexio_uart_type::timerIndex[2]
Timer index used in FlexIO UART.
◆ txData [1/3]
const uint8_t* _flexio_uart_transfer::txData
The buffer of data to be sent.
◆  [2/3]
const uint8_t* { ... } ::txData
◆ txData [3/3]
const uint8_t* volatile _flexio_uart_handle::txData
Address of remaining data to send.
◆ txDataSize
Size of the remaining data to send.
◆ txDataSizeAll
Total bytes to be sent.
◆ TxPinIndex
Pin select for UART_Tx.
◆ txState
TX transfer state.
◆ userData
void* _flexio_uart_handle::userData
UART callback function parameter.
